Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Will not power on light blinks 3 times
Will not power up it tries 3 times cannot find any obvious physical problem
  • RCA Master
  • 8,617 Answers
3 blinks is the code indicating that the flyback is bad. You need flyback 259296 you can get a new one at the following link
http://servicemanuals.vstore.ca/
Posted on Jun 05, 2008
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Picture went out and no audio, red light on power blinks seven times and repeats.
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
I have a Sony KSDR60XBR1. Beginning today, when I hit the power button the power/standby light blinks green approx 50 times and then begins to blink red 5 times. The picture is black and there is no...
Sounds like your lamp has failed. May not be physically blown but the 5 blink code indicates either the lamp or ballast has failed. Normally its the lamp. Good Luck!
Nov 21, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Stop working just red light blinking and when I turn off and turn on working just for 2 seconds then again red light blinking
Plug out the disc, and all cables connected to your console after 2 to 3 minutes see if it will run, if this does not fix the problem try to connect to a different outlet, maybe the power supply of your console is damage and needs repair.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
2002 Panasonic PT-47WX52F - Power button now just blinks 3 times
thats the convergence circuits needing repair. You can repair it yourself for around 50.00 with the convergence repair kit for your model from www.tvrepairworld.com the kits contain the parts and the CD with instructions.
Mar 28, 2010 | Panasonic PT-47WX53 47" Rear Projection...
RCA D52W20 Light blinks 3 times, Replaced Flyback, Caps
I have the schematic, did the same thing and still have the problem. Any help?
Aug 12, 2009 | Televison & Video
My RCA HD50LPW175yx7 is blinling five(5) times and then shuts off
i have the same t.v. the owners manual says "if the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on.If the t.v. does'nt turn on after 5 minutes and the light blinks steadily for 1 minute , one of the following is possible: lamp door is open , lamp is dead , or the power supply within the t.v. needs service.
Nov 29, 2008 | RCA HD50LPW175 50" HDTV
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
