Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Dish washer?? The problem we are having is it washes fine but the water is not draining out after the wash cycle....Does that mean the pump is out..... Thanks John
Thank this is on the money. It works for me thks
Posted on Sep 15, 2008
  • 413 Answers
Has a disposer been installed recently? If so the drain plug may not have been removed...... Some DW have a check valve attached to the sump that may have a blockage..... Remove the drain hose from the disposer, if connected to one and inspect for blockage.
Posted on Jun 01, 2008
We discovered broken glass dish in bottom of dishwasher with some pieces below the bottom pump area. Shortly after the washer is making a louder noise during operation time. The water pump is quite when...
sounds like you have broken glass in the wash pump you will have to remove pump from sump and clear also check the drain pump.good luck let me know how it goes
Jun 22, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Du401 doesn't drain water
there is a little pump at the bottom of the machine,called the askoll pump".this is what pumps out water before and after a cycle.the pump needs replacing.
Nov 01, 2009 | Dishwashers
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher is filling up but not washing dishes.it will run the programme and also drain the water
Sounds like the washer arm is not rotating around during the wash cycle.. Can you reach in and manually rotate the arm to make sure it is free to spin? Also, it may be washing but the drain filter has so much sediment in it from previous cycles that it is just redistributing that stuff on you dishes.. check the drain filter too... lastly, is the detergent dispenser opening after a wash cycle? If it is empty ( meaning it has been used) the other things mentioned above are probably the issue.. Hope that helps...
Aug 16, 2008 | Dishwashers
Hoover optima AAA1600 hntf 6167 washing machine
Most washers have a drain hose that is mouted high to keep the water in. If you drop the hose to floor level it will drain with out help. Be sure you have a floor drain or bucket. Then check the belt on the motor if there is slack it will not engage the pump for drain to operate. Need to tighten the belt.
Mar 25, 2008 | Indesit W 123 Front Load Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Dishwasher Repair
Ebers, you have a seperate wash and drain motor on this model. When you remove the bottom panel the drain pump will be on the right and the circulation (wash) pump will be in the rear. You are going to have to verify that you have power getting to the wash motor. Sometimes this is difficult without removing the dishwasher. The motor may have a quick connect harness going to it that you can check voltage there. If you have voltage to the motor during the wash cycle and it's not running, well, there's the problem. If no voltage, then it's probably a timer issue. Catriver..post back
Feb 05, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Jul 01, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
90 people viewed this question
Top GE Dishwashers Experts
Mike
Ned Halaweh
Ned Halaweh
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
