I'm in a hotel I want to watch my dvds from my own dvd player. I hook video RCA to video and the white for sound. The tv has three rca jacks vid, sound input, sound output. It has cable coax and what looks like a phone jack for thief and another phone jack connection for a game controler. The cable seems to be some hotel basic cable. All I want is to go INPUT AND WATCH MY DVD MOVIE where is the darm button for input or whats the trick? Thanks, John
    Scholar:
  • 143 Answers
I would call the front desk. The maintenence tech can help you!
Posted on Oct 13, 2010
I'm trying to hook up my DVD player to my TV but my TV doesn't have a yellow jack only red and black
If your TV doesn't have a Video IN jack (Yellow) then you would have to attach your dvd by antenna (Coaxial) cable. What does the DVD have on the back ? EG: Video Out is Yellow, Red is Right Audio, White is Left Audio. If your DVD has Ant in & Ant Out you can use a coaxial cable from Ant out to your tv's antenna In socket and put your antenna cable (from your wall socket) to Ant in on the dvd. Turn on the dvd and put your tv on a blank station and tune your tv till you see the dvd screen . lock it in and that becomes your DVD channel to watch your dvd's.
Hope this is some help.
Sep 07, 2015 | RCA Televison & Video
I'm trying to hook my DVD player to my tv its a vizio flat screen but I keep getting a Aucum Signal... What do I do
hook your dvd player into video 0ne two or three, there indication is red white and yellow. red for left sound white for right sound and yellow for video. then turn your tv to video output to what ever you attatched your rca cable to either vid 1 2 or 3. the remote should have an input selection, good luck this is easy and if you hook the cables up to the red white and yellow connections either on the side front or back of the tv it will detect it normaly, if not choose it from the remotes selection tab, called input selection. hope this helps.
Nov 12, 2012 | Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
I am trying to hook up a Memorex DVD player (MVD 2022), and I am not getting it to work. I need to see how to connect the cords or what cords I need. I can't seem to find how to download a manual.
Connect a yellow RCA cable from the yellow video jack on the DVD player to the yellow video input jack on the TV. This will give you the picture. For sound, connect a white RCA cable from the white audio jack on the DVD player to the white audio input jack on the TV. This will give you sound. Use the TV remote to select the input you connected the DVD player to, just press INPUT SELECT or VIDEO or the like until you see the DVD player's output.
Power on the TV and the DVD player. Place a DVD in the disc tray of the player and press PLAY.
If your TV has only a RF coax input, then you will need to buy an RF Modulator.
Mar 15, 2011 | Televison & Video
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
How do you hook up this dvd player to the tv. the plugs are blue green and red instead of white yellow and red
The DVD player has component video as well as the S-video and RCA video and two RCA audio outputs.
If your player is the same as my picture, the component video jacks are in a horizontal line at the top of the back of the player. The white and red audio jacks are in a vertical line to the left. The yellow video out jack is in the second line just below the component video jacks (in a line with the coax port, the S-video port is in between the coax and the RCA video out). (The white jack is at the top left of the connections block, red below that, and yellow to the right of the red.)
I hope this helps.
May 29, 2010 | RCA DRC247N DVD Player
I just purchased this tv. I had no trouble hooking up the satalite cable box but When I hooked up the dvd player the picture is only in black and white. How do I fix this?
Are you using component video (red/blue/green) rca jacks, or composite video input (yellow) rca jack? You need to match the color but watch out and do not get confused with the red and white RCA for audio.
Dec 17, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Hook up portable dvd to tv
Connect the phone jack sized end of the wire to the portable DVD player and then connect the 3 RCA's to your tv in the color coded spots. Yellow for Video, Red and White for Sound.
Dec 18, 2008 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Hitachi ultravision 50v500
there should be 3 sets of video rca jacks on tv or receiver they might have put them on the wrong rca jack in which they just need to be moved over
usually the 3rd set of rca jacks are component jacks not for tv or video but for low output signals say like cameras and only one set of rca's can be used at a time svg on one of them rca's will over power the vid's. so have no picture
Apr 14, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Want to watch thru tv
Hi
Check and see if you have A/V out jacks on the unit. If you do, they will be yellow, red, and white.
They are called RCA jacks, and if you have them, and the TV has the same type of jacks, then you just need the cable that goes in between. The DVD player normally comes with them, but if not, you can purchase them at any Circuit City, or even Walmart.
Jan 14, 2008 | Mintek MDP-1815 Portable DVD Player
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
