Hello, I have a Pinnacle Systems GmbH, DV-1394 Internal firewire pci card and I need the name of the Software that comes with this Card.
2 Suggested Answers
SOURCE: 1394 Header pin-out
http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_25&products_id=57&osCsid=aeefcbb79e7dab18e3439d5d6c64cb0f
Ritmo PCI to USB + 1394 (CC-C15)
PPA USB2.0 + 1394 Combo PCI Card Model 1509
http://www.ppa-usa.com/products/usb/usb_pci/1578.htm
click on get pinouts for pdf file of card
Pinouts:
USB board is slikscreened with numbers but for reference
pin 1 ground is at top edge of board
and pin 5 plus 5v is towards gold connector edge
1. case Gnd (thick black)
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
Firewire: (8 pin header on board)
this board uses the 4pin firewire connection standard
NOT THE 6/9 PIN!!!! you only need to connect 4 pins
and if you have a thick case ground cable you can use it
pin 7 is towards bracket towards top edge of card
pin 8 is towards bracked towards gold edge connector
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
3 Case Gnd Thick Black (not thin black) if you have one
(white 30vdc) and (thin black, signal Gnd)
wires are not used
pins 1 and 2 are also unused for firewire connections
please note that this card has +12v on pin 2 instead of the
30v dc that a normal firewire 6 pin connection has
Posted on Nov 22, 2009
Have just bought new computor which doesnt have a dv opening so i cannot connect my sharp camcoder to computor, is there an adapter for this dv cable?
Many computers come without a dv connection though of late quite a number are catching up. What you need is to buy a firewire 1394 card, called the I-link card by Sony. This is the card that you put in your computer on one of the PCI slots. The firewire card usually comes with the cable and software for it so you don't have to worry about that. If you are not able to put the firewire card yourself then get someone who is computer literate to do it for you. Hope this helps you.
Oct 30, 2011 | Sharp Viewcam VL-Z5H Mini DV Digital...
Good Day! How will i connect and manage my camera to computer.
For the DCR PC101E you need to use a firewire cable or 1394 cable or the i-Link cable which goes to your computer this is one and the same thing with different names. However if your computer does not have a connection for this you must go and buy a 1394 pci card that you have to connect inside your computer. These usually come with the software drivers for the 1394 card.
Mar 16, 2011 | Sony Handycam DCR-PC101E Mini DV Digital...
I need power adapter volt/amp
Looks like maybe 3.3 volts, 1.5 amps not sure of the polarity.
The Pinnacle Studio MovieBox DV Includes
  • MovieBox DV external analog to DV converter
  • Full version of Pinnacle Studio 9
  • Hollywood FX transitions
  • TitleDeko for titling
  • 4pin/6pin IEEE-1394 FireWire cable
    6pin/6pin IEEE-1394 FireWire cable
  • Power Cord
  • Power supply: 110V 60HZ 3.3V/1.5A
  • Studio Software 9 manual
  • MovieBox DV hardware manual
Dec 12, 2009 | Pinnacle Studio MovieBox DV 9 (210100349)...
Does moviebox usb work with studio 14 and vista? I can't get my camera to show as an import device when connected to the movie box.
This is the latest hardware device that can used for Studio 14.
Check the list.
USB based
  • 710-USB
  • 510-USB
  • 700-USB
  • 500-USB
  • MovieBox Deluxe
  • DVC-103
  • DVC-107
  • DVC-100
  • DVC-90
  • DVC-130 (There are no 64-bit drivers for this product.)
  • DVC-170 (There are no 64-bit drivers for this product.)
PCI based
  • 700-PCI (a.k.a. Pinnacle Studio Deluxe 2)
  • 500-PCI (a.k.a. Pinnacle AV/DV)
  • Any 1394 cards.
Are you using vista 32 or 64 bit system? If Vista 64 bit there is no driver for your device and the only available is 32 bit only. Aside from that you can check also the video cable you were trying to used. If firewire under import/capture tab of Studio 14 you need to select the name of your camcorder or dv camcorder. Check that out and try.
Dec 07, 2009 | Pinnacle Studio MovieBox USB Video Capture
Do I need a fire wire card for PC
Hi a firewire input is different from an 1394 port. For the laptop you can buy an firewire interface.
Regards,
Rob NL
Apr 16, 2009 | JVC GR-D370 Mini DV Digital Camcorder
1394 Header pin-out
Pinouts:
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
wires are not used
Sep 01, 2008 | Televison & Video
Transfer moving video
You will need third party hardware and software in order to transfer moving video from your camera to your PC. Depending on what camera you have, a few different options are available to you. For more information on IEEE 1394 connectors locate the websites of manufacturers of this hardware. The following manufacturers firewire products were tested with JVC camcorders: Pinnacle Systems, Belkin, Orange Micro, Digital Origin, Ratoc . Please be advised that compatibility of JVC camera with firewire card may also depends on your particular computer specifications/hardware settings. Even though we tested the above hardware and bundled software there will be always exceptions and JVC doesn’t guarantee that computer, firewire card and JVC camcorder will interface flawlessly in everybody case.
Sep 14, 2005 | JVC GR-D70EK Mini DV Digital Camcorder
Can I transfer Moving Video from my camera to my PC?
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Televison & Video Logo
346 people viewed this question
Top Televison & Video Experts
Electro Med Services...
