Question about Harmar AL500 Platform Power Wheelchair Lift
Looking for replacement accuator motor for Harmar AL500 lift.
HARMAR WILL NOT PROVIDE A MAINTENANCE MANUAL ( NOT OWNERS MANUAL)FOR MY PLATFORM LIFT
only if you spell 'maintenance' correctly. I gave you a hand in the title :>)
Google
make model service manual
That will bring the results if there is one online. You will find some manual sites are scammers and deceitful. They say they have the details, but they don't.
Feb 01, 2016 | Exercise & Fitness
How can I get a manual for a Harmar AL0-Axis T lift?
You could try googling it. PDF manuals are usually available for download.
Nov 28, 2014 | Cars & Trucks
Al300 cannot lower the lift
at the top of the control box there under a sticker or in a small hole there should be a 7/16th nut you can use to lower the lift manually. but could be a power issue trace the line from the battery source. If the power checks out and you are getting 12 volts to the control box it could be the switch or the motor to rule out on of these you can disconnect the motor cable and apply direct power to it if it moves up or down then you know its not the motor which could only mean it is the switch. (when applying direct power to motor if it does not move when you put red on red and black on black then reverse them red on black and black on red.)
Jul 19, 2014 | Harmar Wheelchair Lift System - Power...
How to replace wheels on sl350 stairlift
Did you ever figure out how to replace the wheels on your Harmar stair lift? I think I got the same problem, but can't find where I can buy the replacement wheels? Can you help? dennismolgaard@yahoo.com
Dec 18, 2013 | Harmar Sl350 Stair Lift
Harmar AL435 wheelchair lift arm will not rotate in and out (fuse not blown) Winch and extendable arm work fine. Thanx for any help. Gary
Hallo, mayby late but I had last month the same problem. When you open the electric board wirh the rubber cover. It's on the side of the lift. When opend by the 4 screws you see the board. On the left side there is a red block with I think 6 or 8 white mini switches. First take a picture of the standing of these switches. After this you switch every switch a few times. After this your rotation will work again. It's ocydation of the switches. Succes. John from Holland.
Sep 10, 2013 | Harmar Hamar AL435 Lift - Axis III /...
Wiring diagram for Harmar AL600 Lift
understand but no wiring picture found for this simple circuit
Mar 30, 2012 | Harmar AL600 Hybrid Platform Lift
I need 12v wiring harness for 2pin connector on a harmer al500 this is the hot and ground connection thats plugs into lift wiring going to battery. can this be bought at auto parts store and what is this...
I had the same problem. You can go to a marine supply co. They carry the 2-wire lead plug connector sets, available in several gage wires, I used a 10 gage set and it costs around $6.00.
Jul 08, 2011 | Harmar Mobility AL500 Power Chair Lift
Where can i find the retractable restraints for a Ha,mar ? I have to that do not retract anumore
Go ahead and go to harmarmobility.com and on there web page there is a dealer locater enter your zip ,and that should send you on the right road.to getting your parts.
happy to be of help
Jan 17, 2011 | Harmar AL500 Platform Power Wheelchair...
Need black Cover on the lift motor..Holds tag also..Al 500 model..Need Customer Service Manel also..Bought 2nd hand.
Found Avenue Medical on search..Ordered new plastic cover, New wire harness for Vehicle..Was able to get a service manual printed..Problem is solved..Was a bit expensive..Thanks much for re-contact...
Aug 24, 2009 | Harmar Mobility AL500 Power Chair Lift
The lift extended to far down and will not come up. need diagram to show how gear shaft connects to raise platform
their should be a plastic plug on top of the cover, remove round plug and insert deep socket with extention and manually turn. this should free-up the worm screrw and allow the motor to work
Mar 25, 2009 | Harmar Mobility AL410 Universal Inside...
Harmar AL500 Platform Power Wheelchair Lift Logo
168 people viewed this question
Top Harmar Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Harmar Health and Beauty Expert? Answer questions, earn points and help others
