Question about Whirlpool Heating & Cooling
On switching on the AC(whirlpool Magicool 150 Ei) the number '0' starts blinking and compressor does not switch on and nothing happens on pressing the mode button
catriver
  • 878 Answers
SOURCE: Compressor turns on but not the fan.
Jeannine, on this model there is one motor that turns both the evaporator and condensor fans. First you want to check to see if there is any obstruction preventing the fans from turning. There is also a dual capacitor that gives this motor a kick start. If this goes bad the motor will not run, just humm. Hopefully it is just your capacitor that has failed but it could be the motor itself. Part number for the capacitor is 16-05-00710-109. Part number for the motor is 50-11-t26p0-050. Usually a bad capacitor will show signs of leaking or bulging, but not always...Catriver..post back
Posted on Aug 02, 2006
  • 18 Answers
SOURCE: some times AC blows hot/warm air
Not sure which model you have but i would check your indoor and outdoor temperature sensors  and also it could be your overload kickin the compressor off
Posted on Oct 14, 2007
  • 86 Answers
SOURCE: I need a Remote plate for windows split ac
remote problem.replace remote
Posted on Mar 17, 2008
SOURCE: Cool/AC light is blinking
Try cleaning the filters & coils good with a shop vac, or a scrub brush.
Posted on Aug 04, 2008
  • 124 Answers
SOURCE: High Pressure cutoff
YOUR OUTDOOR FAN MOTOR SHOULD NEVER SHUT OFF IN THE AC MODE. IT IS SUPPOSED TO SHUT OFF IN THE HEAT MODE WHEN ITS IN DEFROST. IF THE UNIT IS RUNNING IN COOL AND THE OUTSIDE MOTOR QUITS ,THE COMPRESSOR WILL QUIT SOON AFTER. EITHER THE RUN CAPACITOR FOR THE FAN IS BAD OR THE FAN MOTOR ITSELF IS BAD, IF CAP IS GOOD THEN THE MOTOR IS At FAULT. THE OUTDOOR PRESSURE SWITCH CAN ALSO OPEN IF THE INDOOR FAN MOTOR FAILS IN HEAT OR THE FILTER IS PLUM NASTY in heat OR THE INDOOR COIL IS PLUGGED UP in heat.. THE PRESSURE SWITCH USUALLY TRIPS AT 400 TO 425 SO ITS WORKING CORRECTLY. YOU MAY BE CONFUSING THE ISSUE SAYING THAT THE AIR IS HOT AND COLD INSIDE. IT IS COLD WHEN AC IS RUNNING HOT WHEN HEAT PUMP IS RUNNING IN HEAT BUT ESSENTIALLY not cold or hot if compressor isn't running, but a lot of folks describe the lack of cold air as hot when the compressor isnt running. but it basically is warm or house air temp.you test the capacitor with a capacitor tester or take it to motor shop and let them test it. odds are its a 5 , 7.5 or a 10. it should test within 10 % of rated value . ask for a RESCUE brand replacement motor. they are great ,reversable etc.carefully oil and sand the motor shaft and note exactly where the blade was located in relation to the grill so you get it back just the same. usually they wire up black to a leg of 220 power. white to the other leg of 220 power. brown and brown with white stripe to the capacitor.you can also pull whole fan shroud assembly on some units and take whole thing to motor shop and let them test motor cap, replace and all you do is return to unit and connect two power leads,
Posted on Oct 26, 2008
I have a 6E code on my dryer and it wont start . When you press the start button it only got a click and nothing happens. The drive belt was broken when I looked inside could that be a problem it's a...
Looking at an other diy fix site (answer by Jake)
Its your door switch that's bad.
Here is the online repair manual for the Whirlpool Duet dryer:
http://www.applianceblog.com/manuals/Duetdry.pdf
Give it time to download. Page 4-6 tells you how to access it. You can print it out as well.
Here's another member that had the same error code and the door switch fixed it too:
http://www.applianceblog.com/mainfor...not-start.html
Here's the door switch for your model you can order:
Manufacturer's Number: 8283288
[img src="http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfaHRfODgyMzgyOC9MUFcvc290b2hwdHJhcC8%3d" border="0" alt="">
Jake
Hope that helps Gerry
Sep 11, 2014 | Dryers
How do i get my ac to work on my 94 honda accord?
You did not say you had check the Freon level or the low pressure switch on the dryer. The low pressure switch will shut down the compressor when it is low on Freon. Hope this helps.
May 17, 2017 | 1994 Honda Accord
My whirlpool window air conditioner' compressor
Sounds like a bit of refrigerant leaked out and it is freezing up or at least running too cold...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 14, 2011 | Whirlpool Heating & Cooling
Split system turns off after 35 minutes. Vanes close but operation green light blinks four times. By pressing on/off switch on remote - green light stops blinking. Press on/off switch again, system starts...
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Jan 19, 2011 | Heating & Cooling
2004 Chevolet Silverado blows hot air and snowflake button blinks when pressed
Blinking or chattering of the compressor clutch usually indicates low "freon" charge.
Jul 09, 2009 | 2004 Chevrolet Silverado 2500HD
Toyota celica, air conditioner will not work, evac done and recharged, nothing, changed out low pressure switch and still nothing. switch on dash blinks when you press it, compressor tries to come but cuts...
Weird, usually the pressure cut out switch, if you manually "bridge" this (only briefly say 4 secs) the a/c should work, sometimes a plugged/blocked condensor or evaparator will cause this . Also look at engine related temp switches, example water, as these are designed to overide and turn off the ac if the car gets too hot etc.
1)Bridge switch
2) ? oil level in compressor (seized??)
3) temp switches,
4)double check that the system is not blocked, coz if it is then the compressor will only go briefly and then stop due to "overpressure"
Jun 16, 2009 | 2001 Toyota Celica
Whirlpool dryer mod#len2000k01 press tha start nothing happens
First thing Is the circuit breaker, then the door switch.
Apr 07, 2009 | Whirlpool Dryers
Where is the low pressure switch for my Honda Odyssey 2003 AC ?
The A/C pressure switch is located in the high pressure line (the skinny one) on the passenger side of the engine compartment just under the fuse/relay box. The switch has three functions: <28 psi, the switch opens to protect the compressor from lack of lubrication. >220 psi, the switch shifts the radiator and compressor fan to high speed. >455 psi, the switch opens to protect the compressor seals. Check to see if you have any powertrain DTC's first. A faulty engine coolant temp sensor can cause problems with the compressor clutch relay. If the radiator and compressor fan come on with the A/C on but the compressor clutch does not operate, check the compressor clutch relay. You can also obtain Heater control panel diagnostic trouble codes (DTC's) by turning the ignition switch on. Then turn fan switch off. Press recirc button to select recirc air. Press and hold recirc to turn off recirc air but this time continue to hold the button down until recirc light comes on for two seconds and then goes off. If there is any trouble, the recirc light will then blink a code (if no trouble, the light will remain off) 1 blink = problem in air mix control motor circuit. 2 blinks = a problem in mode control motor circuit. 3 blinks = a problem in evaporator temperature sensor circuit. (this one could be a factor in your case) Turn the ignition switch off to end the test.
Mar 16, 2009 | 2003 Honda Odyssey
Heating & Cooling Logo
98 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
