SOURCE: sending message fails
Guyz i have got the solution, just update your firmware of Nokia 5800 XpressMusic to the latest version by connecting your phone to PC with data cable (PC Suite must be installed on your PC from the CD you have got in your Nokia box)
Simply run Nokia Software Updater and let it do its work. after completing update just restart your phone and try to send SMS.
I have solved my problem this way. Hay SOX thanx a lot for your kind concern BTW.
SOURCE: E71 cellphone cannot send message but can receive
make sure your phone center is on the right are and u can send it
SOURCE: My mobile will not send
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
SOURCE: hi my nokia e71 can receive messages but when i go
did u get any help with this i have the same problem
SOURCE: nokia 6120 unable to send message says resend then
hi, i cant send text messages. whaen i send it it always resend and when i resend it it becomes failed. and when i click the details it says that General memory full close some applications and try again later..
What can i do ?
