Maytag Neptune FAV6800AW Top Load Washer Logo
Posted on Oct 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag neptune 9800 tl is leaking from above the clutch assembly and very loud during spin cycle
Anonymous
Level 3:
  • Master 526 Answers
  • Posted on Oct 13, 2010
Anonymous
Master
Level 3:
Answers
526
Questions
0
Helped
142991
Points
1214
More than likely a tub seal issue which is a big job but you can DIY if you can deal with the down time.
See this post.
Outer Bearing Tub Replacement 1.
http://www.fixya.com/support/t3961902-maytag_neptune_bearing_noise
I have relaced the Tub Seal, Tranny O-ring in my FAV6800A Series 10 (first two digits of you machines S/N on the back of the console).......Rich
Model fav6800aww drains during the wash and rinse cycle but does not drain during the spin cycle. it give an dc code during the spin cycle which i know that means unbalance but what does that have to do...
Clutch issue and possible time for a tub seal replacement
Google this for a post that covers the Clutch removal and inspection/repair;
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Google this for Outer Tub bearing rebuild;""
FAV6800A/FAV9800A Outer Tub bearing replacement""
1helpful
My Maytag will not run a complete cycle. Is there
mgissy
What is your machine model number? Is it a FAV6800A or FAV9800A TL?
If it’s a FAV6800A or FAV9800A TL do you error out in the Spin cycle of the wash cycle with an unbalance error code such as dC or uC? Is the wsh tub banging around during Spin Cycle of the Wash Cycle?
If so see this post Clutch Fix. I have a step by step maintenance/repair process for Clutch Pulley assembly issues related to the above error codes.
Post back if you have questions or concerns………Rich
1helpful
Won't advance
richard_f777
2answers
Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
1helpful
Maytag Neptune Tl washer
Mike, Sorry to hear that, is there any water around the clutch pulley?  With the front panel removed and you put the washer in a Spin Only cycle with no clothes in the wash basket.  View the Clutch pulley turning CCW and see if is turning true with no wobble? Mine spun off twice before I got it seated properly, and it was in wobble mode until I got it seated properly.   With the water leak issue maybe you can view with the front panel off and a partial fill the leak source. You can always do a quick tub pump out in service mode. As you know unplug the 120VAC to the machine before you poke around in there.  Do you still have the original clutch?  Did you remove the plastic cover and inspect the roller bearings, clutch spring and coupler? Good luck and let’s see what you find. Rich
5helpful
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
1helpful
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Replace the clutch.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
