Question about Navman GPS
Just getting the battery logo appear when the unit is turned on
I held down the the middle toggle button and turned the unit on and it came up with a menu and I managed to navigate to a reboot to factory setting (this was on a navamn F50
Posted on Jun 02, 2008
Garmin 1450 LMT Not loading past Garmin logo
The USB will not be recognized until the unit boots to the main screen. This is where the subroutine scans for the insertion of the USB cable. In order to fix this problem, you have to access the flash drive directly, bypassing the standard boot-up. The drive must be properly formatted, otherwise the Nuvi can not write to the flash drive on boot-up and will either go into a boot-up loop or stay stuck at the Garmin logo. Accessing the flash drive must be accomplished in pre-boot mode. there are several programs out there that can do this. Once the drive is properly formatted, the unit will boot, create the Garmin folder, write a few other folders and files and boot-to the main menu. Now, you can connect the cable as usual and start copying over your backed up files. I've repaired this issue many times.
More info can be found here:
http://www.sharc.net/gps_bootup_repair.htm
Aug 29, 2013 | Garmin GPS
My gps 40lm is froze. I can turn it on and off but all I can get is the Garmin logo. Is there a way to fix it?
I've now had two of these devices fail in exactly this way. It appears that this model is unreliable. Call Garmin and get them to send you another GPS unit--preferably not another 40LM, as that will probably just fail again.
Nov 05, 2012 | Garmin Nuvi 40Lm - Gps Receiver
I HAVE AN 880 AND ALL I GET IS THE GARMIN LOGO, WITH OR WITHOUT THE BATTERY.
Your Unit shout have a Reset on the bottom of the GPS. Use a paper clip and press into rest hole with the Unit turned on. It will now shut off, restart the Unit. Usually this will help the freeze at Logo problem. Good Luck!!
Jun 25, 2011 | Garmin GPS
Screen Acts likes its locked
Question: My nuvi 850, 855, 860, 865, 880, or 885 is freezing up or will not boot up past the Loading Maps screen.....
Answer: If your nuvi 850, 855, 860, 865, 880, or 885 is experiencing any of the following symptoms:
  • The touch screen is no longer responsive and the unit appears to be locked up
  • The unit will turn on however freeze at the point where it indicates that it is Loading Maps...
  • The unit takes five minutes or longer to be recognized by your computer as a mass storage device
A software update is now available for you to update your nuvi to correct these issues. Please use our WebUpdater program to install this update.
Please note: Due to this problem, it may take up to five minutes before your computer will recognize your nuvi as a mass storage device. This software update will correct this issue as well. //changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 12/21/2009
Feb 07, 2010 | Garmin nuvi 885T GPS Receiver
We want to reset the clock from am to pm or start beginning questions all over again.
1. Turn on the TomTom unit. 2. Tap the screen to bring up the menu. 3. Tap the "Change Preferences" icon 4. Keep hitting the arrow to go to the next page. Clock setting is on page 6 of the preferences dialog. 5. If the Set Clock option is greyed out, you will need to perform a system reset and then perform these steps over again.
To reset the system, start with the power off. Then, hold down the power button for about 15 seconds, until you see the TomTom logo appear on the display. When the logo appears, release the power button. After this reset, you should be able to turn the unit back on and proceed with your setup from scratch.
Nov 27, 2009 | Tomtom XL 340S Car GPS Receiver
Lately, my nuvi will not turn on, it starts up and you see the Garmin logo, then it goes dark and starts up again until the Garmin logo, then it goes dark...over and over...that's it. Can you help?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
If the battery is bad it must be sent in replacement.
Nov 11, 2009 | Garmin n?vi 260W GPS
My Garmin c340 has won't turn on, screen is completly dark unit is charged
I has the same problem with a streetpilot 540.. It wouldn't turn on, even once charged. There was no reset button under the serial number. However, prise off the grey plastic square plate on the front panel which goes around the screen. ( there's even a little space for your fingernail under the Garmin logo). The reset button is under that plate. Press that with a screwdriver then turn on. My unit turned on once reset.
Aug 10, 2009 | Garmin StreetPilot c340 GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Unit shuts off
I assume this message is when operating from the internal battery alone, correct? It could be that the unit is confused about the power source status... yes, electronics sometimes get confused too.
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jun 30, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
