Question about Lexmark X1270 All-In-One InkJet Printer
Need to install on Vista
Have had some problems so i uninstalled program now i need to reistall program on sytem which runs vista need help
    Genius:
  • 3,587 Answers
Uninstall Vista
you cannot uninstall vista from control panel.
Aug 15, 2008 | Computers & Internet
Dear Sir, I removed WinDVD 9 from my notebook. The Windows installer is running there. I can't install any software and even can't turn off my machine. Then I tried to install WinVD 9 again. After a...
Yes it is possible to change from WinXP pro to Vista Ultimate, you will need to get a Genuine Vista Product and then follow the instructions, you will need to first remove all the programs or data you need so you can format the Laptop and then its clean and ready for something new. About the WinDVD 9 and other related errors am guessing you never used uninstaller (Recommended Uninstaller), there are programs meant to wipe clean your machine leaving no part behind if you are to uninstall a program, because if its an incomplete uninstall your machine will have problems as the registry will be messed up and corrupted leading to other fatal problems. After such incidences you will need a registry cleaner (Recommended Registry Repair Pro) to clean the mess and enable fixing all the problems you machine is facing because other means would be more technical.
Apr 13, 2011 | Sony Computers & Internet
Fixing ntdll.dll in vista
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
If the ntdll.dll error only displays when you use a specific software program,
uninstall the program, reboot your computer, and then install the latest version again from scratch.
until you know what the problem is you cant fix it or you might try
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Dec 18, 2010 | Computers & Internet
I need to have my lexmark printer serisx1150 soft ware updated from windows xp to windows vista
Hello. Before installing the driver for Vista, you need to uninstall the XP driver first by going to Start Menu > All Programs/ Programs > Lexmark Series folder > Uninstall. Restart the computer. Also, check if your computer is running on 32-bit or 64-bit operating system by going to Start Menu > right click on Computer > Properties. You can download the Vista driver on this link: http://bit.ly/bmvu8D . Click on the Microsoft dropdown found below the page. Choose Windows Vista for 32-bit or Windows Vista x64 for 64-bit. Download and install the software. Hope this helps.
Mar 25, 2010 | Lexmark X1150 All-In-One InkJet Printer
Ever since upgrading to Internet Explorer 8, I find that I cannot print emails, open up many attachments, and retrieve other information. For example, if I click on a link, I get the following message:...
Ther are known conflicts with Vista and IE8 - particularly with Vista 64-bit.
I would suggest uninstalling IE8 and reinstalling IE7 or using an alternative browser such as "slimbrowser" (excellent program) or similar.
IE8 can be uninstall by using Add or Remove Programs module in Windows XP, but in Windows Vista, Windows Internet Explorer 8 is not considered to be a ‘program’. Instead, IE8 is categorizing as an ‘update’. Thus, users will not be able to find Windows Internet Explorer 8 in “Programs and Features” of Windows Vista.
To uninstall Internet Explorer 8, go to Control Panel, and click on Uninstall Programs link or Programs and Features icon. Then on Tasks pane on the left, click on View installed updates link. Locate and select Windows Internet Explorer 8 in the list of installed updates, and then click on Uninstall button. Click on Yes when asked that are you sure want to uninstall the update.
If there is no option of IE8 been found on “Programs and Features” or “Add or Remove Programs” dialog box, or uninstallation of Internet Explorer 8 is unclean (causing error message such as setup cannot continue because a more recent version of Internet Explorer has been detected on this computer when trying to downgrade to IE7), try to manually run the spuninst.exe.
To do so, go to C:\WINDOWS\ie8\spuninst\ folder (your drive letter may be different), and run spuninst.exe.
Restart the computer after uninstallation completed.
Hope that helps :)
Nov 09, 2009 | Dell Studio XPS 435 PC Desktop
Java won't load on my computer
id suggest that you uninstall java and delete the folder from the hard drive after you uninstall it from the computer, and then clean the registry of any instances of old keys associated to java,then redownload and reinstall java fresh,be sure its the right version for your Vista ( home,Bussniess) Hope this Helps Steve
Oct 01, 2009 | Computers & Internet
Photodeluxe 2.0 does not open with vista, Why?
Uninstall it. Click "Start". Click "Help and Support". Search for 'compatibility wizard'. Run this Wizard. Tell Vista that you willing be installing an 'XP' application, and point to the 'setup.exe' on the CD-disk. Re-install the software. Now, whenever you try to run it, Vista will "trick" the program into believing that it is running on XP, not Vista.
Jun 08, 2009 | Microsoft Windows Vista Ultimate Edition
I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Sep 02, 2008 | Computers & Internet
Lexmark X1270 All-In-One InkJet Printer Logo
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
