Why does my Sony 32' Bravia have a red light flashing seven times, and cannot be switched on. This is an intermittent problem (ie after a few days, the tv can be switched on until it fails again).
    Problem Solver:
  • 15 Answers
You have off your tv via remote and then the electric power has gone so please press the onbutton on the remote continuously or off the tv set and then on it i think it should on permanently
Posted on Oct 13, 2010
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Sony bravia 32ex400 5 time red light blink
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 25, 2014 | Sony Bravia Klv-32ex400 Multi-system Full...
B+ Over Voltage Protection problem Sony Bravia KDL 32S2000
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
4 red standby flashes!!! Need help!!!!
There are a few things to ponder here...probably the high voltage inverter power board is shutting down due to excess power drawn from CCFL(cold cathode fluorescent lamps) . This will happen eventually as a carbon track starts to grow down the tube drawing more current . There has to be a lot of hours for this to happen .
Sony was not free from the bad capacitor affliction...an ESR tester is not an expensive investment unless you only use it once but it can find bad caps that are not showing signs of ***** ie:leakage ,swelling.
failing ballast transformers would be replaced by new inverter board . This would be a last resort without schematic and instrumentation to get hard data to find culprit .
The CCFL tubes can be replaced and may be worth the time and effort with sweat equity . At approx 40.00 usd for 10 you would have to decide for a mere 32 inch LCD TV .
I would spend the money to get an LED TV and get longer service life and possibly better features ie: smart TV
Hugh
Feb 28, 2017 | Sony Bravia KDL-32V4000 32 in. LCD TV
My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Oct 09, 2009 | Sony Bravia KDL-26S3000 Television
There was a power outage and when the power came back on, my t.v. no longer worked. When I try to turn it on, the red timer/pic off light is flashing intermittently. It is a 32" Bravia.
I bet you $120.00 you did not have a 1000VA UPS on it. If I was right, you can pay me now, and I can send you one.
You need a new TV.....or it will cost you $150.00 to fix.
The thinner they are the faster they blow...by the way they have a computer in there.
www.storminprotection.com
Sep 07, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
