Question about Canon imagePROGRAF IPF710 Printer
HARDWARE ERROR 03130031-2F16 - Canon imagePROGRAF IPF710 Printer
Mist Fan Error (two large fans on rear of machine) - on ipf8300 looks to be mainboard problem: have replaced fans, initialised and reset counters. Nothing. Hopefully warranty will kick in. Have two out of 5 that have been affected thus far. Nice one Canon.
Posted on Jan 24, 2013
SOURCE: Error code 03130031-2F13
lol,, see this
Posted on Dec 11, 2009
  • 79 Answers
SOURCE: Cannon ipf710 - Hardware Error 03130031-4027
this code has to do with the carriage lifting position.
You have to check (on the right side of the machine) if a foreign object (paper) is blocking the carriage.
Then Check the encoder wheel and the encoder sensor.
The last you have to check is the motor that operates the lifting motor.
Posted on Dec 29, 2009
  • 79 Answers
SOURCE: I get an error on Hardware error 03130031-2F26
This is a carriage move error.
Please check visaully if there is any foreign object (like paper) inside the machine that blockes the move of the carriage.
Posted on Jan 04, 2010
canontech
  • 1219 Answers
SOURCE: WE HAVE A IPF 700 AND IT PRINTS FOR 10 SECOND AND
I cant find that error code. If you want I can send you service manual. emma.servis@gmail.com
Posted on Jul 01, 2010
SOURCE: Canon Hardware Error 03130031-2F26
HI All,
Had this 03130031-2F26 problem on ipf8000, as well as:
03130031-2F13
03130031-4027
Carriage would stop suddenly with one of these three errors, sometimes would start up correctly, but could not print much at all and when it did it was blurry and would 'stagger' the print.
I am not an expert, but neither are Canon service agents apparently(!) so I stripped the machine down and had a poke around - it was a broken ribbon cable from carriage/printheads to mainboard. Break (on top ribbon cable) was just before ribbons are glued to enter inside machine (furthest point from carriage). Must be a stress point there.
Can I have $250/hr now??
Posted on May 21, 2011
Cd drive code 39
What the Code 39 Error Is
CD-ROM/DVD Drive Cannot Start. (Code 39)
Code 39 is an error specific to the device manager. It is directly associated to drivers and errors that have occurred within them. Drivers are the small pieces of software that your hardware devices use to function. Each hardware device has it's own unique driver, developed by the hardware manufacturer, that contains the instructions allowing the hardware device to cooperate with other hardware devices and communicate with the operating system. Drivers are essential to the normal operation of any computer as they bridge the gap between hardware software.
Code 39 errors are amongst a wide array of device manager errors that all point to the same problem: the driver. It is not uncommon for drivers to become corrupted and produce errors during normal operation. Drivers are accessed constantly for every operation that a hardware device performs. Because of this, there are thousands of opportunities for errors during a single session of Windows. Because of this high rate of failure opportunity, many users have experienced Code 39 errors as well as many other device manager errors.
manually fixing Code 39 errors. Updating to the most current driver will replace the corrupted file with a new, better driver. Updating the driver will not only correct Code 39 errors but it will also introduce greater speed, performance, stability and compatibility. Driver updates are changes that the developer made to the original driver in the interest of all-round improvement. Driver updates often correct many other errors that are related to device incompatibitlity.To learn how to fix Code 39 errors manually, read this guide. The guide will provide steps for manually finding, downloading and installing the most current driver avaiable for your hardware devices. However, it is generally MUCH easier, safer and more reliable to use an automated tool. We've discussed using an automated tool to fix Code 39 errors below.
DriverUpdate.DriverUpdate is an easy-to-use tool that scans your unique hardware configuration for any device driver problems. Drivers that are out of date, missing, misconfigured or corrupt can easily be re-installed automatically by the program. The benefits of this program are endless. Most users not only have error messages fixed, but also will see a performance improvement since all of their system drivers can be updated! ( click here to download DriverUpdate ) RECOMMENDED
Feb 23, 2012 | Dell Dimension E310 PC Desktop
Error code 6500
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you better ask for replacement.
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much a user can do except replacing the malfunctioning hardware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
My canon mp830 printer is saying error 6500 and i cannot get it to do anything, i have un plugged and re plugged and nothing. what does this error code mean?
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you can ask for replacement
Abhilash
$7 is the charge for the service provided.
Oct 01, 2010 | Canon MP830 All-In-One Printer
Error 6500
The service error 6500 refers to "other hardware error”. This error results from printer hardware failure & nothing much can user do instead of replacing the malfuctioning hardware.
Mar 01, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
When I reload my F5 5100 I get the following message "hard error: sector 1019072 status 51 error 14: bad format"
Hello my friend, it refers to your hardware components. The error is on your hardware system it causes either the hardware itself where it has a error in the area of SECTOR 1019072 where its status is bad format or its the format of one of your system inside your hardware.
Thanks
Jul 30, 2009 | F5 Networking (f5-big-5110) 24x10/100 Mbps...
Wont read/write hard drive
use Apple Hardware Test to diagnose the error::
1 Disconnect all external devices from your computer except the power adapter.
If you have an Ethernet cable connected, disconnect it.
2 Insert the Mac OS X Install Disc 1 that came with your computer.
3 Restart your computer and hold down the Option key as it starts up. A list of available
startup volumes appears. Click Apple Hardware Test and click the right arrow.
4 When the Apple Hardware Test main screen appears after about 45 seconds, follow the
onscreen instructions.
5 If Apple Hardware Test detects a problem, it displays an error code. Make a note of the
error code before pursuing support options. If Apple Hardware Test does not detect a
hardware failure, the problem may be software related.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 18, 2009 | Apple PowerBook G4 Mac Notebook
I'm am trying to play age of mythology and after the movie ends, error appears and states "initialization failed".
Initialization failed
This means that the game is attempting to initialize hardware such as the video card but has failed
This can be caused by a number of factors.
1. Your hardware does not meet the games hardware requirements
2. Your hardware requires farther configuration to run the game properly
if you are certan that the game supports your hardware you may need to perform
some extra steps to get your game working
"Failed to initialize" is an incomplete error message because it does not tell you what exactly failed
a more complete error message would read "Failed to initialize the video subsystem" and then it would give an error code such as Error Code xxx telling you exactly what error code to look up
to determine what exactly failed.
Most of the time when a game says ( failed to initialize ) that means a video issue
this may mean missing files or wrong versions of files or incompatable hardware.
Selah.
Sep 15, 2008 | Computers & Internet
Canon imagePROGRAF IPF710 Printer Logo
1,610 people viewed this question
old marine
old marine
