Question about Samsung Bn59-00673a Remote Control
Why the enter button on my remote didn't work? for samsung model Bn59-00673a
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
Jan 31, 2016 | Televison & Video
I bought a used samsung tv model lnr32r5hdx/xaa and it didn't come with a remote, the controls on the tv do not respond except the power button. I have been reading about some shop mode and I have has...
Changing modes and resetting on tv internal video setting must resquire the tv original tv remote Try website like Remotes.com to buy the tv original remote.
Jul 03, 2011 | Samsung Televison & Video
My dish network remote isnt working with my Sony Bravia LCD model KDL-40S5100
You didn't mention the model of the Dish receiver, so here are some common Sony codes. To reprogram the remote, press and hold the "TV" button on the remote until it stays lit. Enter one of the following codes and press "#". Check all of the functions. 500,640,652,756,758,781,783,795,796,797,798,806,807,837,844,845.
Apr 19, 2011 | Televison & Video
My sky remote has stopped working on my samsung tv
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
Feb 16, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Sky remote tune to samsung
3. Press tv again
Samsung Code: 0060
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Making my SIR-T451 remote work with my Zenith TV.
Push the Set button and enter the following codes and enter one of theese codes: 018, 020, 193. If one doesn't work try the next one. You have to push set each time you enter a new code.
Jan 11, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
REMOTE CONTROL UNIT DOES NOT WORK
you need to enter the 3 digit code in the manual
hold the set and tv buttons, then enter the code and it should work
Nov 03, 2007 | Samsung TXN2730F 27" TV
Samsung Bn59-00673a Remote Control Logo
Jerry Greenberg
Jerry Greenberg
