Question about Roper RS25AEXLQ Side by Side Refrigerator
Fridge does not get cokld at max setting. - Roper RS25AEXLQ Side by Side Refrigerator
    Problem Solver:
  • 15 Answers
Please clean the fridge thoroughly and set the hemostat on 07 stetting it should be go to its maxium cooling or contact the service technician for its recharging the refrigerant again.
Posted on Oct 13, 2010
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
Fridge not cold enough
You should check that the condenser area is clean you can blow it out with a blower or vacuum cleaner, also be sure that the condenser fanmotor is working
Nov 06, 2009 | Refrigerators
Kitchenaid Superba Side by side, refrigerator side not cooling
Assuming that your fridge is set at max thermostat setting, and still it cools to 8 degrees only. It only mean
one thing, and that is have your refrigerant level check,
and have it loaded. E-mail to us your comments.
Oct 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer and fridge are getting warmer and warmer despite their settingsGE Profie PDS 20 MFS 2005
ONE OF THE MOST COMMON CAUSES FOR A SERVICE CALL IS EXACTLY WHAT YOU STATE, THE MAX SETTINGS ARE SET AND STILL ITS NOT GETTING COOLER, ESPECIALLY IN FRIDGE SECTION RIGHT?
IF YOU ARE MAKING ICE THATS DRY THE FREEZER IS OK,
THE PROBLEM 90% OF THE TIME IS THIS
AS THE FRIDGE SECTION IS RELIANT 100% UPON THE COLD AIR MIGRATING INTO THE FRIDGE COMPARTMENT VIA A LITTLE FLAPPER DOOR THAT OPENS OR CLOSES OR IN BETWEEN AS WELL , THUS ALLOWING MORE OR LESS AIR TO MIGRATE INTO THE REFRIGERATOR SIDE FROM THE FREEZER SIDE
THE STUPIDEST THING IS THE FRIDGE SAYS MAX COLD ON BOTH SETTINGS, ONE ACTUALLY CONTROLS THE COMPRESSOR AND DETERMINES HOW LONG THE COMPRESSOR WILL RUN IT USUALLY IS OFF AND 1-10 , THE ONE THAT TURNS OFF THE COMPRESSOR ISNT THE ONE THAT DETERMINES THE REFRIGERATORS TEMP! THE OTHER SETTING FOR COLDER FREEZER DOES!!!! TAKE THAT SETTING BACK OFF OF MAX FOR COLDER FREEZER AND THE LITTLE FLAPPER WILL OPEN ALL THE WAY , WHEN SET FOR MAX COLD THE FRIDGE SIDE STARVES!, ANY SETTING 1-10 SHOULD STILL KEEP THE FREEZER FREEZING AND MAKING ICE IS THE KEY! IF IT CAN THEN ITS NOT A REFRIGERATION PROBLEM , IT IS A CIRCULATION ISSUE
Aug 23, 2009 | GE Refrigerators
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Jan 13, 2009 | Refrigerators
Fridge works only on the max setting
needs a defrost heater, keeps it from freezing up. my friends did the same thing, she changed defrost heater and works fine now.
Oct 29, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Roper RS25AEXLQ Side by Side Refrigerator Logo
35 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
