Question about Maytag Neptune MAH7500WH Front Load Washer
Machine is leaking detergent
I just noticed that the machine is leaking detergent on to the floor. Seems to be coming from underneath the machine, as opposed to something wrong in the dispenser area. Thanks for any suggestions.
  • 25 Answers
Check inner gasket for small hole
u can take front off by removing screws from around inside door frame (including hinge screws) the panel will pull out towards u then u might be able to c where its leaking better
Posted on Jul 09, 2008
GE Potscrubber,Quiet Power dishwasher leaks while running
Check to see if the door baffles are intact they are little black rubber things in the front on each side of the tub. the pump seal could be leaking underneath. the wrong detergent (dishwashing detergent) could have been used.
Oct 08, 2014 | Dishwashers
Water seems to be leaking from the bottom of my Maytag washing machine. Machine set for a large load. Water stopped, I added the detergent and then the soiled laundry. I went to get other laundry I had...
unplug washer. pull washer to you, have someone tilt the washer back and get a flash light and look for water spots on water pump,your drain hose,could be aclanp or just a hose we hope.
Sep 17, 2011 | Washing Machines
Hoover oph 614 on the front at the bottom ther is a filter i took that out and then screwed it back in today did my washing and there was water all over the garage floor. i noticed the seems to be coming...
Had the same problem today. Found a very small piece of lint/fluff in the sealing groove of the filter socket. Removed this with an orange stick & touch wood the floor is dry again.
Do hope this helps
Oct 26, 2010 | Hoover AAA160 Front Load Washer
Washing Machine Emptying
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
May 27, 2009 | Washing Machines
Water and soap under washing machine
Plug off the mains power on wall. It could simply be that one of your hoses has become loose or has a tear. You have to examine this from wherever you get a good view. Then remove or refix, you need a grip clip plier if you cannot manage with an ordinary pair of pliers.
Sites for spares: (which is good)
You can rate me.....a way of saying thk'u. Note: Stay off the professionals - they are only after your wallet $$ !!!
Mar 10, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
The only time I've noticed a puddle on the floor was when I used too much HE detergent. No matter how big the load is, I only fill the cup to the very first line of the cup that comes with the detergent. It's no where near the max level on the detergent reservoir for the machine. Try using less detergent (way less) and see if that fixes the problem. My clothes still get squeaky clean!
Nov 09, 2008 | LG WM2277H Front Load Washer
LG washer leaking problem
You may be using too much detergent.  Use only 2 tablespoons of detergent in your wash.  Using too much will oversud the machine causing the suds to go out the back vent and on to the floor giving the sense of a leak.
On the dispenser, make sure that the containers are clean and free of any debris.
Jul 16, 2008 | LG WM1814CW Front Load Washer
Washer leaks small amount. DIY fix: check hoses and ???
Wires found in hose!
When we turned washer on it's side, we found the hose from the pump to the basket had been pierced by two stiff curved wires, still embedded in the hose. Water was leaking around the wires. Wires had come out of an underwire bra! Dealer had only heard of this once before; on his own washer!
MORAL: handwash your bras, ladies.... or pull those wires out each time.
Apr 12, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Not getting clothes clean anymore
Have you moved or has where your water treatment facility changed? Changes in the hardness of the water can cause detergents not to react well. A hard water test is easily picked up at the hardware store. I had a similar problem changing from well water to public system.
Nov 05, 2007 | Washing Machines
Water leaking from wash machine
It is probably a seal that is on or near the bottom of the tub. Dirt and grim wears at this seal over time. The leak is slow so it is hard to visually see.
Dec 09, 2006 | Frigidaire MWS939Z Top Load Washer
Maytag Neptune MAH7500WH Front Load Washer Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
