Question about LG DLE2532W Electric Dryer
LG Electric dryer keeps blowing thermostat, vent is OK
I have a DLE2532W dryer that has blown the thermostat several times. The same repairman has come out several times to fix it. He tells me the only reason it's blowing is because of a bad vent. But he also said there is nothing wrong with the vent. He said he called the factory and they said it has to be the vent.
The vent is less that 18" long and vents to the outside with just one 90 degree turn. The unit has worked for 5 years with a long, winding flex tube connected to the vent. There was never any lint to speak of in any part of the vent. There is no obstruction or anything outside when the vent exits. The vent flap is very loose and opens easily and doesn't even close fully. And the air flow out the vent seems very significant.
I went ahead and replaced the flex tube with a very short, stiffer tube that had just two 45 degree turns - the vent on the dryer is about 8" to the right of the vent opening on the wall. This new tube was only about 1 foot long after installed.
With a new thermostat, the unit works fine for several weeks. I'm not sure what causes it to fail - nothing seems different when it does fail. One time it might have been because we ran several loads through it in a row, but that doesn't always make it fail.
I did remove the vent tube completely, and that did seem to work. But I really can't keep running it that way.
It seems to me that something else is wrong with the unit, and when it heats up just a little more than normal the thermostat blows.
I looked at the parts list, and I noticed that there are two thermostat assys, but only the smaller one is ever replaced. Should I replace them both this time ?
Unfortunately, the repairman is unable to fix my unit and will not back up his work because he says its the vent. But he won't tell me what to do to the vent to fix it.
This is very frustrating. Anyone have any suggestions?
  • WhaDL Jun 01, 2008
    IB4G2008:
    Thanks for the suggestion on an extra fan.
    But note that I didn't replace the twisty hose until the fuse blew the second time. Shouldn't that have still worked ?
    Anyway, I'll certainly try out the extra fan, although I'm not sure how I'd get it in there.
    How can I send you my number without it appearing on the forum ?
    Thanks
    Tom
  • WhaDL Jun 29, 2008
    Well, I went ahead and replaced both thermostats this time. The dryer has been working fine for about a month now. Seems to have done the trick. Interesting that LG doesn't seem to know about this...
    Scholar:
  • 198 Answers
It looks lik replacing the other thermostat wil help you.
where is the repairmen comin from. is he not a certified person.
Posted on Jun 01, 2008
    Genius:
  • 3,587 Answers
Sure..this is actually a back pressure issue...when you used the twisty flexible hose, there is less reverse back pressure..
so, with the thermal mass from a 90 degree turn, it's most likely causing a heated air back flash, making the thermostat work harder, shortening it's life..
you might want to consider putting an inline fan, past the 90 degree turn(internal to the vent pipe) and let that exhaust the air at that point, instead of allowing thermal convection to be the sole propeller for this setup.
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Jun 01, 2008
    leave a contact number and i'll talk you through this.
  • Patrick Michaels
    thanks for the fixya..now, see my response on the askme posting.
  • Patrick Michaels
    sounds like LG has done it again. making a low cost item, that has a marginal component. And little to no consumer support.
Lg dryer keeps blowing thermal fuses
check you entire vent system and make sure there is a clear airflow all the way to the outside. A simple test is disconnecting the vent hose and letting the air flow into the open room. If works OK, you definitely have an airflow problem.
Jan 31, 2015 | LG DLE3777 Electric Dryer
Not drying no heat...checked the breakers and everything OK, what should we do next?
check the exhaust vent tubing first
If lint has a build up the moister sensor will keep the heat at check
Jun 07, 2010 | LG DLE2532W Electric Dryer
My LG dryer takes two cycles to dry the clothes
check the dryer vent to make sure it is clear. is there any heat, if not the thermostat or heating coil burned out.
Dec 06, 2009 | LG DLE2532W Electric Dryer
I have an LG DLE2532W dryer and it takes hours to
the vent pipe is probably full of lint. pull the dryer away from the wall, disconnect the vent pipe and look inside the rear of the dryer and thru the vent pipe. remove any lint u find as it is a fire hazard.
Apr 21, 2009 | LG DLE2532W Electric Dryer
LG DLE2532W NO HEAT
Sounds like the heater element is bad that is the main cause for them not to heat up . Their should be a cover on the back that comes off and you can get to the heater element after removing it .
Feb 23, 2009 | LG DLE2532W Electric Dryer
DLE2532W Not heating
ask for old the fuse ,,lg have resettable thermostat...keep me posted,,its a push botton thermosatat..also they replaced this thermostat with a higher rated one,,,if you need part # just ask onthejob keeps uint from having to be reset...
Jan 18, 2009 | LG DLE2532W Electric Dryer
LG DRYER DLE2532W DISASSEMBLY INSTRUCTIONS
DLE2532W is an electric heat model. (a gas model would be a DLG......) To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Dec 28, 2008 | LG DLG5932W Gas Dryer
Replacing saftey thermostat monthly
Clean dryer vent to improve airflow so dryer will not cycle on high limit thermostat. The best way is to use a cordless drill vent cleaner designed to clean dryer vents. Manual brushes are also available, or you can disassemble, clean, and reassemble vent. (if so, use the foil tape when reassembling) Make sure you are not using flex dryer venting. This should also improve dryer performance, reducing dry time.
Jul 10, 2008 | LG DLE2532W Electric Dryer
Removing LG dryer top plate
If your going to do this..... UNPLUG THE UNIT FIRST OR TURN OFF THE POWER.
You can use a 1" paint scraper, it will do the trick, but get one that is strong.
Why is your thermostat blowing though? Do you have a venting problem that may be causing it?
Sgt 48
May 26, 2008 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
353 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
