Question about LXE MX7
My LXE-MX7 system always hang and response slow. Done swap SD card and reimage but still getting same problem.
HELOW
LXE MX7 ERROR
Posted on Jan 19, 2011
    Problem Solver:
  • 4 Answers
Problem with LXE MX7
Try to check the touchscreen. Sometimes it happens that if the touchscreen surface is broken (or tapped too hard) the cpu of the terminal senses as a continuous tap. This may cause the slowdown of your terminal.
Actions:
Pick up a small piece of adhesive tape and gently try to pullo up the faulty section of the touchscreen. If you want to disable the touchscreen at all type the following in the command prompt:
Ctl CtlTouch=0 (with exactly this syntax, reverse command is
Ctl CtlTouch=1). then erboot and test the terminal. If the situation get better then it's a touchscreen problem.
Posted on Jun 22, 2012
HOW HANNSPREE tablet SN1AT7 (HSG1279) manage its memory?
Computer's speed [whether it be a desktop or laptop, whatever be] depends on many things. Even with the highest core speed computers too can hang, and go with little speed. In your case, it will be best to contact the authorized service center, or any skilled computer technician to resolve this problem.
In most cases, a re-installation of the O/S will resolve the problem. Anyway, contact the authorized service center. It will be best.
Jul 03, 2014 | Hannspree HANNS pad SN10T1
My computer always hangs up wen am using it. whats the problem?
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also it is possible that the back up battery ( CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. Sometimes the memory card connections can be faulty either on the card or on the slot. Cleaning the slot and card must be done before you try a replacement. If the Pc boots and fails then the hard disc can have bad sectors or is corrupt. However if there is no result the motherboard also can be suspected. In this case you might need the help of proper tools and equipment support to do a chip level service.
It is best to go for a paid antivirus software which you can get in a package. Personally we are not recommending any particular company but you can try with Avira, Antivir, AVG, Kaspersky. It is always best to install the antivirus when the installation of the OS is done.
Now before this you can open the internet options in the browser and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date.
You can use a registry cleaner like Advanced system care. Download from the site and check you system for corrupt files. Also use a good antivirus software which is active to keep your system performing without an attack on the OS. Remove all unnecessary programs installed which you do not use all the time and clean up the drives. This will free up the space and make your system faster.
If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
Thank You for using Fixya
Sep 23, 2011 | Computers & Internet
My laptop goes very slow when loading facebook games?
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also it is possible that the memory card is a suspect. In this case you need to and swap a memory card. If not the OS is a suspect.
Sep 17, 2011 | Toshiba Satellite Pro L300-EZ1004X...
What to do if laptop hangs continously?
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also it is possible that the back up( CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. If not the OS is a suspect.
Sep 13, 2011 | Computers & Internet
Samsung r519 laptop running really slow how do i fix this when typing it takes few secnds to display text after i'v e typed
Aug 22, 2011 | Samsung R519-53S Notebook
My hp mini 110-3000 working very slow, what will i do?pls help me..
Aug 19, 2011 | HP Computers & Internet
Blackscreen after boot - probably scanner port
It is system running under Win CE. I got answer direct from producer. The easiest way sounds: Make short connection between pin 6 and pin 7 on COM1. It shows screen again and you can set wrong setting of COM port back. I made it using a small screwdriver. Thanks for your concerning. GreetX. Jesco
Dec 22, 2009 | LXE VX7 Portable Data Collector Terminal -...
Laptop boots , then powers off
Its hard to analyze with all the changes you've made and just a hang...here's a really good service though and you get a trial run. Its called Reimage services and detects problems thru the internet..its been proven to work by techs I know who purposely sabotaged there computers and the product from Reimage picked it up. Maybe it can isolate it for you, its free so nothing to lose..here's the website:
http://www.reimage.com/index.php
Apr 11, 2009 | Acer Aspire 5100 Notebook
LXE MX7 Logo
634 people viewed this question
Top LXE Computers & Internet Experts
David Payne
David Payne
Are you a LXE Computer and Internet Expert? Answer questions, earn points and help others
