The error message says I have a communication problem. The printer is powered on; I have disconnected and connected back the power cord and the USB cord; I have a new USB cord. Any other suggestions? I also have new ink cartridges in it. My printer is an All In One ESP 3
    Problem Solver:
  • 15 Answers
You should change the printer cable that is the usb cable the problem will be solved
Posted on Oct 13, 2010
False paper out message
An 'Out of Paper ' error message displays on the product control panel display, and the product does not pick up or feed paper from the photo tray.
Try to reset the printer:
  • Disconnect the power cord from the electrical outlet.
  • Disconnect the USB or Ethernet cable from the back of the product.
  • Disconnect the power cord from the back of the product.
  • After 30 seconds, connect the power cord to the back of the product.
  • Connect the power cord directly to an electrical wall outlet.
  • Connect the USB or Ethernet cable to the back of the product.
  • Try the print job again.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 16, 2012 | Xante ScreenWriter 4 Laser Printer
Error code 0xc19a0035 hp model b210
1.Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
11. connect the printer directly to the walloutlet
12. Still issue is not resolved then do a reset on the printer : Disconnect the power cord from the back of the product.Wait for 20 seconds, and then press and hold # and 6 on the product Control Panel. Connect the power cord to the back of the product and then release the buttons when the product turns on.The product resets to factory defaults.
13. Issue not resolved then service the product
Oct 12, 2012 | HP Photosmart C7180 All-In-One InkJet...
Printer Problems
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 15, 2012 | Lexmark X5650 AllInOne InkJet Printer
I loaded my Lexmark X6180 printer with the software, and the installation went fine to the finish. But I get a communications error message "cannot communicate." What shall I do to fix?
What is the operating system installed on your computer?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 24, 2011 | Lexmark X6180 Printer
An error message reads printer cannot communicate with this computer. I have checked the firewaall, the installation and it makes copies so its a connection problem
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 19, 2011 | Lexmark X5470 All-In-One InkJet Printer
Error code 0xc004e003 in windows 7 ultimate,wat can ido
Welcome to FixYa!
I assume that this error code is showing in the Display Panel your printer.
Reset your printer.
  1. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
    1. Remove the cartridges from the product.
    2. Wait for the 'Insert Cartridges ' message to display on the control panel.
    3. Disconnect the power cord from the back of the product.
    4. Wait 60 seconds.
    5. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
    6. Reinsert the cartridges, and then close any open doors on the product.
    7. If you receive a prompt to print a calibration page, do so.
    8. Reconnect the USB cable to the rear of the product, and then try printing again.
    I hope this helps.
Thank you for using FixYa!
Jas247
Mar 29, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Carriage error msg
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Oct 09, 2008 | HP Officejet 7310 All-In-One Printer
Carriage Jam Error display on the LCD!
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Aug 23, 2008 | HP Officejet 7310 All-In-One Printer
Error - carriage jam message
Mar 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Carriage jam error message
Nov 06, 2007 | HP PSC 2410 All-In-One InkJet Printer
184 people viewed this question
k24674
