Removing Child Lock
We have a Mitsubishi television which has somehow had the child lock activated.  At the moment we switch on the tv and it switches of again within the space of 3 seconds.  How do we remove/deactivate this.
Mitsubishi "Diva" Model #:- CT33AC2(A)  Serial #:- 33AC20032
  • 2 more comments
  • Kolara Jun 08, 2008
    What is the "eeprom" you mentioned? and how do I reset?
    I'm positive that there is no need to replace anything its simply a code or pressing of some keys simultaneously.  Thanks though
  • farakane Aug 08, 2008
    We have a Sony 14 inch colour television which has somehow had the child lock activated. At the moment we switch on the tv and you cannot press any key/button except on/off button. How do we remove/deactivate this.
  • farakane Aug 09, 2008
    I'm convinced that there is no need to replace eeprom and that its simply a code or pressing of some keys simultaneously when the child lock was activated errorneously. Can you please help me with the keys that needs to be pressed simultaneously to deactivate the child lock problem.
  • farakane May 11, 2010
    How can I either reset the eeprom or replace it.
We have a Sony 14 inch colour television which has somehow had the child lock activated errorneously when we were testing all menu options. At the moment we switch on the tv and you cannot press any key/button except on/off button. How do we remove/deactivate this. How eeprom can be reseted or replaced and where is it located on the television set.
Posted on Aug 09, 2008
You will either have to reset the eeprom or replace it.
kev tech.
Posted on Jun 01, 2008
Door not unlocking Fisher Paykel front loader Wh60f60w. The cycle appears to have completed but the door remains locked well beyond normal lock delay. Is there a manual release?
Have switched this on?
Child-proof lock
? You can protect the appliance from being tampered by activating the child-proof lock.
? When activated, no change can be made to the programme running.
To activate the child-proof lock:
1 Press the 1st and 2nd additional function buttons for 3 seconds.
2 The "C ON" (child lock is activated) symbol appears on the screen.
Note: the child lock symbol will also be displayed whenever any button is pressed while the
machine is child-locked.
3 The child-proof lock lamp on the programme follow-up indicator will light up when the childproof lock is activated.
To deactivate the child-proof lock:
2 The "C OFF" (child-proof lock is deactivated) symbol appears on the screen.
3 The child-proof lock lamp on the programme follow-up indicator will go off when the child-proof
lock is deactivated.
Apr 01, 2017 | Fisher Washing Machines
Megapower. how do I remove the child lock without a remote?
How to reset "Child lock" on TV without remote ' Electronics Forum ...
www.electro-tech-online.com > ... > Repairing Electronics
Apr 8, 2010 - 21 posts - ‎11 authors
I opened the TV, but no "switch" on the PCB to do a "reset to factory". ... You almost certainly need the remote, and also the service manual that .... and I was able to get into the menu by remote and to disable the Child lock.
How to disable child lock on Magnavox 27MS343S without remote - TV ...
www.tv-forums.com/.../How_to_disable_child_lock_on_Magnavox_27...
Sep 23, 2012 - 7 posts - ‎3 authors
Hello, I have accidentally turned on the child lock (not parental lock) on my Magnavox 27MS343S for which I do not have a remote. Since the ... panasonic television child lock
Apr 21, 2012
Apr 8, 2010
More results from www.tv-forums.com
Jan 01, 2016 | Televison & Video
It's a big screen tv and it say locked
I think that somehow the child lock has been activated somehow. Try this -PRESS MENU BUTTON THEN UP / DOWN BUTTON TO SELECT SPECIAL MENU THEN TURN CHILD LOCK OFF
Jan 24, 2013 | Televison & Video
A lock icon has appeared on the screen in the upper right hand corner and i can't watch tv. the lock is a red thing on the blue screen.
it could be the child lock, accidenty activated from remote or tv buttons,...goto steup mode and switch off the child loc, or any lock that your tv indicates is active...if the problem continues, might be the gate ic, inside your tv needs repaced or reprogrammed...the number on that ic is in somthing 240co8......8 legged small ic..change it....or refer to qualified tech..
Oct 25, 2009 | Televison & Video
Youngest son somehow activated setlock
try to switch the tv off by the mains for 1 hour and plug it in again. see it this works.
or
on the remote these is a "child lock" press that.
or
go in the menu and see if there is a "CHILD LOCK" feature you can select
Email me is you need more info on
ruanelectronics@gmail.com
May 11, 2009 | Televison & Video
Sharp VCR VC-AA350 removing child lock
sharp vcr vc-aa350 removing child lock
Nov 01, 2008 | Televison & Video
Child lock
I have mitsubishi television model ct-21ab1 i have a problem child lock how i can pleas help me
Jul 27, 2008 | Hitachi C21-RF80S 21" TV
Forgotten password
Your tv is switched on and locked , blue screen and shows keys. A tv with activated child lock can only be unlocked after an 4-digit code is punched in.
Reset of child lock is as followed :
Determain chassisnumber type on type plate on the back of TV.
example: CUC xxxx ( xxxx = 4 digit number).
TV's CUC 6300, 6301 and 6310: bullet.gif Press cursors (blue arrows ) in sequence : Right, Left, Down , Up, followed by OK
TV's with chassis CUC 2003, 2005, 1805, 1825 t/m 1827, 1842, 1894, 1952, 1962, 1983, 1984, 1806, 1828, 1829, 1830, 1836, 1929, 2020, 2021, 2030, 2031, 2033, 2050, 2058, 2059:
bullet.gif Punch in universal code 7038 in. This code ends the child lock
TV's with Chassis CUC 1832, 1930, 1931:
bullet.gif Punch in universal code 7038580. This code ends the child lock Greetz and good luck, and PLS let me know if it works
Arni
Jun 13, 2008 | Televison & Video
CHILD LOCK ON TELEVISION
Need make and model as they differ
Dec 03, 2007 | Televison & Video
Televison & Video Logo
830 people viewed this question
Top Televison & Video Experts
