Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
We have no problem with the liftmaster model 3280 until now. About couple of weeks ago, when we open our garage door, the light would turn on for a few minutes then shut off. Well, this time, the light did not turn on. And so I thought by just replacing the light bulbs problems will be solved. Unfortunately, after replacing the new light bulbs, the light still did not turn on when we open our garage. We do not hear the sensor click on. In addition, the safety reversing sensor on the left side of the garage is green. However, the sensor on the right in yellow. Could you help?
  • Jim Geuin
    Jim Geuin Dec 06, 2013
    Same issue . . . relay clicks but light does not come on. After a several minute delay, breaking the light beam or operating the door closer the light will come on momentarily, then go off.
5 Suggested Answers
Just_Bobz
  • 448 Answers
SOURCE: Safety sensors
Pull the contact wires off the back of the eyes. If this is found helpful, please post as such. Post as fixya if it gets the desired effect. TY
Posted on Jan 16, 2009
  • 25 Answers
SOURCE: My garage door opener stoped working after a storm.
there is a 2amp fuse inside the opener. go get one and replace it. please look at what kind of fuse it is it's the one that has glass all around and about 1 inch long. to replace this unplug the unit then take the 4 screws out take cover off and you will see the fuse inside
Posted on Jun 20, 2009
  • 52 Answers
SOURCE: Liftmaster 1/2 HP Garage Door opener won't open or Close
The shaft on these garage door motors are not direct drive systems. You'll have to open up the box to see what the actual problem is. I have had stuff like this happen where a gear just slipped out of place.
http://www.aaadooropeners.com/?gclid=CLH3wt628p8CFVZS2goduwSLYQ
Here is a link for a parts supplier. I don't know your model but it looks like most of the Liftmaster worm screw gears and drive gears are plastic so it's possible that one of them has cracked.
Posted on Feb 14, 2010
swolfinor
  • 504 Answers
SOURCE: I have a liftmaster garage door that doesn't work.
YOU COULD TRY
RECONNECT THE RPM SENSOR, UNPLUG THE UNIT. TURN THE MOTOR BY HAND (DOWN DIRRECTION) TO CLEAR THE LIMIT SWITCH.
PLUG THE UNIT IN IF. IT STILL OVERSHOOTS THE LIMIT IT COULD BE A BAD LIMIT SWITCH. IF THE SWITCH TESTS GOOD FOR CONTINUITY REPLACE THE BOARD.
HOPE THIS HELPS
Posted on Jun 05, 2010
I have a Liftmaster Garage door model 3280 and I changed the belt and when I try to open the door it only open about 2 feet from the floor.
Remove the belt and then run the opener until the sprocket on top of the motor runs in the counterclockwise direction and stops. Now with the door in the open position replace the belt. Some adjustments of the up and down limits will be necessary.
Sep 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
I installed a Craftsman garage door a couple of weeks ago and all of a sudden it keeps opening by it's self. It is model #139.53918D what is causing this?
Make sure the door isn't closing too far. This will cause it to open. Your opener comes with a warranty. Call Sears repair.
Sep 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
The range for the remote openers (4) for mu Liftmaster garage door opener has decreased to the point of having to be within 6 feet of the door to open it. The liftmaster was installed 5 yrs ago. The...
There is an antenna extender kit available for your opener. The part number is 41A3504 and should be available from any good door opener company that handles Liftmaster or Chamberlain. It should come with instructions.
Jul 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster 3280 opens by itself occasionally. I have tested springs and they test fine.
Change the codes on the remote and of course the lifter itself, sounds as if some one in the neighborhood has programmed the same codes nearby.
Jan 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have lifemaster with the following specs: PART NO: 41AB050-2 / IC:2666A 102 1499A DATE: 05/06 VOLTS:12V AMP:6.0 Hz:60 H.P:1/2 / MODEL 3280 SERIAL NO: 193614200588 My problem is the...
If the light in one of the door sensors flashes it means the sensors are not pointed at one another. Tweak them until the light stops flashing.
Oct 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
I'm having almost the same exact problem w/ Liftmaster 3280
There is a small glass eye sensor on the garage lifter similar to your TV ( infra red) if this has become dirty with dust etc it will not always receive the signal.Check the manual to see a diagram and trouble shoot page.
Aug 14, 2009 | liftmaster Chamberlain Garage Door Opener...
Mar 10, 2009 | liftmaster Chamberlain Garage Door Opener...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
370 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
