Question about Sanyo Refrigerators
Where does the thermostat go in a frige model sr4910m?
  • ajj351 Jun 06, 2008
    this does not have a freezer
  • 828 Answers
More than likely the capillary tube goes up to the bottom of the freezer compartment and attaches there by means of a mounting bracket.
Posted on Jun 01, 2008
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Tip
Finding Your Model number on Older GE Refrigerator (Frige)
Finding Your Model number on Older GE Refrigerator <br /> <br /> If it is a side by side look in the frige side on the side walls near the bottom. <br /> <br /> Also check the bottom right side of the frige between the door and the base.
on Mar 23, 2011 | Refrigerators
Tip
If your refrigerator will not cool but freezer works good
alot of times if your frige is not cooling but the freezer works good most of the time all you need to do is defrost the whole frige for atleast 3 hours if that dont do the trick you may have to replace your thermostat timer that is connected to the dial in top section of the refrigerator sometimes it is turned up to high
on Mar 01, 2010 | Refrigerators
Freezer works fine but frige side not getting cold enough-side by side unit
Check rear wall of freezer to see if you can feel frost about halfway down. If so you likely have a defrost system problem. Three components involved in defrost system, Heater, defrost thermostat and defrost timer or Defrost control (circuit board).
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model and brand is always helpful when requesting information.
Aug 22, 2009 | Kenmore Refrigerators
Refrigerator not defrosting.changed out the control board, thermostat,heating element,and still icing up.
if you replaced the bord on the back of the unit did you replace the 2 thermisters and bottem left back of freezzr loks like a white bullet frige therem is located in left top back of frige under the damper
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Kitchenaid KBFA25ERSS01 freezer suddenly does not stay at 0 degrees. Fluctuates between 2 degrees and 12 degrees.
Sounds to me like you could have some serious problems. What you're seeing could be either the result of faulty electronics (i.e. the thermostat) or an even larger problem with the refrigeration system itself.
About the only thing that I could think of that could be repaired by the user would be the door seals if those are leaking. Anything more intensive than that though and your best bet is to contact a service person.
Jul 29, 2009 | KitchenAid Refrigerators
Frige freezing solid
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Maytag Fridge MTB2156GEW Won't cool. Change thermostat today and ran it for four hours. Frige was warm after. There is a clicking noise every 2 to 5 minutes from the back of the fridge. I think it is
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
May 20, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Light on no fan
it sounds as though the thermostat is faulty not bringing the compressor on and the defrost timer is turning the fan off and on as it should do
May 02, 2009 | GALAXY Microsystems 63702 Top Freezer...
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
Refrigerators Logo
60 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
