I have my sharp washing machine the dryer is not working and turning i check the motor but i dndnt see some burn wire
    Problem Solver:
  • 15 Answers
You please see it in detail the rated fuse that were usually installed at the rare side .please check the fuse if it burn replace your problem will be solved.
Posted on Oct 13, 2010
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
Beko aa washing machine does not spin dry on any programs- used to only work on 30 min wash now even that has stopped
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Sep 15, 2008 | Washing Machines
Holes in clothes
ok make sure there is nothing stuck in the machine that is sharp ,make sure none of the little holes though out the machane are damaged and check if there lying to get free clothes lol joking
Sep 09, 2008 | GE WSM2780W Stacked Washer / Dryer
MODEL 45872 NO POWER IT BLEW THE BREAKER
Unplug your machine right away-you have a dead short it could be wiring that has rubbed through -check the wiring for any bare spots or rubbing on sharp edges,or its possible the motor is burned up-which means it takes alot of power to start it-more than you house hold wiring can come up with without blowing the breaker-hopefully just a wire though-cheers Denny
Oct 21, 2013 | Kenmore Washing Machines
Loud banding noise in my LG Tromm DLE7177
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 11, 2013 | LG Tromm Electric Dryer
I have a hotpoint 9912 washer/dryer & whilst using today there was a clunk & the drum stopped turning, we have replaced the brushes but the motor still does not turn
Could be that you have a faulty motor, check the armature for signs of shorting or burning, also make sure that the brushes are contacting the armature, check the connections are o/k in the motor plug, pull on each wire individually, if still no go, and everything else is working o/k, then it look's like you will have to replace the motor.
Please rate my comments.
Thanks
Sep 25, 2009 | Hotpoint WD52 Front Load Washer / Dryer
Timer, or Heating element?
The timer small motor malfunction or open./ remove test the two wires by multi tester the continuity/ no response motor broken./ test also fuse . if ok / sometime if motor pop same time fuse burn.
Jan 05, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Spin cycle not working
It could be the lid switch or check you motor leads. Sometimes the high and low motor wire gets loose and burns off. The colors are sometimes yellow, orange, or red.
Dec 06, 2007 | Kenmore 98702 Stacked Washer/Dryer
Hotpoint wd62 washer dryier (aquarius 1200)
i am a retired engineer of 20 years, and its about a year since i worked on combination washer/dryers but if the heater elements fine and power comes from timer there must be cut out somewhere around where it should warm up, look all round the machine one may be hidden or hard to spot there maybe about 3 one of them one of them could be a trigger device (you can press a button to reset it) that style is a very small cube about the size of a sugar lump with2 spades on it, others look like a small flat oval or round shape the size of a five pence piece with 2 spade wires on them, remove the plug from wall and remove these spades and check the contacts for continuity, you need not remove from machine to do so, no circuit + no heat, replacement item not expensive, thats where to start based on the information given, check the sensors you mention again, it sounds like your so close, good luck and work safe
Aug 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryer - acquaviva 1300 - how it works?
the dryer has 2 thermostats if these are blown then the heater wont work but you can check to see if the element is burned out by unplugging your machine opening the top off it the wires that plug into the element replace with a plugged wire with bare wires on the end place each wire into the correct connector and turn the plug on this will either heat the element up or if it doesnt then the element is blown m8
Aug 21, 2007 | Candy AQW130 Front Load Washer / Dryer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
