Question about White Sewing 915
Hi, The needle on my Toyota Ligline Auto 22 won't move. Its my granma's old machine, i took it to an aunt of mine to show me how to thread it. and it worked! then she decided that it was squeaking too much and put some wd40 on the turning piece that comes out the motor on the back. and now it doesn't work. it responds to the foot pedal and the motor works but its not catching to the next turn piece to make the needle move... Sorry about the half hazard description! Can anyone help me?
  • 5 Answers
SOURCE: The needle won't move ...
www.whitesewing.com try there web site
Posted on May 29, 2007
SOURCE: bobbin thread won't catch
I've just had this exact problem with my model 2037. The problem, according to 3 shops I've taken mine to, is that the shuttle hook (the metal piece that the bobbin sits in) is broken and needs replaced. Problem is, the piece is next to impossible to find.
Posted on Sep 06, 2008
SpotBert
  • 231 Answers
SOURCE: white sewing machine model 2999
Winter 2002 was when it was first released. Retail of $499.00.
Contact White Sewing Directly for parts =>
http://www.whitesewing.com/customer.asp
Posted on Jan 04, 2009
  • 30 Answers
SOURCE: Hand wheel spins without moving the needle
I used to have an old Bernina that had an inner and outer hand wheel. Loosening the inner wheel disconnected the needle bar from the motor so you could wind the bobbin without running the needle up and down. It sounds to me like your machine has the same feature, but resistance on the needle makes the inner wheel loosen up. I don't know whether wrenching on it as tight as you can would be enough, or whether this is a symptom indicating that there is something loose internally in the connection between the inner and outer wheels. Good luck!
Posted on Jan 24, 2009
SOURCE: Missing Manual
I have the manual, I will scan the bobbin page and try to put it up here. I will scan it right now and post it within 30 minutes!
Posted on Feb 04, 2009
How to use a twin needle on my SR2000 toyota sewing machine
First, verify that your machine can use a twin needle. Most machines take will use a twin needle will have separate thread guides and duel thread spool pins.
To thread it, thread one thread all the way through one of the needles and then thread the second thread through to the second needle. This will help keep the threads from twisting.
Toyota RS2000 Instruction Manual
Aug 25, 2016 | Toyota Sewing Machines
My rs200 toyota sewing machine bobbin won,t take thread round to lift bobbin thread
At 8 months old must still be under warranty, so take it back before you have any more problems and get a replacement.
Jan 19, 2015 | Toyota Sewing Machines
Singer 3825 upper thread keeps breaking
You might have an old needle. Most sewing experts recommend changing the needle between each project. As the needle ages the eye of the needle becomes rough and cuts the thread.
Alternatively, you might be using the wrong needle. Depending on the thickness of your fabric and the type of thread you are using you should adjust your needle type. There are needles for denim and needles for metallic threads.
When I have chronic problems like this I rethread both my upper and lower thread and that usually resolves the problem.
Dec 08, 2014 | Singer Sewing Machines
The bobbin thread wont come up when lowering the needle
The bottom thread won't come up?
Make sure you:
-Have the top threaded and through the eye of the needle (Basics are best to check, I've missed it once or twice! lol)
-Are holding the tail of the top thread when you lower your needle and pull it back up (Hold it too tight though, and it might not grab)
-Have an inch or two of "tail" or extra thread for the needle to grab on your bobbin thread (sometimes it won't grab if there's not much there)
-Have all your lower pieces in and secure. (Mine tend to jump around if I'm not putting 'em in right)
If it's still not grabbing, I'm not sure. Sorry, hope it helps.
Aug 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
Cant make the auto threader work on an elna 2007
Do you mean the auto needle threader?
Mine won't work on very small needle sizes so I resort to the old manual needle threader for these. Ditto for twin needles.
Otherwise its a case of pulling the auto threader down so the hook swings into the needle eye, then pulling the thread over the face of the needle and catching it into the hook, then release the threader so it pulls back through the needle eye, taking the thread with it.
The only other thing that springs to mind is "is the needle at the top position in its stich cycle so that the threader lines up with the needle eye?
hope these ideas help a little.
Dec 03, 2010 | Elna 2007 Mechanical Sewing Machine
Beginner on a sewing machine just got a Euro- Pro from my aunt having a hard time getting it to sew something. I threaded it and ready to go now it wont sew soooo what might be wrong with it?
See if you can find your model here and refer to the instructions to see if you missed something when you threaded the machine - http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Always thread a sewing machine with the presser foot up so the thread enters the tension so it will properly work when the foot is down for sewing.
Check the needle to be sure it is inserted correctly - this is usually with the flat side facing the back of the machine.
Hold onto the thread tail at the needle and handwalk the needle down and back up, which will bring up the bobbin thread.
Hold onto both threads and pull them under the presser foot and to the back of the machine.
Place the fabric under the presser foot. Lower the foot and move the needle down into the fabric - press the foot pedal.
Feb 28, 2010 | Euro-Pro Sewing Machines
Top thread doesn't pick up the bobbin thread (Toyota sewing m.)
Hi! This may sound silly, but if you changed your needle and put it in backwards (which is easy to do), the top thread won't pick up the bottom thread. Take your needle out and check the flat side of the needle shank--which way is it facing? With a lot of the newer machines, the flat side goes to the back, but check your manual to make sure.
Let me know if this helps, ok?
Happy Sewing!
Robbie
Feb 12, 2010 | Sewing Machines
My auto thread component is not egaging the thread down to the needle.
Need more information. Is the auto thread component going down to the needle? Is
it missing the needle hole? If this is the problem, make sure that the needle position is in the correct position by pushing the needle position button. This will bring the needle to correct height for the thread to be inserted. I had a problem similar and it was because the needle was not in the correct position. When using the thread insertion press it slowly and watch to see where the insertion part is going.
Oct 29, 2009 | Brother CS-8150 Computerized Sewing...
HI, my ligline auto 22 wont stop running, its like the foot pedal is permanantly down, only happened once before, I pushed and pulled at the wiring, did not rewire, and gave it the magic bang to the side,...
There is a supressor that has failed, probably in the foot control.
It usually smells like burning plastic/electronics.
Remove itor have a qualified person do it for you if you are uncertain, this is lethal voltage we are talking about, and if you do not know, why risk it for the sake of a few dollars ?
Aug 21, 2009 | Sewing Machines
White Sewing 915 Logo
48 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
