Question about HTC Touch P3450 Smartphone
My phone screen not working, key pad working but my phone was keypad locked. to unlock i need to press unlock button on screen but screen is not working .. i have restarted and remove memory, sim card also but not success..can u tell me what should i do ???
  • 597 Answers
The reason your screens touch pad is not working is because the sensor board is no longer connected to the main panel of the phone, or the ribbon that connects the screen to the main board is faulty.
Try to open up the phone, by unscrewing it open from the back, then locating the ribbon and either try to reconnect it or replace the ribbon with a new one.
Remove your back cover, battery, sim, stylus and memory card. Now remove the cross head screw,
Lever the antenna cover off using a mobile phone opening tool.
Now remove the six screws you have access to.
Next you need to separate the battery compartment from the rest of the phone. To do so lever it away using your opening tool. There are various recesses in the back of the phone do allow you to do this.
The volume buttons are stuck to the side of the housing and need to be carefully peeled away. you can see the volume buttons after they have been unstuck from the side of the phone. You can now peel the large brown/orange ribbon away from the phone. It's held in place with double sided tape. The circuit board which the ribbon is connected to will come away with it. The on/off switch will be stuck down in the same way the volume button was and also needs to be peeled away when you remove the circuit board.
The on/off button will also come loose. Remove the screw, circled bottom left. The vibrating motor, bottom right, should be levered up so it is loose.
Lift the lower circuit board up and you'll be able to see another ribbon connector which needs to be disconnected. Again, it attaches like a plug and socket. Just lever this away from the circuit board to unplug.
To screen is held firmly in place with double sided tape and to remove it you first need to heat the screen (using a hot air gun or a hair dryer), then push your opening tool very firmly. You'll then see the screen raise slightly allowing you to slide something like a guitar plectrum or credit card behind it. Move your plastic tool all the way around the edge of the screen to release it.
You can now simply lift the screen away from the housing.
You should now have the screen removed. Reverse the whole procedure for reassembly.
Take care and good luck
Posted on Oct 13, 2010
Phone is locked. How do I unlock it?
With front of phone facing you. On the left side of the phone you will see two grey slim inline buttons, and or, keys. The top button, and or, first key is the UP/DOWN VOLUME key. The bottom button, and or, second key is the LOCK key.
(1) To UNLOCK the phone. GOTO the LOCK key. PRESS and HOLD until you see the screen read out display "KEYPAD UNLOCKED". You are now done.
(2) To RE-LOCK the phone. GOTO the LOCK key. PRESS and HOLD until you see the screen read out display "KEYPAD LOCKED". You are now done.
In Addition:
(3) To set AUTO-LOCK on the phone.
GOTO the MENU key. Located on the top left of the keypad on the front of the phone. The LARGE WHITE HORIZONTAL BAR directly under the word MENU on the screen readout. PRESS-IT ONCE. You now SEE the PREPAID ICON.
Next, locate the OK key, top center on the keypad. Directly below the middle of the screen readout.
Next, locate the UP-ARROW key directly above the OK key. By using the OK key PRESS-IT ONCE. Now you see the SETTINGS ICON.
Next, by using the OK key, PRESS-IT ONCE. Now you are in SETTINGS.
Next, locate the DOWN-ARROW key. Located directly below the OK key. PRESS-IT ONCE. PHONE SETTINGS should now be highlighted for you.
Next, by using the OK key, PRESS-IT ONCE. You are now in PHONE SETTINGS.
Next, GOTO the UP-ARROW, PRESS-IT ONCE. AUTO KEYPAD LOCK should now be highlighted for you.
Next, by using the OK key...(or...by using the WHITE HORIZONTAL BAR key, located directly below the OK on the screen read out). PRESS-IT ONCE. You are now in AUTO KEYPAD LOCK settings.
Next, by using the UP or DOWN ARROWS, GOTO the amount of minutes that you would like to set your phone to auto lock for.
Next, GOTO the OK key...(or...by using the WHITE HORIZONTAL BAR key, located directly below the screen read out). PRESS-IT ONCE. Your screen read out will now display, "DONE"
Your phone is now set to AUTO-LOCK when your phone has been at rest for the amount of minutes that you have selected.
If you would like your phone to lock sooner in order to place it in case, pocket, or purse. Simply refer to (2).
Jan 31, 2014 | Alcatel Tracfone A382 BIG EASY No-Contract...
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
Emachines netbook unlock key pad
Key Pad or Touchpad? Is it that the mouse pointer is frozen and does not work? If so, look at the middle of the touchpad at the top of it and there might be a button there that lets you toggle the touchpad between locked and unlocked.
Sometimes there might be a set of keystrokes you will have to hit to lock or unlock the keypad. Most times you will have to Press and Hold the Alt, FN or Ctrl key then hit the key (most times one of the F1 thru F12 keys) that controls the keypad. The key that controls the keypad will have the icon of a finger inside or pointing at a square that represents the keypad. On one laptop recently that I worked on it was toggled by Pressing and Holding the ALT key then hit the F6 key. F6 had a finger pointing at a square area representing the touchpad.
Apr 07, 2012 | eMachines eMD620-5133 Notebook
Don't know how to set key pad lock
Before locking the keypad first remember if the keypad lock is assigned with a security code.
Default value of the security code is normally 0000.
1. To lock the keypad first press the option key, then select the LOCK KEYPAD.
2. To unlock the keypad press the option key then press the "C" button.
You can check more lock/unlock optoons in the users manual, downloadable from this link. Read page 63 and on.
http://dl-www.sonyericsson.com/cws/download/1/150/669/1192984731/J230i__UG_R1a_EN.pdf
Sep 04, 2011 | Sony Ericsson J230i Cellular Phone
How do you unlock the key pad on a Nokia phone
Hello
To unlock your keypad press the top left key on your keypad and the star (*) key on your keypad, this unlocks the keypad...
Apr 11, 2011 | Nokia 6085 Cellular Phone
My keypad is locked.please help me
ky keypad is locked by security code what can i do 4 unlock 2730c
Aug 12, 2010 | Nokia 2730 Cell Phone
I'd like to lock the keypad of my HTC S740.
To lock the keys so you don't accidently activate the phone whilst carrying it about.
Press and hold down the "end call" button ( phone handset down picture) until Unlock shows at bottom left screen
To unlock, press the top left button, above the "start call" button (phone handset up picture), then press the * button (bottom left).
You get a screen prompt to press * to unlock
Mar 06, 2009 | HTC S740 Smartphone
How to lock and unlock keypad Motorola VE240
To Lock your phone
Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
To Unlock your phone
The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
Hope this helps you all!
Jan 02, 2009 | Cell Phones
Unlock pantech c3b
Lock or Unlock the Pantech C3b Goal:
Lock or Unlock the Pantech C3b Fact:
Pantech C3b Fix:
Pantech C3b Keypad Layout
Keypad Lock
The Pantech C3b does not have a Keypad Lock feature. When device is not in use, close the flip to guard buttons from accidental contact.
Lock the Phone
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Security.
  4. Scroll to and highlight Phone Lock.
  5. Press the directional pad left or right to select Enabled.
  6. Press OK.
  7. Enter the Password.
  8. Press OK.
Unlock the Phone
  1. From the standby screen, press Unlock.
  2. Enter the Password.
  3. Press OK.
Aug 26, 2008 | Lands Phones
Can't unlock keypad
The default security code for Nokia is 12345.
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Apr 03, 2008 | Nokia 6300 Cellular Phone
HTC Touch P3450 Smartphone Logo
161 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Jerry Kramer
Jerry Kramer
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
