Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Pictures are green
I've calibrated, cleaned printer heads, tried different pc's, even went direct from card, and tried new ink...pictures are still green.
error code3506
  • Anonymous Jun 02, 2008
    All pictures are green. Tryed it all. Did a good job for one set of ink. Next set for about 15 pictures. Very upset with 5300 printer.
  • 121 Answers
Some ink delivery vesseles could be jamed
try to clean the cartige holder with a glass cleaning solution pour so the liquid makes its way and open the jamed tiny tubes which delivers the ink then dry it with a piece of cloth
Posted on Jun 01, 2008
The colours on our HL-4040CN have gone all strange - when we perform colour calibration the colours go either red or green. All toners are new and the drum has been replaced recently as well. We do a lot...
Hi
We need to isolated the problem on what cause ink cartridge not print in color. When even you installed new cartridges, It is necessary to run the print nozzle to clean the print head. Also, please try to clean the print head manually by removing all the ink cartridges and rub the print head into a white paper with alcohol until ink flows and then return it back and run the print nozzle for 2 times.
Then try to print again.
If it does not help you, please let me know to give you more help.
Mar 03, 2011 | Brother HL-4040CN Laser Printer
When I print the picture has a purple haze in it ?
If you are using re-manufactured ink tanks, that would explain it, a mi-matched ink tank. To clarify the ink colour is not quite right.
If genuine ink tanks (Recommended) then maybe try different paper. If using photo paper you should be using compatible / genuine paper as the different chemicals react can give this problem.
If using fax / standard paper then could be print head fault....normally get an error code.
Jan 26, 2010 | Dell P703w Printer
Thinking of cleaning the print head? ?
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page, then scan it after. Load a regular paper. Then try to print a demo page by pressing Photo and Copy at the same for 5 seconds then let it go. If same problem persist call this no for further assistance 1800 421 6699
Thanks
Aug 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Bad color in photos-Starts out good then goes to very bad
have you attempted printing directly on the printer via. pictbridge orthe inbuild card reader? this does sound like a problem with the printhead, or connection to it... try taking the print head out andreplacing it, it would need to be re-calibrated again when you do this,but if there is a connection issue this would most likely solve it. its possible also that the feed through for one colour of ink isslightly clogged or not drawing ink correctly (sounds like yellow)-this would mean that its not able to restock its yellow pallet quicklyenough while printing. you could attempt to clean it out yourself, orif its under warranty, see if they will replace your print head for you
Jun 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer does not print black ink
I have seen many NEW dried out cartridges. i would try new ones again.
Dec 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Poor picture printing
Do not try to clean print head again and again, it consumes too much of ink.
Try reseting print head and then calibrate it.   after then check nozzles and align prinhead.   Now u can try cleaning printhead last time.
If it does not fix your issue , your printer needs to be replaced  (In case printhead has already replaced within 30 days)
MS
Dec 22, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Color of pictures
image quality occuring after long period of inactivity of the printer oftenis caused by inks drying up or clogging either the nozzle or the channels of your printhead. to prevent this from happeniong, i suggest you do the maintenance first: deep clean and calibrate the printhead before you start using it if you havent used it for quite a while. you might be experiencing a printhead problem if the printer is printing predominantly in one color. you should try to visit thsi helpful website. the link ive provided below:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
it should direct you to the right recourse regarding your issue...hope this helps..ciao!!
Oct 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black inkwon't print
pictures are not clear even after installing new ink cartridge and cleaning print head
Oct 04, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Poor color on home printed photos
hmm..no blue, eh? that means that one of your print head cartidge lines is clogged. Sounds like time for a new cartridge tray, which you can access through www.kodak.com
Aug 20, 2008 | Office Equipment & Supplies
Photos are printing green
call support and have your printer head replaced
Jun 01, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
29 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
