I put in a code that now wont allow me to program my t.v anymore.is there a way to reset my remote?
    Scholar:
  • 143 Answers
Most remotes can be reset. But we need the Remote brand and model number to find instructions for doing it.
Posted on Oct 13, 2010
I got into the settings and i pressed code two and now the remote wont work anymore and wont let me get in the setting on my bluray remote
Press and hold the [OK] and [2] buttons at the same time for 10 seconds. This will allow the remote to work once more.
Apr 17, 2014 | Panasonic DMPBD65 BluRay Player
How do I program a tv code into my remote
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Jan 05, 2014 | GE Tv Vcr Sat/cbl Remote Vsqs1495...
Remote wont turn tv on [after power cut] does remote need re codeing if so what is code
Not usually does a power outage affect a remote in operating a TV...but there are always reasons. I suggust re-programming the remote. To do this, simply go to your remote's brand name website. Example: www.Your remote's brand name here.com,then go to "programable codes". Jot down the codes which apply to your television(will be several at the least). Next, go to "programming instructions"...If able, print these out (or write down for quick reference). You WILL need these in front of you while programming your remote to your TV, ensuring you are completing every given step. This should help you...suffice to say you'll be controlling that TV in no time! Thank you for allowing me to be of assistance. I hope you don't have any future problems, but in case you do...you know where we are. Thank you and enjoy your day!
Jan 28, 2011 | Televison & Video
I would like to program the remote to a different tv and i dont have the manuel anymore
You can download your manual free from here:
http://www.jascoproducts.com/support/download-files/ge-remote-instruction-eg-24912.pdf
Click the link and the file will open. You can then view, save and/or print your manual. Please note this manual does not contain the codes for your remote. You can also download these from here:
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
These codes work with all GE remotes, but some older remotes wont be pre-programmed with all of these codes and older remotes may not work with new TVs. If you are unable to open the manual and codes, you may also need to download Adobe Reader:
http://get.adobe.com/reader/
Please rate this solution if you find it helpful. Thanks.
Nov 04, 2010 | GE JASRM24912 Remote Control
My touch screen stopped working on my samsung impression so i put the rest code in and the phone reset then its now stuck on the calibration screen and the touch screen wont respond
Dont kno if "Impression" is similar to "Omnia" but 'REMOTE SCREEN ALIGNMENT' program installed on PC skips 'align screen' on your phone. Also "welcome.not" (made in notepad) & pasted into your root files. A REGISTRY EDITOR will allow you to input the touchscreen configuration numbers manually. Of course, none of these will be much good if you dont have 'Windows" phone or cant access your Registry!!
If all this fails, ASK 'XDA DEVELOPERS', or 'MoDaCo'.
Oct 29, 2010 | Samsung SGH-A877 Impression Cell Phone
The amplifier was put to mute on using the remote control then the remote control was broken and cannot use anymore. How can I return back the amplifier to normal without using the remote control?
Two suggestions.
1) You may be able to reset the memory and get back to factory default settings by either unplugging from the power point and leaving it unpowered for at least 5 minutes - some products could require a few hours for memory to be reset. Alternatively your amplifier may have a reset funtion (usually a button or switch on the rear panel - see owners manual for specific instructions of your model)
2) Since your remote is broken, the cheapest option is generally to buy a universal remote control (available from may discount and electrical retailers) for around $10.00 enter the code for your particular amplifier and then use the amp as you did previously - you might like to double check that your brand/model is supported by that particular brand remote manufacturer - the better ones (read dearer) even allow you to down load the remote codes from the web (this would be overkill for your problem, but you might like to combine all your remotes into the new tricky one you will buy).
Feb 15, 2010 | Yamaha DSP-A3090 7-Channel Amplifier
My remote wont program with the code or with out them
try it again. press code search button then TV button then the code you have then OFF button.
Aug 04, 2009 | RCA Universal Remote Control
Wireless Keypad wont allow use of other door openers
hit learn button for 10 seconds. now nothing will work except wired buttons. Hit learn for 1 second and put in yur 4 digit keypad code and hit enter, light on motor will blink twice. hit learn again for 1 second and push button on remote. again bulb will blink. continue pushing learn for 1 second and adding another remote.
Dec 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
I don't know how to program my remote anymore!
I had the same problem and typed in the model of my vcr instead of the remote model. This is the site I found, although my tv is not on the list, I followed the steps at the bottom of the page and found that code 08 worked for my Phillips TV. I hope this helps all of you with finding your codes and programming your remotes.
http://www.remotecodelist.com/remotes/sharp/sharp_vch982.html
Jan 14, 2008 | Sharp RRMCGA342WJSA Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
