Question about Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka Uno Model 2999. I need instructions on how to replace the belt.
  • 377 Answers
I think you will find the free manual at this URL to be helpful
http://www.eureka.com/service/manuals/80247.pdf
Posted on Oct 13, 2010
How do I remove the dust cup and clean it?
Hey, this is Tristan with Crucial Vacuum,
In order to remove the dust cup, there's a designated lever that you slide to the left in order to pull the dust cup out. This slider is above the HEPA filter (the four holes near the bottom of the vacuum). After cleaning, you slip the dust cup back and slide the slider to the right to lock it back into place.
Below I have attached a link to the users manual for the Eureka 2997-2999 series. You should refer to page 4 to view the diagrams pertaining to my suggestions.
http://www.manualslib.com/manual/49521/Eureka-2997-2999-Series.html?page=4#manual
You can purchase replacement parts for Eureka direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Tristan Clausell
Crucial Vacuum Customer Care
Sep 13, 2015 | Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka Model 8852 bvz belt for beater bar belt is broke
You need to replace it. Here is a link to the belt you need and the manual which has instructions:
Eureka 8852 Belt
Owner's Guide (1.36 MB download)
Dec 17, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
What type of belt does the Eureka Uno take?
Here is a link to the belts for the Eureka Uno models and a manual you can view which has instructions.
Eureka Uno Belts and Manual
Dec 15, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
It smells like something is burning and then I saw smoke coming from the bottom, where the roller brush is.
That means that the belt is very worn and it is slipping on the motor. You need to replace the belt. Here is a link to the belts you need and a manual you can view with instructions:
Replacement Belts
Owner's Guide (3.4 KB download)
Dec 08, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
My eureka bagless uno vac problem is when I use it the belt gets really hot and starts smoking
try to manually turn the brushroll. if it feels tight then u will need a new brushroll. otherwise try replacing the belt
Jul 13, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
Handle from my Eureka Uno 2999 AVZ broke off
try a company called cds they r in the midlands but they courier parts out 2u dont have their no 2 hand u will need the model number try the web marting
Mar 17, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
How to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Dec 03, 2008 | Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka Uno brush not spinning
There are 2 or 3 screws on the top to take out and the top cover will come off. Belt is #61120A U long life, brush roll if you need it is #62365-2. If the brushs look ok and the ends turn freely, then it is probably ok. The belt goes around the brush roll then up to the motor shaft.
Mar 01, 2008 | Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka Uno 2998AZ Bagless Upright Vacuum Logo
376 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
