Question about KitchenAid KAWS750L Top Load Washer
WONT STOP FILLING, NOT WATER VALVE - KitchenAid KAWS750L Top Load Washer
    Scholar:
  • 78 Answers
Sounds like shut off switch is bad or stuck some how. You will need to find it and check it.
Hope this was helpful.
Good Luck
cookEmonster
Posted on Oct 13, 2010
Water wont stop when filling up, and over flows
Water valve problem to make sure while water is filling unplug washer if still filling change valve
Jun 04, 2011 | Washing Machines
Fills with water but wont stop filling and wont change to different cycle just keeps filling
check water pressure, it need to be about 20psi. also remove fill hoses and check the screens for dirt. clean it if necesary. also check water valve at fill hose connection. it has screens also. clean if needed. if all is ok then replace water valve.
Feb 07, 2011 | Washing Machines
Washer wont stop filling even when its washing. GE
Replace water inlet valve, it's stuck open. You may try removing hoses to valve and see if something is holding it open
Jun 29, 2009 | Washing Machines
Ont stop filling with cold water
Hi. the pressure sensors in the water valve assembly appear to be damaged. you will need to replace the inlet water valve assembly in this case asap.
This is solenoid failuer. (basic water valve failure this case)
May 31, 2009 | Kenmore Washing Machines
Flashing FE and wont stop filling with water
FE means Fill Error, but you already figured that out. If you unplug the machine and it still fills, and the only way to stop the filling is to turn off the valves supplying the water to the fill hose(s), then you need to replace a fill valve. It is best to figure out which one by turning one off at a time while the machine is in that FE condition. There is a separate hot and cold valve. (they are the part that the hose screws onto on the machine.) To replace valve, cover comes off machine by removing two screws at the back of the top. (not the two which go into the top, the ones just below them) Then, standing in front of the machine, use the palms of your hands to give the top a sharp push to the rear to slide the top back about two inches. Then lift the top off.
May 31, 2009 | LG Washing Machines
Wont stop filling
If when you press pause while filling and it keeps filling then you have a faulty valve. If the filling stops then valve is ok.
If you filling keeps going until overfilling the machine which is what i understand is your problem, then most likely that you have a small pinhole in your pressure tube.
Apr 18, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine wont stop filling up with water
Water valve is bypassing and need to be replaced or the water level switch control is out of order.
A remote possibily is a leaking pressure swith airhose is leaking . Good luck
Dec 28, 2008 | Washing Machines
Washing machine wont stop filling with cold water
Since you removed the screens, the sand probably has entered the valve and damaged the spool. It's apparently sticking open. You need to replace the complete valve and keep the screens in place.
Jun 09, 2008 | Whirlpool LSR5132PQ Top Load Washer
see if the water coming in is hot or cold by turning the water faucets off and on to see if one fills and the other dont and replace the valve
Feb 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
KitchenAid KAWS750L Top Load Washer Logo
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
