Question about Andis Styliner SLII Hair Trimmer
My andis is not cutting well i put anew blade on and it just vibrate but not edgeing on hair
  • 62 Answers
SOURCE: Putting blade back on my Andis dog clipper
It sounds like you may have a bent hinge which is what the blade slides onto. Please call Andis customer service at 1-800-558-9441 to speak with a customer service rep. They can give you instructions on where to purchase a new hinge or send or clippers in for repair.
Thank you,
Posted on Jul 23, 2008
  • 61 Answers
SOURCE: andis adjustment
blades has to be set precisely,only then will you get a crisp cut.
Posted on Jan 26, 2009
SOURCE: Blade won't cut
Try replacing the Drive Lever which is located at the end of the clipper and goes from side to side, simply undo the two screws on the name plate/ gearbox cover and remove then pull the lever out. This is the most likely cause if you experiance the same problem with all blades.
Posted on Apr 25, 2009
SOURCE: My GTO model Andis clippers
YOU HAVE TO OPEN DEM UP. TAKE OUT THE SCREWS ON THE TOP DEN TAKE OFF THE BLADE. ONCE YOU HAVE THE BLADE OUT THERE ARE TWO MORE LIL SCREWS UNSCREW THOSE (NOT ALL THE WAY OFF, JUST ENOUGH SO THAT THE BLADE WILL MOVE) ADJUST THE BLADE HOWEVER YOU WANT. IF YOU WANT IT CLOSE FOR A MORE DETAILED CLOSE LINE (NOT TO CLOSE AS DEY WILL CUT YOUR OR THE CLIENTS SKIN). YOU MUST TRY THEM OUT ON YOURSELF SEE IF THEY ARE TOO SHARP, IF THEY ARE TAKE THEM OFF AND ADJUST THEM AGAIN. EASIEST THING TOO DO IS USE A MIRROR, HOLD THE BLADE AGAINST THE MIRROR DEN MOVE IT AT AN 45 ANGLE DEN TIGHTEN THE SCREWS DER (BARBER TRICK).
Posted on Jul 21, 2009
  • 8 Answers
SOURCE: adjust blade
On the Andis T-Outliner or Outliner if you have use the trimmer for more than 3 hair cuts or 3 time or more I do not recommend moving the blade, reason why is that you have all ready start or have a sit in or a grooved, I have found that by moving the blade it won't cut at all.You need to resharpen the blade with a professional sharpener and have them reset the blade for the type of hair cut you want. The blade can be set to shave or do line ups, and Fades. This type of trimmer is for that kind of hair cut the professional barber use them all the time. Call Mannys Sharpening 323 263-4697 They have a good rating on Yahoo Local.
I have try many sharpener and had no luck, until a friend of mind told me about Mannys Sharpening, They know what they are talking about highly Professional in thier work.
Posted on Aug 01, 2009
My toutliner cutting too sharp
Adjust your blade. Remove it from the clipper, and then loosen (don't remove) the two screws that hold the blade and cutting edge together. Use a FLAT surface, like a ceramic sink top or flat piece of tile, and push the cutting edge down and angle the blade with the cutting edge facing the flat surface down to about a 30 to 35 degree angle. Use your thumb to hold in place until you can retighten the screws. Under a light, inspect to see if it is level (it will be noticeable if it isn't) or oil the blade and touch it to a clean dry piece of paper. If it is level, replace the blade on the trimmer, and edge your beard. It should be better than brand new. This also works when it doesnt seem like the blade is cutting sharp anymore. ALWAYS make sure the cutting edge is lower than the blade or you WILL CUT YOURSELF or YOUR CLIENT!
Mar 29, 2014 | Andis T-Outliner Hair Trimmer
What if you remove the screw that hold the blade in
Then you have just ruined your blade. Those screws hold the cutting edge level below the edge of the blade. Without those screws aligned and tightened, its going to jump all over the place and will cut the skin and eventually fall off.
Dec 10, 2013 | Andis T-Outliner Hair Trimmer
When i cut hair my andis master clipper seems to get stuck while cutting hair causing me to take longer with the fade how do i go about fixing it to where it doesnt get stuck in hair & by the way im...
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Jun 19, 2010 | Andis 01690 Hair Trimmer
My andis t-outliner keeps pulling hair when cutting and it barley cuts the hair. Do the blades need adjusting?
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Jun 08, 2010 | Andis 01690 Hair Trimmer
Trimming with #10 blade seems to work ok but #7 blade will grab the hair and will not cut clean. I've purchase another new #7 blade to see if the blade is the problem but the same result. Any ideas? Thanks...
I have the same clipper and have found that if you comb,wash and dry the hair thoroughly first, it works alot better! Also putting a drop or two of the oil on the outer edges of the clipper. (did you get a dvd with it?)
Apr 19, 2010 | Andis Advanced 21490 MBG2 Hair Trimmer
How do i get blades closer on the pivot pro t liners
You really can't move the cutting edge on any andis trimmer blades without throwing them out of spec. I say this to say that if you try (and the blades are not precisely set) it will scrape and cut the skin when you attempt to use them. They are factory set for optimum cutting. If you have found that they aren't cutting as closely or as cleanly lately, it just might be time to replace the blade entirely. I have a set of those, and a styliner II, but I prefer the cutting power of my T-Outliner over all.
Oct 04, 2009 | Andis T-Outliner Hair Trimmer
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Aug 13, 2009 | Andis Health & Beauty
Andis Styliner SLII Hair Trimmer Logo
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
