Question about Sanyo HT32744 32" TV
My Sanyo is making a noise that's been a little quite but now its louder and it would usually go away but its not. Please help I don't want to use the small tv
    Top Expert:
  • Sanyo Master
  • 75,581 Answers
One anong your TVs transformers causing the problem. Usualy, on all tvs ferrite cored transformers are used. If the core of the transformer get loosed, it will make a whisling noise. To get the faulty transformer, you must open the back cover of the tv and listen which transformer makes noise. Usually core of LOT will vibrate. After recognising the transformer which makes noise, press its core with a wooden or plastic matereial to sure the transformer under concern is it or not. Fix its core joints with some super glue, without seperating it you can do that. Take caution. There are severel very high voltage points are ther inside the tv.
Posted on Oct 14, 2010
Does not drown out background noise, only makes it louder
If you have just bought these, take them or send them back.
Feb 02, 2014 | Dual TV Ears - Headset System Headset
I have a Sanyo digital camera, model: VPC-X1250; it now takes blurry pictures where you can't tell what the subject is even when i am inches away from the person's face. it also turns on, makes a...
hi According to your information, somehow your camera has lens unit defective. Your local repair shop would charge around $ 35 to 75 depend on what really want to charge. Thanks and best regard!
May 24, 2011 | Sanyo VPC-X1250 Digital Camera
HI, I hope you can help. I have a pair of samson resolve 50a monitors and an imac 21". The issue I have is, when using the monitors I get a electrical white noise kind a sound and the louder the...
If the noise varies with the volume, it's entering your signal path somewhere before your volume control.
Make sure all audio-bearing cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Jan 24, 2011 | Audio Players & Recorders
My frigerator is making a very loud noise coming from the ice maker area. It sound like a airplaine engine getting ready to take off. Sometimes it gets louder and louder. If I turn the switch to off then...
the noise is the evap fan hitting . now either its comming off the motor shaft or its hitting ice build up caused by incomplete defrost . It's time to call the repair man . as the noise will quit and the cold will too . mm
Jul 06, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Hi, I have a chrysler pt cruiser 1991, it is making a loud throaty noise as I go up in gears, it's not the exhaust.
HI" does this noise go away when you step on the clutch pedal and does this noise gets louder as you go faster, try turning the steering wheel a little see if noise goes away that would indicate bad wheel bearing
Sep 23, 2009 | 2001 Chrysler PT Cruiser
Aircon compressor makes noise
Is this noise definately from the compressor? have you looked round the system for a loose componant like the fan? is this system a heat pump sorry I have not checked online but if it is what is the sound like in heat mode, if just coling unit please ignor last.
Jun 08, 2009 | Sanyo CM3172 Air Conditioner
Honda accord 07 making a highpitched squeaking noise in cold
Its more than likely a bad worn or loose drive belt. Here is what you do the next time you start this vehicle up and the noise is herd open the hood and pour some water on the drive belts this noise should go away or get louder temporarily. If it does turn vehicle off and check for loose or damaged/worn drive belt and replace or adjust if needed. Good luck and contact if you nee more help, thanks for using FIX YA
Jan 26, 2009 | 2006 Honda Accord
Refrigerator not working
Hello bobbie50,
Welcome to Fixya,
You said, After making a louder than usual grumbling noise several times today, my refrigerator is no longer cold (freezer too). Please tell me I don;t have to buy a new one. my refrigerator is not working properly. The freezer keep thing cool but will not freeze. the bottom part does a little cooling ,but not like it should.
Help me with a little info.
What is the model # and the year or age of your fridge?
Let me know right away. I'm here for you!
Huuum
Aug 04, 2008 | GE Hotpoint Top-Freezer Refrigerator
HOWLING NOISES
Did you check your Transmission fluid and your differential fluids make sure there up and I don't know if you checked your rear wheel bearings or not, You can usually tell a wheel bearing when you are driving the car at highway speeds and you go around a corner and it get quite a bit louder Depending on what way you are turning if your turning right and it gets louder it will usually be the right side front or rear. the left usually the left front or back. some cases I have even heard Axles making a Howling Noise. Please let me know what you come up with. And Thanks in advance If I helped you out any. Bear001
Jun 17, 2008 | 2000 Honda CR-V
Sanyo HT32744 32" TV Logo
191 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
