Question about RCA Televison & Video
My 51" rca flat screen tv is on all inputs make everything red, green, and blue. how do i fix this?
  • Paul Bade Oct 13, 2010
    Is this is a CRT rear projection TV? If so, is the picture "bow-tie" shaped (bows in at the sides and top and bottom)? I assume you mean the three primary colors are not lined up together (properly converged).
    The bow-tie picture in a CRT RPTV usually means your convergence amplifiers are not working. A mechanical or electronic mis-alignment in the CRTs can cause color fringing in an otherwise normal picture.
    If you have an LCD or DLP rear projection set, the color wheel is not properly synced to the picture. This will produce some interesting rainbow effects or sideways color shifts, but I can imagine it's hard to watch for long.
    If you provide the model number and a more detailed description of the problem, we can give you better guidance.
    Genius:
  • 1,030 Answers
The sympton you describes points to a convergence issue. Is the picture 3-d looking? is the picture bowed in at top and bottom? Can you get the menu to display? I offer a suggestion ... read the article named fl231 fuse in the tips and tricks section of this website. http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in
then let me know if i can help you further. i have seen alot of rca in the shop.
ps. what is the model of this set?
Posted on Oct 13, 2010
How do I connect my flat screen tv to my Phillips MX3900 system
This is an older home theater package and only has component video out for HD and RCA or SPDIF optical out for audio. You'll need to locate the component video input on the back of your flat panel and connect it to the component output of the Phillips unit. Component cables have 3 RCA cable (Red, Blue, Green) for HD. You can use a RED/WHITE RCA cable for audio but if you have a SPDIF Optical cable you should use that for better sound. The TV should have that as an input also. You will need to go into the Menu for the TV and select component video and SPDIF optical if you went that route for audio.
Dec 03, 2014 | Philips MX3900 System
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
I have an L32HD31 TV and just recently the screen started to display these fine horizontal lines that cover 3/4 of the bottom half of the screen. Was wondering if there was a fix for this and what could be...
Check all your input cables. If RF coax, make sure they are just beyond hand tight. If RCA, twist each a few times to burnish (clean) connections. This is especially true if you are doing Component viodeo (Red, Green & Blue).
Nov 25, 2010 | RCA L32HD31 32 in. LCD HDTV
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
Oct 07, 2010 | Nintendo Wii Console
When using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Feb 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Sony kp 51ws510 upgrade to HD - how to do this
There are inputs on the back of the set. If your tv is Sony 51ws510 then it is capable of HD, but you have to have component or DVI cables to connect the tv to the HD device (HD cable box or DVD player).
<br>
<br>
On your set the component inputs on the back of the tv are video5 and video6 in the middle located in a vertical line (red, green, blue rca video connections with red and white rca audio connections).
<br>
<br>
You also have a DVI input toward at the top of the input panel (white connector with red and white rca audio connectors).
Jan 03, 2010 | Sony KP-51WS510 51" Rear Projection...
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
From cable box component out to tv component picture is on no aud
You need to also connect the RCA audio out (red/white) from your source to the audio input on the TV. You do not need the yellow wire as that is for composite video. The component cable (red/green/blue) is only for video. Look at the input on the TV where you connected the red/green/blue cable. Right next to it, you should have another red and white connectors for the audio input. Connect that to the audio out on the cable box.
May 01, 2009 | Digimate DGL20 Television
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
How do I get sounds when I use the red green blue rca hook ups?
The red, blue and green RCA hook up is just video. You must also use the red and white pair of RCA jacks for the audio. You can usually find the audio red and white jacks right below the video red, blue and green RCA jacks. Get yourself an audio RCA cord with the red and white connectors and run that from your video device audio output to the audio input of the TV that corresponds with the video input of the TV. An example would be if the red, blue and green are on the "Video 1" input of your TV you will find the red and white audio input for "Video 1" right below or right next to the video inputs.
The red, blue and green video jacks are called "component video" and they only have a video signal for high definition video, so you must also run a separate audio line for it. The same holds true for the yellow video RCA connector, that one is called "composite video" and it also has only a video signal with no audio.
I hope this helps, if so a "FixYa!" rating would be very much appreciated.
If you need more help just post your concerns right here onthis thread.
Dave
Nov 28, 2008 | Initial DTV-171 17 in. TV/DVD Combo
Televison & Video Logo
55 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
