Question about Ovens
Wiring diagram for mti-10 deep fryer - Ovens
I have Frigidaire gallery oven with an F 10 error code. What does the code mean?
A faulty RTD sensor probe is one of the causes for an F10 code or overheating oven. The sensor probe is supposed to detect the exact temperature in the Frigidaire electric range cavity and relay it to the oven's main control so it knows when to shut off the heating elements. Follow your wiring diagram to find the probe's location, which can differ among the models. Inspect it for any obvious damage such as cracks or tears in the wiring.
May 08, 2017 | Frigidaire Ovens
Hi, Looking for a wiring/electrical diagram for Neff D39F56S0GB Extractor hood. Or could you Kindly point me in the right direction. Thank you
You can find the manual here:
D39F56S0GB/01
and here:
D39F56S0GB/02
It should come with a cable attached which should conform to standard wiring colour codes.
Red/Brown = Live/Feed
Black/Blue = Neutral/Return
Green/Green & Yellow = Earth
If the standard cable has been cut off there is a good chance it was for a reason and you shouldn't try to connect it without knowing how to determine which contact is for which (an electrician/electronics tech will know within seconds what should be connected where.)
Mar 07, 2015 | Neff Ovens
Wiring diagram for a Kelvinator DeVille eye level oven Model B305, Serial no 3674
Request the wiring diagram directly from Kelvinator.
Jun 25, 2014 | Ovens
Wiring diagram stove
That is an older model, so the wiring diagram will be harder to find. Have you already checked the manual? I would also suggest checking online at the manufacturer's website. Other than that, you can try online.
Elisa Jed ' http://www.atlasappliances.com
Jun 22, 2014 | Ovens
Chef premier 091S16FE1 gas cooker. Igniter will not work in grill or oven. Switch tests ok. Need wiring diagram. Would like to know if there is a fuse in the system.
I dont have a diagram but most Chefs have a wiring diagram stuck behind the lower kickpanel or underneath the warming drawer ( if fitted) The Premier was a fairly basic unti when it came out. A lot of these had battery ignition. Look behind the kickpanel or under the warming drawer for a battery box. ( About the size of a matchbox) and has a 9volt radio battery.
I have not seen fuses in these ovens for over 10 years , so I would suggest that yours doesnt have one.
Jul 26, 2011 | Ovens
Wiring diagram of a Satchwell type70th thermostat switch
need wiring diagram for defy gemini petit chef oven switch
Dec 07, 2010 | Ovens
Sfe comes up when autofry is turned on
The SFE is a code that stands for safety. Typically this happens when one of the push buttons is not pushed in all the way. Check the buttons inside the filters area, make sure the filter cover is on correctly and make sure the door is closed when turning the machine on. If you contine to have problems, please contact MTI manufacturers of the AUTOFRY @ 1-800-348-2976.
Sep 26, 2010 | Ovens
Wiring diagram for jtp18
Call GE at 1-800-626-2005 to get a wiring diagram
Regards,
Powerman
Oct 26, 2008 | GE Profile JTP18 Electric Single Oven
HOBART AM14F wiring diagram
I can tell you where the wires need to go.What are you trying to hook up on the dishwasher?
Feb 23, 2008 | Ovens
Ovens Logo
157 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
