Question about Bosch Dryers
Under wire from bra cuasing noise in dryer drum
  • Joe Mama
    Joe Mama May 11, 2010
    Try taking the bra off first
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    well...is that due to it being caught between the drum and the case?
    this is without a doubt one of the more interesting questions I've seen..
    Guru:
  • 859 Answers
Place the bra in a pillow case.
I know this helped with four daughters behind me and out on their own.
Worldvet
Posted on Jun 02, 2008
  • Glenn Rogers
    Glenn Rogers Jun 02, 2008
    Oh, you might need to make that two older pillow cases until you find the comfort level and just keep them in the laundry room.
    Worldvet
    Sergeant:
  • 226 Answers
I'm not sure we have enough information yet, but I do believe that the bra would be more comfortable in its relaxed state.
Posted on Jun 01, 2008
How to remove a bra wire from behind drum in tumble dryer
Somehow they always end up in some inaccessible spot. Go to www.repairclinic.com and enter the model of your dryer. You will be presented with a list of common replacement parts and may be able to view a generic video showing disassembly for bra wire retrieval. Good luck.
Feb 18, 2017 | Dryers
Hearing a scraping noise (metal against metal) in dryer- how do I remove the door
it is also possible that a metal support bar from a woman's bra found its way between the drum and the panel, just reach with your hand or with a hooked coat hanger and turn around the seal of the drum,
Aug 01, 2015 | Dryers
Clunking banging noise
It may be something stuck in the drum, ie a bra wire, which would have extra weight on it whilst the clothes are wet. If this is the case, it will need looking at sooner, rather than later, as it will just be causing further internal damage
Dec 19, 2013 | Fisher and Paykel Dryers
The washer just started making this real loud high pitched noise while running the spin cycle?
have u lost a bra wire ?? it could be caught under drum or your bearings are gone in drum ... turn drum by hand it should run smooth .
Feb 27, 2011 | Whirlpool Washing Machines
Problem with bra wire
a common problem, the wire usualy catches on the heater assembly and wraps around it, shine a torch into the bottom of the drum through the holes and you should be able to see it,if so remove the heater to remove the wire. the only other place it could be is in the sump hose so remove that to remove the wire,i must do six or seven of these a week
Jul 26, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Drum wont turn
sounds to me like the belt may have fallen off the back of the drum.
look under the lid and see. if a wd, should be simple enoughto put it back on by removing the back cover to refit.
turn the power off though.
Jan 29, 2009 | Hotpoint Aquarius WD63 Front Load...
I have a hotpoint aquarius 1100 washer dryer wd51 was making a grinding noise we turned it off and a under wire from a bra was sticking through a hole in the drum pulled it out and it is complete but now...
The bra wire bears no relation to your present problem.
Remove top cover, screws at rear, and push top cover back.
See if the belt is still on, if it is, then select final spin and see if the motor and drum go round, if it does not, then the brushes in the motor probably need replacing.
Unplug washer, and disconnect the motor. you will find the brushes at the motor plug end, depress plastic lugs, and slide brushes out, if they are less than 5mm long, then replace them
If it is the belt that has come off, you will have to remove the rear panel to refit it.
Plz rate my solution.
Thanks.
Kenmore dryer
kutter1:
With the little bit of information you have given I would assume you have something stuck in one of the baffels ,((or possibly the most common is a Bra wire in one of the drum seals on the drum))
or a more in depth problem would be something in blower wheel (like the old playing card in the spoke of a bicycle)) when we where much younger.
woodychoppers
Jun 29, 2008 | Kenmore 75944 Gas Dryer
Intermmittent buzzing noise
IT COULD BE SOMETHING CAUGHT IN THE DRUM UNPLUG THE MAINS AND OPEN THE DOOR AND TURN THE DRUM BACK AND FORWARD YOU MAY BE ABLE TOPUT THE CAUSE EASIER LIKE WORN BEARINGS SOMETHING CAUGHT IN THE HEATER OR A BRA WIRE?
May 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
113 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
