Question about Acu-Rite Magnum-80181 Clock Radio
How do i turn my acurite 80181 radio off? there is no off button
Acurite pc connect doesn't connect
PC Connect Weather Stations AcuRite
Contact
  • General: 1-262-249-3259
  • My AcuRite: 1-262-203-5667
  • Mon-Friday: 7:00am-5:00pm CT
  • It is supposed to run on Windows 7.
    https://support.acurite.com/acurite
    I am tempted to tell you to try a system restore to a point where the program was running. This would uninstall programs between then and now but should restore your use of the application.
Sep 12, 2017 | Computers & Internet
Geo button on acurite weather forecaster model 02010 won't work
My opinion would be do do a factory reset. If this does not work, warranty? Do you feel comfortable opening up the case? Could be a connection issue. (Do not do this if it voids the warranty.
The link below are the instructions for reset and other options:
https://www.acurite.com/media/manuals/02010_02014_02015-instructions.pdf
May 16, 2017 | Computers & Internet
How do I set the clock on my acurite
Press and hold the SET button. when the two dots start to flash, use the hour button to set the hour and minute button to set the minutes. more accurate steps can be given if you share the make and model of the Clock Radio
Mar 02, 2016 | Audio Players & Recorders
How do i turn off the alarm on the clock would really like some instructions sent to me
Here are some alarm clock instructions for you.
http://www.acurite.com/media/manuals/13027-instructions.pdf
Jan 05, 2016 | Audio Players & Recorders
How do I change the time zone on my Timex atomic T303T clock?
http://www.acurite.com/media/manuals/75324T-instructions.pdf
Mar 09, 2015 | Timex Audio Players & Recorders
How to reset my Acurite 1099rx after replacing battery
http://www.acurite.com/advancedsearch/result/?q=1099RX
There is no reset button, installing new batteries causes the sensor to reset itself.
Try removing and re-installing the batteries.
Good luck,
Steve
Jan 15, 2013 | Measuring Tools & Sensors
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
I don't know how to turn off the alarm.
The manual is at http://www.acurite.com/manuals/00604A1-instructions.pdf
To turn the alarm on and off 1. press the alarm button momentarily. 2. Press the "+" button momentarily once or twice. The alarm indicator (looks like a bell) to the left of the time numbers will change from on to off.
Jan 06, 2011 | Acu-Rite Acurite Wireless Weather...
How to set the time on Acu-Rite model 13100 clock?
How do reset time on model 13003 ?? It reads 12:15 and the Time is 11:27 Clark page plaza@cox.net
Mar 08, 2009 | Acu-Rite Magnum-80181 Clock Radio
Acu-Rite Magnum-80181 Clock Radio Logo
Top Acu-Rite Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Acu-Rite Audio Player and Recorder Expert? Answer questions, earn points and help others
