Question about Toshiba Televison & Video
I have a toshiba plasma tv. Im getting audio but no picture. Please help.
  • 597 Answers
The reason you are having audio but no picture is simply because there is a problem on a component in the television.
First, unplug the television for at least 2 hours before unscrewing it open. After opening it, take not of the main board for any burnt capacitor, it will look either swollen, worn out, or burnt. Have it replaced, by turning the panel to the other side and using a soldering iron to melt off the lead from the tips then insert a new capacitor with the same capacity then reverse the process to reassemble the television back.
Another cause can be a bad lamp in the unit. All you have to do is to replace the lamp. And if any of that does not work, then it means there is a problem with the t-com board in the television, and the solution is for you to replace it with a new one.
If you are not familiar with such technical activities, i will strongly advice you seek professional assistance from a repairman. Also check if you are still under the warranty period given for the television so as to be able to return it to the dealer who will have it fixed for you.
Take care and good luck
Posted on Oct 13, 2010
    Scholar:
  • 143 Answers
Tap the TV on the right side front near the edge of the screen (not on the screen). Does a picture come back on? Please also provide the TV model number!
I have audio but no picture on my Zenith Z50PG10 50" plasma tv?
Plasmas are like tube TV's(CRT). Once the plasma tube breaks, air gets in, plasma gas gets out. And that's it. They are an enclosed vacuum picture tube. I don't know why people buy plasma. The newer LED have a much better picture. Rich people who swear by plasma, are ridiculous in my opinion. Again, if plasma tube breaks, thats it. Any wrong jarring can break a plasma tube.
Feb 12, 2014 | Zenith Z50P3 50 in. Plasma TV
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
I have a lg plasma and im trying to connect it to my pc hooked up the vga in the comp and on the backside of my tv, have the audio and hooked it up to the audio, but when i change input i can see the pc on...
It sounds like you are using the wrong audio input jack, by chance are you using the audio cable with RED and WHITE RCA to mini stereo plug ?
If you look at the VGA port on the the TV, you will see a small mini phone jack (PC audio) close by, that will be for the sound input when TV is in PC mode.
Please verify for me.
Dec 31, 2010 | LG 42PX5D 42 in. Plasma HDTV
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba 50in plasma
Hello brattbabie1,
Ok you have sound and no picture. This denotes that since this is a plasma TV the circuitry that controls the activation of the screen may have become defective. You will need the schematic to show the voltage levels that need to be present on the cable that connects between the screen and the control circuit and a voltmeter to measure those voltages. I would suggest that you get a qualified TV technician to work on this problem, due to the technical nature of this issue.
I hope this helps,
Thank you,
Shuttle83
Aug 09, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Toshiba 42HP66, HDMI problems
Your Cable box might need to be reprogrammed. Call the cable company and they will drive you thru the steps to program it, this way you will get the channels. This process might take you 30-45 minutes.
Artgirlny
Jul 12, 2008 | Toshiba 42HP66 42 in. LCD Television
42" Toshiba Plasma TV no picture or sound
My experience with 42" plasma tv's with no picture or sound was a missing power supply voltage. On the power supply board check voltages on the plug. The voltages should be marked on the board,
Mar 01, 2008 | Toshiba 42WP27 42 in. Plasma Television
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Televison & Video Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
