Question about Altec Lansing ACS 295 Computer Speakers
Power indicator light on right speaker is not lit. speakers are making clicking sounds. all connections seem secure. problem just developed today. assume issue w/ subwoofer?
    Master:
  • 397 Answers
Have you tried another set of speakers in your system? even a pair of headphones (directly connected to your soundcard, not the headphone port you can have on your speaker control)? If you get good sound through headphones/other speakers- it's likely a fuse in the subwoofer or the speaker set itself has gone bad. Usually the subwoofer has the power unit for the speaker set- check and see if the fuse has blown. If so, you can get a replacement either from a place like Home Depot, Radioshack, your local hardware store, even Autozone or Advanced Auto (even Wal-Mart usually has a few fuses). Check the documentation for your speakers to make certain you get the correct amperage fuse- too low, it will blow the fuse again; too high: it blows the speakers.
Posted on Oct 13, 2010
Harman Kardon 5187-2105 hp speakers: power light does not come on
Google the contact info for Harman. Start there.
Sounds bad. The power indicator light has faded to black and that usually means something serious like a failed power supply or if you're lucky, a bad solder joint somewhere. Always unplug the unit before you operate! Good luck!
Nov 30, 2016 | Miscellaneous
No sound. Tried disconnecting/reconnecting all input/output HDMI cables. Only computer is connected via RCAs (for sound only). No sound at all. Audio works on HDTV, which is going from cable box,...
Did the speaker relays light up ? and did you hear the third speaker relays ON clicking sound? If both no, DSP problem. If both yes, DIR problem. If the speaker relays lit up but NO speaker relay clicking sound, check relay driver +24V power supply.
Sep 17, 2017 | Yamaha RXV467 Receiver
I have boston ba 735 speakers i am using a new pc with windows 7 a presonus firemobile setup. I can get no sound out of the boston speakers. They are lit up when connected. I am able to record sound via...
click start control panel hardware and sound manage audio devices playback then select speakers you will se a list configure test disable set as default show disabled show diconnected.right click on speakers make sure they are enabled also select the recording tab you will see microphone midi right click on microphone and midi make sure ticks are in boxes show disabled devices and show disconnected devices
hope this helps
Jun 27, 2011 | Boston Acoustics BA735 Computer Speakers
With the speakers seemingly connected correctly I do not get a power indication.
clean your computer of dust using a fine air blower from a compressor specifically around your central processing and your sound card unit making VERY sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 31, 2011 | Bose Companion 3 Computer Speakers
I can not get any sound out of the speakers. There is 6 ports (all different colors) I have tried everything. I have had the speakers for a year now. I cleaned the computer and the speakers came unplugged...
first connect both the satallite speakers to line out which is located near to the power switch (speaker out)
Now vertically above these 2 connectors there will be another connector that says remote control (audio input) this is connector that gets connected to your PC.On your PC this should get connected to the green port named as line in.
connect the power cable to mains
switch on th power switch which is situated at the rear of the subwoofer.The power indicator light will be lit up with a blue light
Now adjust the speaker volumes and try to play music
Dec 26, 2010 | Philips SPA2300 2 Speakers
I re-installed windows xp service park 2 but there is no sound
You need to install sound driver separately after installing XP.
www.hiddendragons.tk
Oct 07, 2010 | Computers & Internet
My speakers won't make a sound.
Process of elimination... check your cable hookup first. then control panel and check sound, right click on properties tab and do a diagnostic.
Jun 02, 2010 | Creative Labs Inspire T3000 Computer...
Bel STi Short or Loose Connection
This most likely is due to a blown internal speaker which has shorted across its voice coil rather than becoming an open circuit. Bel/Escort now uses special "high temp" speakers which resolve any failing speaker issues due to higher temperatures. I assume that your STi is out of warranty. Yet, it will be worth it ($80) to have the speaker replaced and to have your STi flashed with the latest firmware which also gives the STi a true audio ramp-up rather than just the original slow or fast audio beeps to indicate the strength of the detected radar. The new firmware also includes slight performance enhancements, and includes better filtering for Autoscan mode. This latter enhanced Autoscan filtering makes the STi noticeably quieter while driving around town.
Apr 03, 2009 | STI Driver Radar Detector
Only a steady pulse comes out of my bull power
hello, it seems that you may have a bad ground on your amp? turn everything off(pull amp fuse at battery) and go to the amp ground and clean paint away to bare metal! secure ground tight and make sure the car battery is not low voltage! this may stop the pulse! the sound problem of no sound in speakers, if still there! make sure the speakers are not shorts or pinched to ground! this could damage the amp! hope this helps, good luck!
Jun 12, 2017 | Magnat Bull Power Reflex 300 Car Subwoofer
No sound
This issue could be caused by any of the below reasons.
  1. Sound card does not work
  2. Speakers are not connected properly
  3. No power to the speakers
  4. Volume on speakers turned down
  5. Volume on sound card turned down
  6. Bad hardware
  • make sure the speaker setup is correct. It is possible that during an installation of another program that the speakers software setup was changed causing issues with your sound. To do this follow the below steps.
  1. OpenControl Panel
  2. Open "Sounds and Multimedia Properties" or "Sounds and Audio Devices" in Control Panel.
  3. Click the "Audio" tab
  4. In the Audio tab click the "Advanced" button under "Sound Playback."
  5. In the Advanced Audio Properties window make sure your speaker setup is correct. If you're not sure what to set this setting as, set it to the default "Desktop Stereo Speakers" option.
  6. If you changed this setting click "Apply" and close out of all windows.
  • Ensure that the sound card works properly by connecting either another pair of speakers to the computer, or a pair of headphones.
  • the left speaker will generally have a cable that cannot be removed from it. This cable should be connected to the other speaker (generally this cable has no color or is white / gray). The next cable is the line out cable, it is generally green in color and should go from the right speaker to the line out hole in the back of your sound card.
  • Finally, the power cable generally should be connected to the back of the right speaker, or in some cases, the sub woofer. The power cable can vary; while most speakers are in the above configuration, some speakers may also not utilize a power cable connection but instead have batteries, while other speakers that connect to the side of your monitor may use a portion of the power from the monitor itself (via another type of cable).
  • Most speakers will have a small LED (light) indicating if the speaker is on. Verify that if this light is present that it is illuminated.
If no LED is seen or the speakers don't appear to be getting power, verify the power cable is properly connected to a working outlet or if your speakers use batteries that the batteries are good. Finally, most speakers can be turned on either by using a button or by moving the volume knob from left to right.
  • Verify that the volume knob on the speakers is properly turned up. If you are un-certain what direction to turn the knob, play a long sound file or CD and while the sound is being played, adjust the knob left to right or up to down.
  • The sound is also able to be turned up and down through the software installed on the computer. Verify the sound settings in the software are properly turned up.
  • Finally, if all of the above recommendations do not resolve your issue and connecting another pair of speakers or headphones to the computer does work, it is likely that the speakers are bad. It is recommended that you contact the manufacturer of the speakers or computer for a new replacement.
Jul 16, 2008 | Audio Players & Recorders
110 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
