Question about Kenmore Elite Oasis 27052 Top Load Washer
Everytime i put a load of clothes in its fine until it hits the 12 min mark and it starts to wabble everywhere and then the ul code comes on
    Scholar:
  • 78 Answers
Try making sure the machine is level front to back and side to side. It sounds like the barrel ( tub ) inside the machine is out of balance.
Hope this was helpful.
Good Luck
cookEmonster
Posted on Oct 13, 2010
Why do i have loud noises coming from my washing machine only whilst it spins
The bearing in the drum has failed and it's always noiier as it spins faster as there is more debris being thrown around inside the hardened steel casing of the bearing. Bad news is that's a write off. Uneconomical repair. It will tear its self apart shortly, probably leaking grease into the wash and leaving black marks everywhere, oor the drive belt will come off, or the drum will impact the front gasket and fill the drum with smoke. Any way you look at it, it's almost certainly going to destroy a load of washing. Throw it away now before it wrecks your washing
Aug 21, 2016 | Washing Machines
UL code keeps coming up at last 9-10 min of spin cycle will not finish load What could be causing this? Is it bent suspension rods?
I replaced the suspension rods but it not resolve the UL issue - still gave UL code even when run with no clothes in load -so I called Maytag for service.(Purchased REPAIR PLUS 1 which covers this repair and one year maintainence contract). Tech from local subcontractor service came out and said it was the bearing. I am still waiting for repair 10 days later because service contract required "approval" before he could order parts (7) including rotor and sensor although to fix bearing tech should only need bearing kit & tool to pull old bearing.
May 20, 2016 | Washing Machines
What does the error code UL mean?
UL means UnLevel. To fix , open door of washer, and redistribute the clothing/laundry in the machine, and press start. It should start spinning again. Sometimes , if you have a overly heavy load of laundry above will not work. What I have done is, put my weight on the machine (upper body laying on the top) until the machine has extracted enough water so the machine will be balanced.
Dec 10, 2015 | Washing Machines
Got it used and it shakes at spin at hi speed an ul come on
This can be due to excess load on the drum. remove the clothes and check once again. check the level of the machine, Also check the filling and draining water level to confirm if there was a overfill.
Jan 18, 2013 | Whirlpool WTW6200S Top Load Washer
How do you solve the balance problem in the kenmore elite oasis even with no clothes it in
Try running with no clothes? If still shows UL when empty running, your machine needs service. P.S. use HE detergent or else.
Aug 27, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
My cabrio waher will not spin on the last 12 min of the cycle...it displays ul everytime...it is not unlevel we have checked
My washer dose the same thing even with no clothes in it, cause i'v leaveled it and redistrbute the clothes in nothing wroks
Jan 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Everytime it goes to spin it starts shaking real bad displays ul then ol not even anything in it i have pulled tub there is a crack in the piece with windings but not affecting windings
The ul and ol are unbalance load and over load.
I would suspect the suspension rods, if you look you can see the tub is suspended by 4 rods (10 in image) and spring loaded shock built into them.
The crack in the stator is nothing that should cause any worry about.
If the suspension rods, springs and holders are all okay the next likely suspect is the basket itself.
Apr 25, 2010 | Kenmore Oasis 27042 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
128 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
