Question about HTC Touch Dual Slider Smartphone
Can't make phone calls with my touch slide always force close. When I try to make a phone call, the screen goes black and I can't view the dialer. Please help!
  • 597 Answers
The problem with the phone is the flexi ribbon thet slides the phone up and down, it is not properly seated that is why it is losing contact with the main board of the phone, hereby resulting in blank screen while dialing or making a call.
The flexi ribbon is known as the flex, so as soon as you replace the flex of your phone, it will work perfectly fine once again.
Have a repairman fix the flex of your phone, and it will be in good condition once again.
Take care
Posted on Oct 13, 2010
  • Kakaroto4 Jan 11, 2011
    Not necessary he didn't say he slide the phone he just said he cant see the dialer an i think its happens when he changes from the menu to dialer whit out using the slider if you reset your phone tho factory settings it would work just fine for a time but it will do it again I think is a problem with the version 2.1 and the phone try upgrading to any version of android 2.2 if it work just fine let us know
  • Toyosi  Sarumi
    Toyosi Sarumi Jan 11, 2011
    The version of the phone does not determine if your phone goes black or not, it is a hardware device that operates the screen. I am very familiar with such problem and definitely sure it is a flex problem. The firmware only changes if the version is changed and that does not in any way deal with making calls on the phone.
Tip
Nokia 5800 XpressMusic Smartphone Tips and Tricks 1. To bring out the...
1. To bring out the Shortcuts on your Screen/Desktop-> Settings/Personal/Home Screen/Home Screen Theme and select Shortcut bar, you can then select which shortcut to display if goto "Shortcuts". This will also bring out the "Track" playing being displayed when you open the Music Player.
2. Tap the Clock to bring out the Clock menu and make your alarm, alarm repeat is now built-in.
3. Tap the "General" or Date (the set Profile besides the clock) and the Profile selection menu pops out, almost similar to pressing the "Power" button in all S60, but here the Remove memory is not shown, but "Calendar" shortcut is included and the other profiles as well.
4. If you are on the Numeric Keypad, pressing the [#] key alternately will toggle the General and Silent Profiles, same as before, which means long press on zero [0] will bring out bookmarks for the Web.
5. Tapping on the displayed To do or Calendar entry will bring you immediately to that particular item.
6. Tapping the Active Icon on the Top Left (near the battery indicator) will give you shortcuts for any of the active icons.
7. Long press on the Green Call Button will still activate the Voice Command Prompt
8. Long press on the center button is similar to the Long press on the "Menu" key (the yin-yang key on most S60) which will bring out the menu for all the active applications.
9. Go to Applications/File Manager and setup "Backup" for automated backup schedule of your phone data.
10. How to update your Nokia 5800 firmware using your phone.
Press*#0000# to display phone factory information and firmware
Now press options and select check for updates
The newest update is sent to your phone from nokia
Download and install updates.
This is done using GPRS or WIFI Connectivity.
General Tips
1. Use Dialer and press # for about 2 seconds will switch the profile between Silent and General; press and hold 0 will open the web browser; press and hold 1 will open the voice mailbox
2. There is a shortcut key for Music, Gallery, Share, Video, Web shortcut at the top right corner just below the front camera
3. Press and hold the Green caller button when standby mode will activate the voice command. You could call the name from the contact or application name.
4. Organize your sms by grouping them like outlook by Messaging -> Option -> Setting -> Text message -> Other -> Show messages in groups -> Yes
5. Notification light will blink if there is unread sms/missed call. It could be turned off at Settings -> Notification light -> Off
6. If the touch input is not accurate, you could calibrate your screen at Touch Input-> Touch Screen Calibration -> ( Tap around the 4 dots at the corner)
7. Turning control functions:
a. Rotate your screen horizontal or vertical
b. Silence your phone for incoming call by rotate your phone with screen facing down.
c. Snooze the alarm by rotating phone screen facing down
8. Theme effect will give 3D and transition effect if on but will slow down your tube considerably. Settings -> Personal -> Themes -> General -> Themes effects -> On/Off
9. Shortcut to exit application : Press and hold the middle white button then press and hold the program that you wish to quit, an open/exit option will pop out (useful for those haven’t install handy taskman yet)
10. When using handwriting input, slide from left to right is Spacebar, right to left is Backspace
11. Organize your menu by Menu -> option -> organize. You could drag and drop the location of the application you wish to relocate.
Battery saving Tips
1. Always turn off wireless scanning, Blue-tooth when not in use
2. For those not using 3G, choose your network mode to “GSM” instead of “Dual mode” which will consume more battery. Settings -> Connectivity -> Network mode -> GSM
3. Less Display Light
a. Setting -> Phone -> Display -> light sensor (move the slider to the left)
b. Setting -> Phone -> Display -> Light Time-Out (lesser time to save battery but annoying if too short while you are playing games)
4. Always terminate the application properly that is not using by using Option ->Exit. It might be running background and consuming battery which you don’t know.
Memory Saving Tips
1. Restart your phone if the memory less than 30MB, you could either soft reset (User a dialer and dial 5 * * then call) or hard reset by pressing the power button
2. Use Handy Taskman to close all application regularly or kill application that is not in use.
Camera & Picture tips
1. Some noise could be reduced if set the ISO sensitivity to low instead of auto.
2. When viewing pictures, you could use your stylus to view for previous (slide left) or next (slide right) picture like iphone feature.
Video
For converting video that is high quality to play at 5800, should use the mp4 format as below (All is 16:9 widescreen):
a) Xvid @ 678kbps resolution 480×272
b) Xvid @794kpbs resolution 640×352
c) H.264 @ 512kbps resolution 400×224
d) H.264 @ 550kbps resolution 400×224 (Recommended)
Music tips
1. If you can’t find your songs after transferring from your pc to memory card, go to music player -> Option -> Refresh library
Application Tips
1. Always install your phone theme on the memory cards. This is because if some theme does not work (Christmas tree) then you need to flash your phone.
2. Uninstall your application in proper way. Use Menu -> Setting -> Application mgr. -> Installed apps -> Choose application then option n uninstall
5800 Hard Reset(credit goes to ArunGupta)
WANNA HARD RESET YOUR NOKIA 5800 XM?
JUST PUT *#7370# AND THEN PUT LOCK CODE(I.E 12345) BACK UP YOUR PHONE MEMORY BEFORE DOING THIS
NEW LOCK CODE METHOD FOR NOKIA 5800XM
PRESS GREEN KEY + RED KEY + CAMERA KEY WHILE BOOTING YOUR 5800 JUST PRESS IT UNTIL YOUR DEVICE RESTARTS
This method is for nokia 5800 XM
on Mar 05, 2010 | Cell Phones
Why htc wildfire dialer 4 5 6 does not work
greetings.. try going to settings>applications>manage applications>all category>look for something called dialer >force stop and clear data and cache. if that didnt work go to the playstore and download a 3rd party dialer app...i hope this helps... best of luck
May 27, 2014 | HTC Wildfire Cell Phone
There is a key combination to perform a hard reset for an LG KP500?
  1. Start by pressing Power button, device must be working to succeed this operation.
  2. Pressing Call key will open phone's Dialer.
  3. Type in this code into dialer. (Code: 1809#*500#)
  4. Factory reset operation needs to be confirmed by clicking green Call key.
hard reset for an LG KP500 Google Search
Jun 19, 2017 | LG KP500 Cell Phone
Can't receive calls on my ZTE warp
somthing wrong with your settings.
restart your cellphone,
Jan 18, 2012 | ZTE Warp
Samsung impression cell phone touch screen goes black when i use the keyboard.
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is going black when you use the keyboard.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will not go black again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
May 21, 2010 | Samsung SGH-A877 Impression Cell Phone
When i slide the phone to expose the number pad it the screen just goes black and when i close it, its stays i can get calls but just cant see anything
that was the common problem of sliding phone, flex cable of your phone's got damage and need to replace, just go to cellphone repair shop.
Jan 23, 2010 | Sony Ericsson W760i Cellular Phone
Phone is muted...No one can hear me when I am calling, or answering a call. I can hear them fine. Phone shows "muted"?? How do you "un" mute?
Receiving Calls
1. To answer a call, touch or open the slide.
 If the slide is closed, simply slide it up.
 If the slide is closed, press the Voice
Commands key twice, then touch .
 If the slide is open and the touch buttons are
lit, touch .
NOTE If you touch Left Soft Key [Quiet] while the
phone is ringing, the ringing or vibration is muted
for that call.
NOTE If you touch Right Soft Key [Ignore] while the
phone is ringing, the call will end.
Mute Function
The Mute Function prevents the transmission of
your voice to the caller. To quickly activate Mute
touch Left Soft Key [Mute], then to unmute
touch Left Soft Key [Unmute].
NOTE! while doing this you must call someone then while talking with him touch Left Soft Key [Unmute] to Unmute
Hope it help you out ^_^
try download the manual if you loose it
http://www.cellphones.ca/upload/manuals/lg-vx-8500-manual.pdf
Jul 03, 2009 | LG CHOCOLATE VX8500 Cellular Phone
My phone touch dialer /keypad not working .
my phone touch keypad is not working, so i am unable to unlock my phone, have any solutions?
Jan 23, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC Touch Dual Slider Smartphone Logo
390 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
