Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
We have a ESS25LGNAww GE Eterna side by side frig. We have replaced the mother board thinking that was the problem, not much difference. Problem is the Freezer is set on 1 and is frozen harder than it should be at that temp. Icemaker is working but the water dispenser won't work. Most importantly, the upper part of the frig is too warm, ie 50 degrees, but the produce drawer freezes the fresh veggies solid. It is set on 8 at present. The damper between the fridge and the freezer opens and closes periodically. Had to superglue it at one point because it was such a flimsy design and broke off. What could be the problem. The thermostats and defrost have all been changed in the last yr or so too.
Joe_Rex
  • 114 Answers
SOURCE: Fresh Food & Freezer Warm
CHECK AND MAKE SURE YOU CAN HEAR YOUR EVAPORATOR FAN RUNNING (INSIDE MOTOR). IF IT IS NOT RUNNING ... AND YOUR COMPRESSOR IS RUNNING. THE MOTOR OR DEFROST TEMENATION SWICTH COULD BE DEFECTIVE. IF NOTHING IS RUNNING ... TRY TO LOCATE THE DEFROST TIMER(USUALLY LOCATED WHERE YOUR COLD CONTROLS ARE) YOU SHOULD SEE A SMALL HOLE WHERE YOU CAN MANUALLY TURN THE TIMER WITH A SCREW DRIVER.IT CAN ONLY TURN IN ONE DIRECTION. IF THE MOTOR IS RUNNING. CHECK TO SEE IF COMPRESSOR IN THE BACK IS RUNNING ... IF IT ISNT AND IS "HOT" (BE CAREFULL) SEE IF THE CONDENSER MOTOR NEAR THE COMPRESSOR IS RUNNING ... IF NOT ... THE COND. MOTOR IS BAD ... THAT MOTOR RUNS IF POWER IS GOING TO THE COMPRESSOR ALWAYS. IF COMPRESSOR IS HOT AND NOT RUNNING AND COND. FAN IS RUNNING .... UN PLUG FRIG AND WAIT TILL COMPRESSOR IS COOL TO THE TOUCH. THESE COMPRESSORS HAVE AN INTERNAL T-STAT THAT PROTECTS THE COMPRESSOR IF IT SHORT CYCLES.IT SOMETIMES GETS SO HOT IT DOES TAKE HOURS TO COOL OFF. THERE IS ALSO A DEFROST-TERMINATION SWITCH THAT CAN GO BAD. CONSULT A LICSESED FACTORY CERTIFIED COMPANY TO GIVE YOU A FIXED-PRICE DIAGNOSTIC TEST.
Posted on Apr 28, 2007
  • 531 Answers
SOURCE: Items in Fridge are Freezing/Water Dispenser isn't working
you will have to call in service
Posted on Apr 03, 2009
Sea Breeze
  • 4654 Answers
SOURCE: frigidaire freezer cold, refrig in 50's.
Yes pull the refrigerator away from wall and feel top of the compressor. Is it too hot to touch? Are bot fans running. Straight wire the thermostat to see if it is causing this. The start relay and start capacitor may be the reason. Let me know by email you response because Fixya has not been notifying me of any ones response to my solutions. I just found you made a response. Sea Breeze
Posted on Jul 20, 2009
  • 25 Answers
SOURCE: Frigidaire plht189sska top freezer fridge problem.
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Posted on Sep 15, 2009
Testimonial: "Thanks for your help. Just looking for direction and trying to troubleshoot ...very frustrating. Thanks again Em"
  • 2468 Answers
SOURCE: loud ticking noise when i close freezer and lights
if your lights burned out recently and the digital temp read-out is now dark also,burned out lights will cause a power surge and will destroy the main-board circuit trace(mother-board), it is located in the back side of the refrigerator, in a small plastic case,when you remove it you will see a burned spot on the circuit board and the loud clicking sound is a relay on the board trying to latch to light the bulbs and operate the unit
Posted on Feb 21, 2010
Ge side by side frig won't defrost gss25sgmb new heater motherboard thermostats
Replace the thermistors #4 and #5 . 4 is the white bullet looking piece on top of the coils inside the freezer , with 2 white wires . 5 is at the bottom of the freezer , on the left side . These thermistors tell the main board , the temp and the board goes into defrost according to temp the thermistors "tell it " .
Aug 14, 2012 | GE GSS25SGMBS Side by Side Refrigerator
I have a GSL25JFPA BS that the frig side will not cool properly. Repalced the mother board. t stat in freezer and thermistor in frig. Freezer works fine. Damper will open when first plugged in but closes...
Unplug the refrigerator and then plug back in. Using multimeter check between J3-1 and J3-4.
Must be done within 10 seconds of starting. You should have 6 VDC. If you do replace damper, if not replace motherboard.
Jul 06, 2011 | GE GSL25JFPBS Side by Side Refrigerator
My eterna Ge frig is not cooling, freezer part is what can I do to fix the problem?!
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Artica, pulsing lights
Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00 .
Dec 09, 2009 | GE Profile¿ Arctica® Energy...
Ice dispenser will not shut off
If yours has a dispenser control board it would be suspect. Do you know what the model number of your GE is? With that I will be able to trace down all the different possibilities. Most ice makers are mechanical arm up switch is off. let me know, Sea Breeze
Aug 18, 2009 | GE Refrigerators
Frig lights on but not cooling
The GSH25JRF uses a mother control board and we need to unplug and have a look for burn mark on both sides of the board. The board has 2 different numbers for the same board. WR55X10942 or PT number 1531075 Main Control Board. The board is located behind your refrigerator and under a covered panel screwed down with sheet metal screws. We will need to also look at the start relay and start capacitor if the board looks OK on both sides. Here is what to look for on the board, burn marks, signs of heat or loose solder connections. Let me know if I can help you more I will be here to assist you, Thanks Sea Breeze
Aug 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
Side by side fringe goes stays in defrost mode
replace the mother board part number wr55x10552. it located on the back of the frig
Nov 21, 2007 | Freezers
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
132 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
