Question about Acer TravelMate 4150LCi Notebook
Hi tm4150 heatsing holding 4 screws faild i'm tried use super clue still shut down
  • 393 Answers
Its batter use solding wire with solding iron and sold it i slove many time thanks
Posted on Oct 14, 2010
How do I tighten the ignition switch on my fxd?
If your ignition switch went loose or damaged you will have to change it ,then tighten. the screw that hold the IGN switch to the frame.
Jul 12, 2014 | 2006 Harley Davidson FXDCI Dyna Super...
Moonroof will not vent or seal shut. Why?
It sounds like a mechanical adjustment. A lot of times moon roofs will have adjustment screws to make small alignment adjustments. You may have to move the glass to various positions to access them, but that is where I would start.
Jun 18, 2013 | Ford Fusion Cars & Trucks
Shuts down unexpectingly when running game programs
Is the Laptop Overheating? During intense game play your Laptop will Overheat if it's not getting sufficient air flow. Try cleaning the Fan, vents, heatsing with Compressed Air, Improve air flow through the Laptop, a Laptop Cooler is a option. Try shutting down unnecessary processes, I use freeware RAZER GAME BOOSTER, you configure what you want to shut down: http://www.razerzone.com/gamebooster Remember, Your machine usually shuts down for a good reason, it's trying to protect vital components. Overheating will fry the CPU, Graphics Adapter, etc.
May 11, 2013 | Gateway NV73A17u Laptop
A/C runs fine for 7-8 minutes, then shuts off.
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
May 11, 2013 | Sharp Heating & Cooling
I HAVE A PAIR OF BURBERRY SUN GLASSES THAT SCREWS KEEP COMING OUT OF. I NEED TO KNOW WHAT CAN BE DONE .I HAVE TRIED PUTTING SCREWS IN BUT THEY KEEP COMING OUT.
sounds like the threads worn pop the screw in and with a pin head apply superglue otherwise take into any glasses shop and they should be able to help please give thumbs up thanks
Aug 09, 2011 | Burberry Clothing Accessories
Computer shuts down when xp loads
Follow CPU FAN and the temperature of the CPU from BIOS under the PC health.Or you can change the RAM if you have a spare .Some times CPU FAN or HEATSING base broke ,so you should check the base of the CPU FAN>You can open the cpu and apply correct heatsing paste.
Follow some links
http://www.pcbuyerbeware.co.uk/BIOS.htm
Regard's
Shibuda
Jan 03, 2011 | Mach Speed X-Caliber PT800DBP Motherboard
Compaq presario v5000 won't stay
sounds like overheating , probably due to the cpu or gpu fan/heatsing loosing contact, even a little knock could have caused this
Jul 16, 2010 | Compaq Presario Notebook
My computer shuts down at random on its own
it could be a heat issue,
can you reseat your heatsing and fan?
and make sure that there is a metal to metal contact
pls rate if this thing helps
Jan 25, 2010 | E-Machines eMachines Desktop PC
Blank screen, triple beeps when trying to shut off
I have looked around for you and here's what i found:
Try holding down the power button on the front of the unit till you hear a beep (4-5 seconds). If you don't the unit will power on, but won't reset the video settings. Most people don't hold the button down long enough.
i hope i have helped and i hope it works,let me know how goes !!
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
How to replace outside mirrors on a 2002 ford f-250 super duty
you need to remove door trim panel there are (2) 7mm screws that hold panel on .. 1 is behind the lower red light lens and the other is behind switch panel for the power window switch . remove both screws and remove small black panel above door trim by pulling strait off .(now there are (4) 11mm nuts the hold mirror on 2 are behind the small rubber plugs in front of door that you can see with panel on and the other 2 are under panel that you can see after panel is removed . the wiring need to be disconneced you may have to remove speaker for acess to feed new wiring down into the door good luck
Mar 10, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Acer TravelMate 4150LCi Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
