Sd card faulty
I can not access my micro sd card which has phots on it, can i repair it without formatting
  • 1,944 Answers
Try using this to recover the pics.
Posted on Jun 01, 2008
My 2gb sandisk micro SD card reduce the size after formatting
Possible micro SD bad sectors. To check your micro SD bad sector or not, you use the HD Tune software. To restore the capacity micro SD, which is done is Low Level Format. You can use the software HDD Low Level Format Tool.
How to use HD Tune and HDD Low Level Format, you can see here
Transcend Repair Bad sectors
How to repair micro SD, you can see in here
MMC Repair Without Losing Data Video 2
Oct 12, 2011 | SanDisk 2GB microSD Memory Card
After i insert my 1 gb sandisk micro sd card into my blackberry 8530, an error message comes up: "cannot access media card due to fatal errors" i have tried to install, repair, and format it...
It sounds like in your situation that you may have a bad card. If you cannot get your card to mount to your phone for storage, I would try to find access to a pc that has an SD card slot that you can try to format it that way. If the card still wont format, your looking at a defective card and will need to purchase a new one.
You can find Micro SD cards here for purchase.
Sep 22, 2011 | SanDisk 2GB microSD Memory Card
I cannot format my memory card
You should be able to just use a micro sd card adapter and use your computer to format it to FAT32. Then you should be able to stick it in your phone and use it as normal. Otherwise it could be a faulty micro sd card port.
Aug 22, 2011 | Nokia N70 Cellular Phone
My 1 gb micro sd card is corrupted and my nokia E63 phone and DELL inspiron is not recognising it
    • 1 If your aim is to repair a corrupted SD card so that you can use it to store files then proceed to step #2.
      If your aim is to recover the files on the SD card without erasing them, proceed to step #5.
    • 2 Insert the SD card into a digital camera card slot and choose to format your card. If this doesn't work then move on to the next step...
    • 3 Place the SD card into your computers SD card slot.
      Right click on the SD card drive letter IF it appears and choose to "format."
      If this doesn't work, proceed to the next step...
    • 4:You will need to go to the website
      Here you will download, install, and run the program to format your SD card. This is the most advanced step of the three, but most likely to work 99% of the time.
    • 5
      If you want to recover files ON your SD without erasing them, then you need to download and run the software on this site.
      This is the best free software available for this type of problem.
Jun 02, 2011 | Maxell 4 GB Class 6 Micro SDHC Card with...
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
I took pictures on my Samsung Rogue phone and saved them to the micro SD. I'm wanting to print them directly without having to email them one by one. The only way I'm told I can was to purchase an adapter...
I don't quite follow what you have done or are trying to do, but that last bit about formatting sounds like the problem. Formatting a memory card deletes everything on it.
I would suggest that instead of putting your SD card into your camera for printing, that you put it into a card reader attached to a computer. You should then be able to access the card as a removable drive and print the pictuires with the computer's printer. There are adapters for fitting Micro SD cards into a standard size SD card slot- maybe that is what you are using.
Nov 17, 2010 | Kodak Easyshare CD82 Digital Camera
I cannot access my 2GB micro sd card in computer or phone, when i opened it from computer i get message card need to be formated but when i start to format card windows says unable to format this device....
i cannot access my 2GB micro sd card in computer or phone, when i opened it from computer i get message card need to be formated but when i start to format card windows says unable to format this device. please help me.
from kapil sharma
Sep 19, 2010 | PNY 2GB microSD Memory Card
I want to format my 3110 phone i need a formating code
lets try to fix your problem without spending a single cents..removed your micro sd ,(small memory card of your phone) then scan it in computer,,by doing this you need an all in one card that supported mini sd,mini sd ,memory stick etc..then you will find if your micro sd is having a virus..back up your files then reformat your micro sd ,then after formatting back your files...without your micro sd open your phone ,if it is ok now ,so the problem is your micro sd...if still there the problem ,reset your phone by doing this ,type *#7370# and enter your locked code..wait until the phone reboot itself.
Jun 21, 2010 | Nokia 3110 Cellular Phone
Micro SD card
try to format it using your computer.
Connect the card with computer using a card reader
Then go to my computer right-click the micro sd-card and select format. Format it using FAT.
May 24, 2008 | LG Shine KE970 Cellular Phone
Televison & Video Logo
434 people viewed this question
Top Televison & Video Experts
