Question about LG Computers & Internet
My LGFlatron L194WT-SF monitor just stop working.Is there a reset button on it or something?
  • 11,361 Answers
No reset button, more likely to have failed power supply due to bad caps, tha twill be the first place to look.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 13, 2010
I use an LG L194wt-sf monitor and I just installed windows 7 on my desktop computer which was using windows xp formerly. i optimal display is 1440x900 and its not available in the resolution settings what...
Try to update the display driver on your monitor.They should have a website for that.If not your monitor may not be able to display at that resolution.You can also check out your video card.Good Luck.
Aug 02, 2012 | Samsung Computers & Internet
My L194WT -SF WONT WORK NO POWER USED SAME POWER LEAD ON DIFFERENT MONITOR NO PROBLEM
Hello Steve,
The most common problem with the L194WT monitors is a failure of the power supply board. There are parts called capacitors that fail and can cause the issue you have. Sometimes the power light will just flash, sometimes it takes several minutes to display a picture or even a wavy picture, all of these issues indicate a failing power supply board. These boards can be repaired if you can do a little soldering. The L194WT uses the same power board as the L196WTQ and we have a step by step repair guide with dis-assembly instructions available at http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ Look over the guide and check your board to see if your capacitors have bulged and need to be replaced.
I hope this helps, if so please rate our solution.
BuddyMc
Aug 07, 2011 | LG L194WT 19" LCD Monitor
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
HOW TO CHECK A LG FLATRON L194WT-SF MONITOR FUSE, THE REAL PROBLEM IS HOW TO REMOVE THE BACK COVER
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L194W&kategoria=monitor&kat2=all
After removing all the screws and the base, I use thin flat blade screw driver to crack open the case starting at the bottom egde and work your way around, just watch out for any cables attached to the front bezel. The monitor is not made to be easily open up.
Please read my guide so you will know what to look for inside the monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 15, 2011 | LG FLATRON L1919S-SF 19 inch LCD Monitor
I just got my LG L194WT-SF with an older computer and dont know what hapin, but it dont turn on i have try'd difrent power cords but still no power ive seen outher people with same problem but no awsners..
Hi There,
It's used LCD Monitor, right? You can read my Tips about this kind of issue, just click here.
Let me know if there is not clear enough.
regards,
dm
Dec 16, 2010 | LG L194WT 19" LCD Monitor
How to open a 17" LG L194WT LCD monitor
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L194WT%20&kategoria=&kat2=all
I usually open it at the bottom edge first and work it all the way around using thin flat blade screw driver.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 17, 2010 | LG L194WT 19" LCD Monitor
My LG l194wt monitor keeps shutting off.I am not sure if there is a reset button.After unpluging it will sometimes come back on
take the post(power on self test ) of a monitor connect power cable and disconnect signal cable see that no signal check signal cable massage comes then monitor is ok right cllick on desktop then properties screensaver -power -select -never
Feb 28, 2010 | Computers & Internet
Hi My LG Flatron MDL L194WT-SF just stopped working. no power surge or power outages. Can this be repaired or is there an internal fuse that may have blown. it is just like new and hate that it failed....
They have an internal power adaptor which does contain a fuse. However the fuse is soldered to the board so you need soldering skills to change it. Also, if the internal fuse has gone then it's probably because another component such as the transformer has gone in which case it won't help.
Unless you know how to troubleshoot electronic boards a component level you're almost certainly out of luck here I'm afraid.
Jan 14, 2010 | LG Computers & Internet
My screen keeps going blank after about 2 hours
check the flexible connectors conecciom tambein There is a false contact
Aug 21, 2009 | LG Flatron L1710S 17" LCD Monitor
Computers & Internet Logo
402 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
