Question about Whirlpool GEW9200L Electric Dryer
Dryer maked humming noise when start button is pushed, dosen't turn on
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 15, 2010
Amana Dryer LEA30AW
usually the humming sound is coming from the motor,try this,open the door,turn the drum with one hand and hold the door switch in with your other hand and have someone else push the start button at the same time,this might help the motor turn on but if it does you need a new motor,if you can't turn the drum you could have something stuck in the blower wheel or something jammed in the motor like a broken belt but like i said a humming sound is usually the motor.
Feb 22, 2012 | Amana Dryers
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
When I push the start button on the dryer it makes a hum noise and did not start. It makes a lot of electrical consumption because the lights of the house decrease their intensity when I push the start...
heatman101
a
Sep 28, 2010 | Maytag Dryers
HUM NOISE OCCURES WHEN TURNING KNOB TO LEFT BEFORE PUSHING KNOB TO START- STOPS WHEN POINTING TO OFF POSITION - MODEL GYC4000AWW . DRUM DOES NOT TURN
it sounds like you have a bad motor and door switch. the unit should not run unless you push a start button. the humming noise is the motor. either something is blocking it or your motor is bad,
Oct 12, 2009 | Magic Chef CYG2000AWW Gas Dryer
Dryer won't start but makes a humming / buzzing noise when you push the start button
If the humming noise is coming from the motor, (take the back panel off) remove the power plug and try to turn the motor by hand. If it seems free, look for a 'starter' capacitor on the motor which may be bad.
Oct 11, 2009 | Dryers
Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Mar 15, 2009 | Kenmore 84052 Dryer
Maytag dryer mod #mde600ayw only makes a humming noise when start switch pushed will not turn.
a hum with a burning smell means the motor winding has failed.
you can try this: open the door and hold in the door switch, have another person hold the start button. You manually roate the drum by grabbing a fin and moveit while the unit is humming.IF the dryer starts, you need a motor.
Good Luck!
Feb 28, 2009 | Dryers
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Kenmore dryer hums but will not start
If it just hums the motor is probably on it's way out. If it makes a growling noise, it's the motor.
Nov 04, 2007 | Dryers
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Whirlpool GEW9200L Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
