Question about Technics Audio Players & Recorders
I have a cd stuck in the back of my player. I can hear it moving around inside when I pick up the player. The cd tray will only go half way in. HELP!
    Problem Solver:
  • 9 Answers
Try turning upside and shaking it may free up
Posted on Oct 13, 2010
Game stuck in the back of my xbox 360
If you have a xbox 360 the DVD drive is self contained you wil have to open the system to retrieve the game go to www.llama.com to find a tutorial on how to open the system
Feb 14, 2013 | Microsoft Xbox 360 Console
CD'S ARE ENTERED IN THE TRAY AND WHEN CLOSE BUTTON IS PRESSED IT DOES NOT SELECT ANY CD AND TRAY CAME OUT AGAIN. MEAN IT DOES NOT PICK THE CD
Does this happen on all cd's you try? Are these original cd's or burned copies? Many times burned copies will not work in certain players, it depends on the formats your player is capable of reading. If the player can not read that particular format it will reject it. Another thing to look at is to make certain there is nothing in the player that shouldn't be there, with the player open flash a light inside to see if there is anything stuck inside. Just a couple of things to try, hope this helps solve your issue. Best of luck.
Feb 18, 2011 | Audio Players & Recorders
Cd tray will not open. Is there a quick fix for this I can do myself?
If when ejecting the disc tray you can hear motor noise from inside but the tray doesn't open up...
1. Unplug the unit from the A.C. outlet
2. Remove top cover
3. Look for rubber drive belt that causes load/unloading tray to move in and out.
4. Replace with new rubber belt..not a rubber band but a rubber belt.
Nov 08, 2010 | American Audio CDI-100 Personal CD Player
Dvd does not eject when open/close button activated?
Hello sir, hi!, the dvd tray is controlled by a single motor connected to a shaft/pulley where a belt is spun to roll a series of mesh gear to move the tray forward... well something like that, usually the problem is the belt, its wormed out, replacing this belt will tighten the pulley making the tray to eject. You need to disassemble the unit and get to the belt to replace it
Aug 31, 2010 | Philips Televison & Video
Hello, I have a jammed cd in the player. Was
Pull the top off the unit. It's 6 or 7 phillips head screws. Two or three across the back,and two on each side. Pull the back of the top up first and slide it away from the front and then off. CD should be very easy to remove at this point. If you need further help, post a comment and I can help you more.
Nov 02, 2009 | Sony CDP-C545 CD Player
Cd is stuck inside the player. I moved the unit when decorating and now the unit will not play any cds and there is one stuck inside. I removed the casing to look inside but got scared off when I saw all...
It is safe (except for the lead solder) as long as the unit is not powered ON.
There is a "pin hole" on the front of the CD tray.
With power OFF, use a stylus (straightened-out paperclip) to push the mechanical eject button inside the pin hole. Carefully use enough force to push the CD tray out.
Oct 13, 2009 | Audio Players & Recorders
CD stuck in a 5-disc changer
There is a flat ribbon cable on the inside that is defective. The cable needs to be replaced and the loading mechanism retimed. This is a simple repair for a repair shop. Expect the ribbon cable to run around $10. Add in the local labor rate for the total repair cost. I've done many of these. This is a common problem with age.
Dan
May 07, 2008 | Audio Players & Recorders
Stuck CD
hi there bguedes
best solution take top cover of and as it says pleasewait and you hear the noise just give the tray a bit of a jolt to help it around but beware of electric wires and static that should fix your problem
hope this helps an please if you have the time please rate me if you dont mind
thank you
fixya
Jan 11, 2008 | Kenwood CD-323M 200-Disc CD Changer
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
