Question about E-Machines eMachines Desktop PC
Why is there no signal when i connect my desktop to my flat screen?
  • 386 Answers
Hi Good day!! No signal of your monitor means:
1. vga cable is not properly connected each both end or maybe it is damage.
2. if your using a video card (AGP,PCI-E) maybe the slot of your video card have dusts that's why your video card is not sending any display to your monitor.
to solve this:
1. pull out the vga port and re-plug both ends..
2. if your using video card remove your video card and clean your video card slot by using a brush. after then put it back be sure to lock your video card.
hope it works now!!
REGARDS
JR
Posted on Oct 13, 2010
    Scholar:
  • 131 Answers
If its you tv flat screen you might have to go to the menu and select pc on that...if its your pc flat screen make sure its connected fully to blue vga connection and turned the right way up...hope this helps
    President:
  • 1,768 Answers
1. You could have a faulty video graphic card on the mother board.
2. Your display or LCD screen has a bad power supply adapter or not get
power at all.
3.Your display has a bad inverter board and needs service. I cannot tell
not being able t o see the devices physically.
4. A computer tech can determine this with a few simple isolation test such
as disabling the video card and using a know good one in the pci or AGP
slot and connecting the monitor to it.
check the video cable to see if it is seated properly. check for bent/broken
pins on the video cable.
5. the video card is sometimes built in to the mother board and may have
lost the drivers. Do a driver update and or reinstall the video drivers for
the video card.
6. check the monitor/ connect it to a another pc to see if you have a screen
/ if so then the video card may have lost drivers or may have stop working
7. check the "device manager for this:
instruction set here>>>
http://support.microsoft.com/kb/307970
Windows 7:
http://windows.microsoft.com/en-SG/windows7/Open-Device-Manager
I hope this helps. Have a good day.
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Random "No Signal"
This can happen if your monitor's refresh rate is too high, try lowering the refresh rate, and or the resolution. Also disable the screen saver, as this too can have unwanted results. Further also make sure you have the most up-to-date Video Driver, for your setup too.
Jul 21, 2010 | E-Machines eMachines Desktop PC
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
Nothing on screen after turning on
Connect the LCD to a different (laptop? desktop?) computer, to see if the screen works at all.
Connect a different monitor to your desktop computer, to see if the video-card on your computer is working at all.
Jun 09, 2010 | Compaq FP 7020 17" Flat Panel LCD Monitor
Need to connect hp flat screen moniter to dellgx280 pc tower
Hi. Just Plugin the signal cable of your HP flat screen into the VGA port at the back of your dell optiflex computer, look for a blue port on the back with fifteen holes on it and that should be your VGA port. Hope this Helps
Jun 04, 2010 | Dell OptiPlex GX280 PC Desktop
When i turn on my screen it says no signal and turns off
Either the "data" cable between your screen and your desktop is defective, or that cable is not connected to your screen, or that cable is not connected to your desktop, or the video-card inside the computer is defective.
Check the connections.
Temporarily connect the screen to a different laptop/desktop computer, to see if the screen still works.
Temporarily connect a different screen to your desktop, to see if your desktop's video-adapter is working.
Feb 28, 2010 | eMachines W3507 PC Desktop
Acer flat screen monitor, attached to laptop. Turns on and says 'no signal' occassionally works though for a short period. Works when connected to other laptops.
If this monitor works when connected to other laptops, the problem is likely to be your laptop, not the monitor. I would suspect that there are bad comnections at the video connector of the laptop.
Dan
Jul 23, 2009 | Computers & Internet
LG 32LG30 no signal when pc and tv r connected via rgb cord
For No signal try- Updating your Video drivers, and making sure it shows a connection on your laptop ( by going to propertys on desktop and then dysplay)
For format try- Updating and or turning down the screen resulotion becuase the size differs on screen even if you think it shouldnt.
Mar 14, 2009 | LG 32LG30 32 in. LCD HDTV
Blue screen
set your dell desktop display for 1024x768 60 hz refresh.
right click on desktop/properties/1024x768
and then advanced/monitor for 60hz refresh
then connect to tv.
Dec 02, 2007 | iLO 2600 Television
E-Machines eMachines Desktop PC Logo
125 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
