Question about Krups F203 Grinder
I just got a brand-new Krups F203 grinder. I was grinding up a whole bunch of coffee at once and at about the fourth cup of grounds, while the button was still pressed down, it just shut off. And now it won't turn back on again at all - I thought maybe it had overheated so I left it for a while and tried again, but nothing. I tried different outlets etc. but it won't turn back on. Any thoughts?
  • Krups Master
  • 1,309 Answers
You may really have overheated it and it may not have a self resetting thermal fuse. Probably best you say nothing and take it back for repair or replacement under guarantee. When you are up and running again do much less grinding at one time.
Posted on Aug 09, 2017
SOURCE: Burr grinder GVX212
I had the same problem, took it all apart, separated the two halves, and looked into the guts of the machine, not an easy task. Fiddled with this and that, and looked at the back of the switch mechanism, and heard it making a 'click' when depressed, so put it all back together, to no avail...It turns out the grinder needs to have two limit switches engaged, one between the lid of the ground coffee hopper and the underside of the grinder hopper housing, and the other between the grinder lid and the base of the unit. This last limit switch was my problem, it seems the lid wasn't making contact with the limit switch, so the unit didn't run. I cleaned out the narrow gap that the grinder lid sits within, pressed the lid down until I heard a small 'click' , pressed the on switch, and presto! it works. You can see this very tiny switch if you take off the grinder lid, and look in the narrow gap it sits in at a position of about three o'clock ( the back of the machine when viewed from the top being 12 o'clock. Hope this helps anyone else who can't find their receipt within the one year warranty period. This is the best burr grinder I've found for the money, and I'm glad mine's still o.k.
Posted on Feb 06, 2009
SOURCE: Krups GVX2-12 Electric Burr - Thermal Fuse
Open the grinder by removing both knobs.
The front knob is held in place by friction. Use two flat head screwdrivers to pry it off.
The side knob is held in by tabs you have to push. Pry forward to expose the tab, and use another screwdriver to press the tab, and use the other screwdriver to press the tab on the other side.
Now look at the bottom of the grinder. There are four tabs on the outer shell, use screwdriver s to pry the tabs to separate the bottom of the grinder from the shell, and pull off the shell. Your fuse should be attached to the motor wiring coil.
Posted on Jun 27, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Krups GVX2-12 grinder - ground coffee and
Most plastic products contain enough carbon black to neutralise this problem. Obviously not with yours.
Try a camera accessory cleaning cloth - specifically anti-static.
http://www.amazon.co.uk/gp/product/B00006IVV8?ie=UTF8&tag=shopwiki-uk-21&linkCode=as2&camp=1634&creative=6738
Cleaning less often will also help, and maybe a quick brush out would result in less mess.
Natural fibres like cotton cloths or bristle brushes will also help.
Coffee naturally has oils that, if left on, will eliminate this problem anyway.
Posted on Feb 07, 2010
Testimonial: "Thank-you - unfortunately, reviews I've found about this coffee grinder indicate that it's a common problem, but your suggestions has helped some."
My grinder stopped suddenly. Open the cover(s) by prying at the cracks with a butter knife or flat head screw driver.
The thermal fuse was good in my case, as were the interlock switches.
The circuit board was burnt around a large power resistor but I could figure out which component was bad. I simply cut out the timer control completely. One of the black motor wires now connects to the red wire from the bottom interlock switch and the other black wire connects to the blue AC power wire. I may put in a button switch but it works great by using the lid interlock as an on/off switch.
Posted on Mar 16, 2010
bcarson750
  • 5 Answers
SOURCE: coffee grinder will not turn on
I recently had this same issue - it turned out that the lock switch no longer engaged because the spring came out of alignment after the unit was dropped. Chances are you have a similar issue. You can test this by using a small screwdriver to press down on the safely latch and then pressing the ON/OFF (careful of the blades!!). then you can easily fix it.
Posted on May 16, 2010
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
Grinder stalls constantly (motor whirring, but no grinding happening) so I shake it to get it grinding again, but the whirring/no grinding happens over and over. I have to shake the think 5 or 6 times to...
As I can see, what happens is that some coffee grains stucks in the way from the upper pot to the grinding wheel. This is not something usual, but possible if coffee grains are too big and are placed across the entry of the mill. Try cleaning more deep with some old toothbrush. Look for a clean and even surface of the duct.
Other cause might be a loosen mill hub/grinding wheel off the motor shaft, which would require dissassemble of the appliance to be repaired.
Dec 10, 2010 | Krups Burr Coffee Grinder
Grinder starts up but wont grind..nothing happens. one week old
I think this might be because no beans have gone down into the mill. There is a definite difference in sound when it is actually grinding beans. Try emptying the beans out, set it to the coarsest setting, put the beans back in, shake the thing a bit then turn it on.
Jan 17, 2009 | Krups Burr Coffee Grinder
I bought a Krups GVX2 coffee grinder and am not able to get it to work. I have followed the instructions "to the letter" but once it's plugged in and switched on, the "on" switch on...
I know that this machine is sensitive with the lids needing to be securely fastened (both the top and the plastic catch bottom container) maybe that is it.
Jul 14, 2008 | Krups GVX2-12 Electric Burr Grinder
I have a Krups Orchestro Model 889 which hasn't been used in a while. Now when I use it, the grinder works and the steamer works but nothing pours into the cup when I activate the machine. I think its an...
I had the same problem with my Krups Orchestro and today picked it up from service. There was nothing wrong except the internal filter was blocked and a manual clean by the technician fixed it. I think I exacerbated the problem by going to the finest grind over time the amount of liquid to the cup got less and less till it stopped.
Now I am using a courser grind - hopefully this will delay the onset of the problem. I was going to try a clean myself - but was deterred by the security oval head screws on the back. The repair centre told me they thought the Krups machine was a great product - and that I should expect many more years. It is essential though to perform maintenance (clean especially) as soon as prompted.
Jul 10, 2008 | Krups Orchestro 889 Espresso Machine
I have a 12 month old KRUPS XP7240 coffee maker. It has just ceased to grind the beans. I suspect that the grinder or hopper to the grinder is blocked? Any suggestions how it might be...
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
May 19, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Won't Grind without shaking it!
Sound like it's choked up with grounds and oil. Burrs may also be blunt. U need to dismantle and clean/ check burrs, passages and body. If you can see "flats" on the burrs or they feel not sharp when you check with finger, they should be replaced.
Jan 17, 2008 | Krups GVX2-12 Electric Burr Grinder
Krups F203 Grinder Logo
649 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
