Question about Mordaunt Short 906 Rear Speaker
I mistakenly removed the binding post with the red and black label for speaker polarity in one amongst the speakers. I cant remember how to return it back. Is there a speaker polarity for MS906 declaration series? My bose 301 have a left and right speakers with binding post polarity opposite from the other. Do MS 906 have the same? Thanks a lot.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 40 Answers
For the ms 906 scanner, this is the original one, you can find your local dealer, they can help you
Posted on May 27, 2016
2 Suggested Answers
zoomiezz
  • 50 Answers
SOURCE: mordaunt short 906 tweeters
 i have found that partexpress is a good place to replace speakers and much more
Posted on Feb 25, 2009
Wiring a DVC 10 inch sub to 2ohms
RED IS USUALLY POSITIVE
RED-WHITE IS MORE THAN LIKELY NEGATIVE
TO CHECK SPEAKER POLARITY:
1. HOOK LEADS UP AS I DESCRIBED
2.TAKE A AAA,AA,C,OR D BATTERY
3.CONNECT POSITIVE SIDE TO POS ON BATTERY...NEGATIVE TO NEG END......
4. IF SPEAKER "CONE" PUFFS OUTWARD..POLARITY IS CORRECT. IF IT PULLS INWARD..POLARITY IS REVERSED
Jul 21, 2013 | Cars & Trucks
Tip
Using Proper Speaker Polarity
Sound system speakers have standard polarity which is indicated either with a "+" or a "-", or with Red and Black colors near the speaker terminals. This same polarity marking is also found on the sound system amplifier section. Most speaker cable has a polarity indication; either color coded, or a physical difference in the wires. Reversed polarity results an obvious decrease in bass, and a hollow sound in the mid range frequencies. If your speaker cable has no obvious polarity indication, you can check the polarity as follows; connect a 9V battery to each speaker cable for no more than about a second; long enough to see the woofer cone move. When the + battery terminal is connected to the + speaker lead, the woofer cone will move out. When you have this situation, label the positive speaker lead, either with tape, or by tying that wire in a simple knot. Make sure both cables are checked.
on Oct 06, 2010 | Audio Players & Recorders
Peavey SP 118P speaker leads...blue and yellow? which one goes where on the speaker?
Blue should go to red. I assume they used an Asian standard. Rough way to remember- sky blue, return brown/ground is green yellow- same potential as brown. yellow somewhere in between.
However reversed leads are not going to be noticed on the speakers of a single amp/speaker. Or if a multi speaker setup in a cabinet as long as all are mated with the same polarity.
It just translates to the direction a speaker cone is moving in relation to the magnet when the polarity of the sine wave peak is positive.
In a stereophonic setup- many can hear the difference an out of phase speaker can make, in a monophonic setup- no one is going to hear the difference. And on a stage setup, unless the speakers are all attached to the same source, they are all moving independently.
Feb 17, 2012 | Peavey Music
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
I just moved and had someone disconnect my high end surround sound home audio system. I'm still trying 2 figure out the connections to the back of the speakers.. They are B & W Nautilus SCM1...
If your speakers looks similar to these...
You should see 4 connections on each speaker.
Look for a label that says "IN" or "INPUT"... probably the top connections. 1 is gold (with a red cap) and one is silver (might have a black cap on it). If you have the original cables, they will be red and black.
Attach the red cable to the gold... black cable to the silver. Do the same on the back of your audio system (more than likely red/black look for the "OUT" or "OUTPUT" connectors.)
The main thing is making sure the cables are connected to "like" colors (when possible).
The other two connectors on each speaker, if labeled "OUT" or "OUTPUT"... are for piggybacking more speakers. Otherwise, they are more than likely used as a "RETURN".
Apr 02, 2011 | Audio Players & Recorders
There is not a subwoofer input jack on the back of this subwoofer. There are a set of input (negative and positive) terminals and a set of output (negative positive) terminals like would hook speaker wires...
On the back of the sub woofer you have two sets of binding post / some have spring clip terminals ( red & black ) labeled Speaker In ( sometimes High Level In ) and Speaker out.
Take 2 pairs of speaker cables and connect one end to the speaker out socket of your amplifier ( left & right ) . The other end of the cable should be connected to the sub woofer's Speaker In socket , Red to red and black to black. Now on the Speaker Out socket of the sub woofer connect your existing pair of speakers using another pair of speaker cables. If your sub woofer has a Hi Pass filter built in , you may not hear bass coming from your existing speakers with this kind of connection. Good if you have small satellite speakers.
Mar 12, 2011 | Audio Players & Recorders
Do LF and HF +/_ both be connected and if yes do they both go to speaker system A or separate to A and B on the amplifier.
From the factory, those are equipped with "jumpers", one for red-red and one for black-black. This allows for one speaker cable to power one speaker.
The jumpers can be removed, allowing for "bi-wiring", where you run two leads from a single amp channel to both inputs on each speaker. There's also "bi-amping", using a treble amp and a bass amp dedicated to each input.
If the jumpers are missing, you can use a short piece of stripped speaker wire to reconnect the upper and lower binding posts, just be sure to match colors.clmrt5000_0.jpg
Jan 10, 2011 | KEF Audio Q55 Speaker
1985 Ford Laser, I want to know what wires/colour match new wires/colour when installing a new car stereo and speakers?
do it the old fasion way i have never used diagrams for splicing iht existing wiring.
simply a test light to find constant+ switched + ground, and such thin trial and error for speakers!
there's 3 screws above the heater/vent controls, and two screws behind the ashtray - you've gotta pull it all the way out. then the centre console comes out, along with the stereo. the heater control knobs pull off by hand, no screws, you may also have to remove the choke 'knob' to get the plastic consol off. The knob is held on by a screw on its underside, then you will have to unscrew the collet (chrome thing) with a screwdriver, you will see what I mean.
For speakers, if the car already has them then sweet, but if you need to check polarity is correct get a AA battery put the wires on either end, and if the speaker moves 'out' polarity is correct as per the signs on the battery,if the speaker moves in the polarity is wrong.
does it have the standard pioneer deck in there?
if so and u want to go by those colours
red = acc
orange = +12v
black = ground
green = left +
black = left -
grey =right +
black = right -
(cut the joining black wires on the plug (the one that has 2 black wires coming out is the front, the one that just has one black then a bridge across the plug is the rear)
if u want to go behind the plugs then
blue/red = left +
blue/yellow = left -
blue = right +
blue/white = right -
(same for rear but on a seperate plug)
dont remember the colours for acc and 12v (they're blue with some trace, one of them is black i think)
ground is black (might have grey dots)
illumination is red/black
Dec 13, 2010 | 2006 Ford Laser
How do I hook up banana plugs to a infinity PC 350 speaker
The illustration in the manual I found at retrevo.com isn't detailed enough to show the axial connection option, which would normally accept a banana plug inserted straight in if the opening is conductive and about 4mm wide. I suspect it is as they mention a "variety of wire connectors".
Their only illustrated example show bares wire ends inserted into a small hole drilled through the termial post and the red or black plastic piece tightened down to secure it.
WIRING THE SYSTEM
IMPORTANT: Make sure all equipment is turned off before making any connections.
For speaker connections, use a minimum #16-gauge speaker wire with polarity coding.The side of the wire with a ridge or other coding is usually considered positive polarity (i.e., +).
NOTE: If desired, consult your local Infinity dealer about speaker wire and connection options.
The speakers have coded terminals that accept a variety of wire connectors. The most common connection is shown in Figure 5.
To ensure proper polarity, connect each + terminal on the back of the amplifier or receiver to the respective + (red) terminal on each speaker, as shown in Figure 6. Connect the – (black) terminals in a similar way.
See the owner’s guides that were included with your amplifier, receiver and television to confirm connection procedures.
IMPORTANT: Do not reverse polarities (i.e., + to – or – to +) when making connections. Doing so will cause poor imaging and diminished bass response.
Feb 20, 2010 | Infinity PC350 Center Speaker
What is the polarity of the jbl platinum series speakers
Speakers don't really have Polarity ... they have Phase. The audiophile wants the speaker cone acting in the same direction not opposite directions. So, watch your wire - one conductor will have a rib on it, the other smooth. You pick which you want to hook to the red or the + or what the mark is on your devices pick the other conductor for the other side, black or - or what ever matches.
Make sense???
Please post comment to this question if you need more info
thanks for your interest in FixYa.com
please vote
thank s
a
Dec 07, 2009 | HP JBL Platinum Computer Speakers
Mordaunt Short 906 Rear Speaker Logo
133 people viewed this question
Top Mordaunt Short Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
rhodesworks
Are you a Mordaunt Short Audio Player and Recorder Expert? Answer questions, earn points and help others
