Question about Lenovo G550-29583AU Notebook
When i'm typing on my G550 the cruiser will suddenly move to another line. and no, i'm not touching the touchpad.
    Genius:
  • 1,035 Answers
Hi. You need to install a new touchpad driver for you touchpad. This is a common issue for this unit. you may download this driver to this link. Once you have it installed in the system. Go to the sysnaptics software and look for a box that says "tap off when typing". Put a check mark on that box then you are good to go.
Have a nice day!
Posted on Oct 13, 2010
How do I disbale the Lenova G550 touchpad Thank ou
To turn off the touchpad when an external mouse or other pointing device is present, you can go to the Control Panel and double click the Mouse properties icon.
a) Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting
Feb 22, 2011 | HP Computers & Internet
When typing, my cursor will randomly jump to some other part of page thus screwing up what I have already typed. I am not accidently hitting touch pad. Lenovo G550 thinkbook Windows 7 proffesional...
Hi rbdav1,
Based on your situation. I suggest trying the following steps:
1. Download touchpad driver from here:
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=600154
2. go to Touchpad section and make sure you select the Windows XP, Vista or Windows 7 version of the drivers that matches your Windows operating system.
3. After downloading the touchpad driver driver install it and then restart your computer.
4. Log back in to your computer then go to control panel --> open mouse properties then look for Alps pointing device tab.
5. Under Alps tab uncheck tap off when typing.
Hope it helps.
Thanks for using FixYa
Best regards,
Reyjoshua07
Dec 13, 2010 | Lenovo G550-29583AU Notebook
Mouse Cursor Jumping while typing causing major typing errors
Reinstall the Mouse Drive rplease and it should work.
Please write abck if you still face problems.
Jul 01, 2010 | Lenovo 3000 Y410 Laptop
My Hp dv5 suddenly started giving problem when typing the cursor is jumping. what will be the reason? I cannot type continuously. I hav to search for the cursor where it goes. suddenly it disappears and...
This issue could be due to corrupt Touchpad drivers or corrupt Touchpad sensitivity settings or corrupt BIOS settings. To isolate this issue, please perform the steps provided below: 1. Uninstall and reinstall touchpad driver on the notebook. 2. Decrease the Touch Sensitivity of the Touchpad. If you are using Windows Vista on your notebook then you can follow the steps listed below for decreasing the touch sensitivity of the touchpad: a. Click Start and type ?Mouse? without quotes in Search field. b. Click on Mouse from the results list. c. This will open d. Click on Tapping tab in the Mouse Properties window. e. Click the Touch Sensitivity Button to launch Touchpad settings. f. Move the slider to the desired setting (in between Light touch to Hard touch) This will adjust the Touch sensitivity of the touch pad. Now check for the issue. 3. If the issue persists, then update BIOS on your notebook. To update BIOS, go to the HP drivers download page for your notebook model and then download and install the latest available BIOS update.
May 20, 2010 | HP Pavilion dv5000t Notebook
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
Mar 03, 2010 | Compaq Presario 700 470024-192 Notebook
The cursor jumps around on my E-105-S1402, suddenly moving to an entirely different place on the screen or moving back in a typed line so what I'm typing suddenly is inserted in a previuosly typed...
Yes.
Most probably, you are involuntarily very lightly touching the surface of your touchpad with the base of your (usually right) thumb.
Some touchpad drivers have special settings to ignore very light strokes to avoid this effect - try your pointing device settings in the control panel.
If yours doesn't, you just have to remember to keep your hands at such an angle as to avoid contact with the touchpad. A soft wristrest may help, as it elevates your wrists a bit; gel-type wrist support is my favorite.
Good luck :)
Nov 04, 2009 | Toshiba Satellite A105 Notebook
Laptop Touchpad - cursor random dragging problem
On my acer all I have to do is press function F7, Function is the button with 'Fn' on it. I am not sure if that works for HP, but its worth a try. Also, is there a switch near the touchpad? Sometimes there is one that switches the touch pad on and off. You can also try other Fn(function) F1 or Fn F2 etc. and see if one of the other "f" buttons work.  I hope this helps, let me know how you made out. Good Luck!
Jan 16, 2009 | HP Compaq dc5700 Microtower - Free Flat...
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Cursor skips lines while typing
My experience: cursor suddenly moving backward when i was typing, or moving somewhere else on the page. I would be typing and text suddenly would get highlighted. I followed someone's advice to disable the touch pad. Since I do have a mouse & key pad that was all i had to do.
HOW TO DISABLE THE TOUCHPAD FOR ACER 3680 AND OTHERS??? PRESS Fn +F7
Yep, it was that simple. At first I made sure i typed without my fingers or palms touching or near the touchpad. I noticed it seemed to stop or happen less. Soon as I disabled the touch pad all is back to normal. Yet I spent hrs trying to find out how and there were all these posts by people suggesting downloads and other more complicated things etc..
May 12, 2007 | Acer NSK8458AN Keyboard
Lenovo G550-29583AU Notebook Logo
136 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
