Question about Kenmore 500 6952 Dryer
I have a Kenmore 500 that shuts off if the load touches the door from the inside or wont start unless I press the door in again after its shut. I'm assuming there is a safety switch the door touches to let it know the status of the door. How can I fix that switch so it stops shutting off when the door is still shut?
  • Kenmore Master
  • 2,290 Answers
Sounds like the door catch is loose,this is what holds the door shut,when the clothes are spinning they hit the door opening it enough to reset the door switch,there's a metal or plastic tab that goes into the catch,easy to install and part is cheap money
Posted on Oct 17, 2010
Testimonial: "thanks!"
    President:
  • 3,074 Answers
Sounds like the door switch is loose, you will need to remove the front panel and make sure it is not broken or unseated. remove the screws inside the door and pop open the top corners. Hope this helps tim
Posted on Oct 13, 2010
Testimonial: "Thanks! I'll give that a shot!"
My Kenmore 500 mod 110.69522800 type DWSR-ELE-2406026-FM54 start button wont turn it on. How do I fix this?
I will help you please contact me melissamaemartin@yahoo.com I have neen repairing appliances for 34 years
Feb 01, 2014 | Dryers
I have a Kenmore 500 model # 110.68532700, sometimes it would work and run for about ten minutes then shut off, after about 10-15 mins you could run it again, sometime it would run fine tell the clothes...
see this possibles causes:
see the diagram attached
1) Test the main start switch for open 2) Test the switch door for open 3) Test any coonector for loose wires, or broken wires, or burn .4) Motor defective repair
Jun 09, 2012 | Kenmore 500 6952 Dryer
After 500 kenmore dryer is done drying the dryer won't shut off
The push-start switch in the dryer is probably bad. The contacts inside the switch get warped over time, causing the dryer to think you pressed Start again after it finishes a cycle. Replacing that switch should solve your problem. You can find the switch online at PartSelect.com if you know take the rear panel off the dryer and see what the switch looks like.
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Dryer&Brand=Kenmore&PartType=Switch
Nov 06, 2010 | Kenmore 500 6952 Dryer
I have a front loader. When I shut the door and
pin on door switch is brocken. look on top of door latch
Feb 12, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore dryer 70 Series doesn't shut off, timer continues to run
there are 2 different kinds of units made back then.
one has a push to start button that could have a stuck contact causing the unit to think you are pushing the button and want it to run again.
the other could have a stuck motor switch and thats not available separately. you would have to replace the motor. try to clean any lint out of the motor if you have that type. use compressed air to blow the lint out of the motor. it usually works to get the lint out and it can cause the switch to stick.
Dec 28, 2008 | Kenmore 63942 Dryer
Lid Display lit when starting wash cycle
LID code could mean that the door lid switch is not pressed. try to shut the door completely or the lid switch could have been broken. or the plastic that should press the lid switch could have been broken also. it is attached to the door i hope i was able to help.
Jun 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Please help , tell me why door is locked, on h 2 kenmore washer,
THANK YOU,
still nothing,
red doorlock light on, wont do anything,
I have to unplug so it will shut off,
when I plug in and hit start, red light stays on again,
Mar 28, 2008 | Kenmore 4292x Front Load Washer
Kenmore 500 6952 Dryer Logo
149 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
