Question about Vacuums
Belt replacement can you tell me how i replace the belt on my electrolux velocity hoover please
  • lubo25 Jun 02, 2008
    MY HOOVER IS AN ELECTROLUX VELOCITY PETLOVER HOOVER AND THE MODEL NUMBER IS Z2955BZ. THANKS
  • lesvaley8 Oct 08, 2008
    i have the electolux velocity and dont know how to change belt lost instructions
    President:
  • 1,673 Answers
Need to know if it is a Electrolux or a Hoover and the model number.
Posted on Jun 01, 2008
  • Lauren Junge
    Lauren Junge Jun 02, 2008
    Sorry, am not familar with this model, but most if you remove the bottom plate, you can then replace the belt. Put it over the motor shaft and then over the brush roll and stretch the belt until the brush roll sits in place. On some you have to remove the top cover to do this.
I have a Electrolux velocity hoover one side of the hoover brushes is stuck not the side with the belt how do I fix it thanks
Are you talking about the brushroll? If one side of it wont turn then most likely the beating is fouled and it needs to be replaced.
Jan 17, 2016 | Hoover Vacuums
Burning smell
Something may be keeping the brush roll from spinning freely which may have caused the belt to break.
Jan 02, 2014 | Electrolux Central Vacuum
Replacing belt on u6331-906
Your best bet is checking the owner's manual.
May 10, 2012 | Hoover Elite U5061-900 Bagged Upright...
Have electrolux upright hoover that only picks up when using the hose but have no idea how to get to the belt to replace it - help - jackie
I was not aware that hoover and electrolux merged if so you will probably need a phillips screwdriver turn the unit so you can see the roller remove all the screws that hold the cover to the base than take off the cover plate and check the belt if it needs replaced remove the old belt take off the roller by sliding it out of the slots put the belt on the shaft that is conected to the motor first than over the end of the roller where the belt should ride than you will need to pull the roller towards the front of the unit untill it slides into the slots on the side of the base put the side that dosent have the belt in first than replace the roller cover plate and the screws and you are ready to vacuum, Don the Vacuum Doctor Alb, N.M.
Oct 29, 2009 | Vacuums
Loss of Suction
check for a recall on that product
Oct 21, 2009 | Electrolux EL1000A2 Pronto Bagless Stick...
I have a velocity pet lover 1900 only 2 months old
You have broken the rubber belt that drives the brush. Flip over and remove the old belt and replace it with a new one.
Jim
Jun 10, 2009 | Electrolux EL1000A2 Pronto Bagless Stick...
Electrolux velocity pet lover 1800
we had the same problem and replaced the driver belt. The only problem is that we seem to have to replace the belt everytime we hoover!
Sep 07, 2008 | Electrolux EL1000A2 Pronto Bagless Stick...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Feb 15, 2008 | Electrolux Central Vacuum
Belt Replacement in Hoover Savvy
go to thehooverstore site. find your machine and they'll have exploded diagrams for your machine - your should be able to tell how to replace the belt.
Sep 01, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Vacuums Logo
170 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
